Question about Intermatic Inc. EJ500C Digital Wall Switch Timer - Self-Adjusting Feature
When hitting the next/on/off button, it dims the lights vice turning them off???
Tried a hard reset. Same thing.
  • Intermatic Master
  • 5,245 Answers
The EJ500 is rated for incandescent (resistive) bulbs only, and not LED CFL etc.
Max distance between light and timer is 100 feet and wire cannot be underground.
Replace with ST01 timer, or Ei600 timer... these timers are rated for any load (resistive or inductive), and are programmable or dawn-dusk... 7 day... single-pole or 3-way
http://waterheatertimer.org/Programmable.html#st01
Gene
Water Heater Timers Save Money
Posted on Nov 17, 2014
MY SONY EREADER ISNT WORKING AT ALL. THE RESET BUTTON WILL NOT DO IS JOB AND THE ONLY THING ON THE SCREEN IS ROTATING ARROWS.wHEN I CHARGED IT DIDNT TURN YELLOW.iTS BEEN LIKE THI9S SINCE CHRISMAS AND IT IS...
Hi huffasia,
Looks like a charging problem, try this:
1. Connect the reader to the computer and make sure red steady light comes on, if not, then hit the reset button for 3 seconds.
2. Once you get the redlight, leave the reader charging for 15-30 minutes (make sure the computer does not go into sleep mode)
3. After you charge the reader, try the soft reset again and slide the power switch at the top of the unit.
If this does not resolve the problem you may try a hard reset on the reader but this will remove all content.
To hard reset:
1. Hit the reset on the bottom of the reader
2. Slide the power switch
3. Once "Opening Book" comes on the screen, press and hold the directional "down arrow" and the number "0" both at the same time until "Reset All" appears on the screen.
4. The screen will go blank, now its time to turn it on again.
Note: If after trying the hard reset, the reader goes back to the black arrows trying to turn around, then repeat the steps again.
Hope this helps!
eBookBoy
digialreader.freeforums.org/
May 16, 2011 | Sony E-reader Portable E-book MP3 Player
2001 plymouth voyager, when i apply brakes the lights go dim
Is your check engine light on? Do they dim when you hit a bump Tammy?
Feb 25, 2011 | 2000 Plymouth Voyager
2007 KLX250 KAW. Out of the blue, when hitting the starter button, all electrical functions quit (horn, lights, nuetral light, etc.) After sitting 5-10 min. everything electrical "reset" as if...
the starter hase a loose field inside the starters casing. That will cause the armature to rub and short out the entire electrical system when hitting the starter button. At times it will not in your case therefore the bearing or armature shaft is bent or very worn causing this to happen at times.
Dec 18, 2010 | 2006 kawasaki KLX 250
I can't get my car to start, when i turn the key the car don't make any sounds, i check the battery, change the starter
The next thing i would check is the ignition switch itself. Turn the key to the on position, If the red warning lights on your dash don't light up (and your battery connections are clean), the ignition switch is bad. If they do light up, turn the key to the start position. The dash warning lights should turn off at this key position (most cars). If you're not sure, turn on the headlights. When you try to start the car, the lights should either dim (a lot) or turn off completely. If they do, your ignition switch should be ok. If not, the switch will need replacement.
Sep 02, 2010 | 1995 Ford Windstar
The lights have gone dim
Press the yellow button on the remote, do not release. You will notice that lights will go from bright to dim and vice versa. Remote shows percentage of light on the LCD (display). Good luck!
Oct 31, 2009 | Hampton Bay AC414-LRU 52'' Kemper...
Will not eject
Have you tried using the remote control if the button on the front of the unit won't work, and vice-versa? Try playing each disc, then go to the next so that you know all are loaded back in, then try again.
Aug 28, 2009 | Sony CDP-C910 10-Disc CD Changer
Monitor turns off and is dim
replace pwr inverter board...
replace the video/keyboard as well...
Feb 08, 2009 | ViewSonic Optiquest Q9b 19" Flat Panel LCD...
Ps3 80 gig
Try getting a new AV Option, well actually first startup your PS3, startup your controller, and hit the center PS3 button, because those 2 options are only in the Main PS3 Option, which is accesed and closed through hitting the middle button on your controller. Hope this helped.
Jul 11, 2008 | Sony Playstation 3 (PS3) Console
Intermatic Inc. EJ500C Digital Wall Switch Timer - Self-Adjusting Feature Logo
89 people viewed this question
Top Intermatic Hardware & Accessories Experts
Craig Butler
Craig Butler
Gene Haynes
Jay Finke
Jay Finke
Are you an Intermatic Hardware and Accessory Expert? Answer questions, earn points and help others
