Question about Frigidaire Refrigerators
I am looking for the wiring diagram for a Frigadare FRT21LRGD2
Ice macine is not working. Thanks so much!
  • Official Brand Answer
  • 2,267 Answers
Thank you for your post, Larry White!
I understand that you would like a copy of the wiring diagram for your Frigidaire refrigerator. I was able to locate a wiring diagram for your refrigerator. If you have any additional questions please feel free to reconnect. -Matt
Frigidaire Manual Search Results
Posted on Nov 13, 2014
Frigadare refrigertor side by side its cooling fine but the freezer wont freeze
Check the heater coil in rear of freezer. Mine was burned out. Letting ice build up on the cooling fins. Replaced with new type double heater coil and fixed proble. You'll have to remove the cover off rear wall of freezer section to access it.
Jul 04, 2014 | GE GSS20IEP Side by Side Refrigerator
I have a whirlpool gold gs6nbexrl002 the ice maker works but the motor will not turn to despense ice thru the door i was wondering if there was a wiring schematic so i could check for power to the motor? ...
Yes there is but Whirlpool has become very strict about posting their material. I have to purchase their subscription yearly to have help topics to assist my customers. I will assist you if you like but posting the GS6NBEXRL00 Wiring Diagram here or on-line I cannot do. Let me know through Fixya, my profile or the capsha at top and near bottom of site here, Thanks, Sea Breeze
Jan 10, 2011 | Whirlpool 25.4 Cu. Ft. Side-by-Side...
Scotsman DCE33A-1WB Residential Ice Machine Problem
Making good ice. Could be cube size control. Could be a weak compressor. Also these machines are household and meant to run in air conditioned space.
Aug 02, 2010 | Scotsman DCE33PA1BC 15in Built-in...
M/n gs6shaxmq00 s/n sp4654020 whirlpool refrigerator not dispensing ice cubes through chute. Auger motor also not coming on. Suspect circuit board but need wiring diagram to test. Switch is pushing in and...
I would like to work with you with this. At the moment I have found the wiring diagrams for your model. And here is first=> http://www.servicematters.com/docs/wiring/Wiring Sheet - 2255955.pdf
Try looking over that and if you have more question please let me know. One person I trided to help said not helpful before I could get back with the parts and things to look for. If you need more assistance please contact me here on Fixya or my Forum=> Appliance 911 My contact information is located above the Fixya Ad on my blog here=> Sea Breeze Appliance Parts and Technical Services, Thanks, Sea Breeze
Jan 19, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Frigidaire side by side FRS24ZSG. Door Dispenser doesn't work
click on the wiring diagram and look at the circuit which powers the dispenser...it looks like the safety switch would be a problem to all the functions you listed above..such as the light not working.. no ice... no water
i would look for power to that safety switch..and if its getting power.. then i would check continuity through that switch.
also another possibility maybe its the wiring harness that leads to the dispenser.
Oct 05, 2009 | Frigidaire FRS6R5EMB Side by Side...
Ice make just quit making ice - worked fine up to this point
Hi!
Please check whether the ice maker has been turned off. Here's how to check.
Look for a wire along the right side of the ice maker that looks a bit like a coat hanger. If this wire is in the raised position, the ice maker is turned off. On some units you simply lower the wire to the down position to turn the ice maker on. On others, you lower a small red plastic lever to lower the wire. If the wire is in the proper position check the freezer temperature, it should be between 0-8 degrees Fahrenheit. If it is warmer than 10-12 degrees, the ice maker may not produce any ice. Check your door seals and thermostat, repair/replace as necessary.
Please do accept this solution and revert for further assistance.
Thanks
Rylee
May 19, 2009 | Kenmore 56549 / 56542 / 56544 / 56546 Side...
I need the wiring diagram for an ice maker for the Maytag Refrigerator # PBB2255GEQ
Bring your model number to my site and enter the model number in Model search. The search will take you to your model and on left side of screen scroll down to wiring diagrams. Click it and you will get the complete wiring diagram. At top right you will see the ice maker. Hope this helps, Thanks, Sea Breeze
Click below
http://servicepartstec.blogspot.com/
Mar 19, 2009 | Maytag MFI2568AE Side by Side French Door...
No water to the ice maker. No voltage to the inlet solenoid
icemakers work on a timed cycle and a timed fill. pressing the reset switch i would say solved your problem. I would switch the valves back to the way they were. The valve for the ice is smaller then the door water because the icemaker takes a small amount of water to fill. Good luck
Jul 21, 2007 | LG LRSC26910 Side by Side Refrigerator
Refrigerators Logo
97 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
