Question about Maytag Neptune MDE5500AY Electric Dryer
When power came back on, getting 88 on digital display but won't reset
    New Friend:
  • 4 Answers
88 is diagnostic mode. just press cancel or push power again. that will reset it back to normal use.
Posted on Nov 14, 2014
How to calibrate rubbermaid 4010-88 digital scale
Pressing the ZERO button will set the display to zero.
Here is the Spec Sheet
http://www.rubbermaidcommercial.com/rcp/products/detail.jsp?rcpNum=4010-88
If you think it is no longer accurate you would have to get an engineer in to reset it. Here is the Calibration Certificate.
http://www.rubbermaidcommercial.com/rcp/ObjectServer?table=PDFs&id=660
Dec 29, 2015 | Rubbermaid Pelouze 4010-88 150 lb. Digital...
Our fridge compressor won't run after a power outage, can it be reset?
compressors use a small start / run capacitor to start the compressor
modern fridges do not like spikes from power outages and many power boards and electronic components fail because of this and I am inclined top use a surge protector before the fridge cord plug
I went google and typed in --fault code 88-88 for samsung fridge model rf26aewp and the first site up is error codes /messages/ blinking
the site is support-us.samsung>popup>iframe
there is a detailed answer there with a list of fault codes as well and what they indicate
there are other sites that also refer to the fault that you have
Dec 15, 2015 | Samsung RF267AEWP - 26 cu. ft. French Door...
Digital display flashes 88 for both sides. Can t set anything or turn on ice maker
Need your model number to give you answers. Try resetting the controls by unplugging power for 1 minute and then plug back into power source.
Appliance 911 Sea Breeze
Sep 30, 2015 | Refrigerators
Samsung rfg298 display 88 a8
The power went out, then came back on a minute later. I held the Energy Saver and the Lighting buttons together for about 10-15 seconds. That reset the refrigerator. Nothing else worked.
Mar 23, 2013 | Samsung RF265AA Bottom Freezer French Door...
When i unplug the timer then reset a new time schedule and plug timer back into wall my timer sets to 88:88. whats am i doing wrong? this timer worked brilliantly until i reset and plugged it back in.
Open following link to identify timer and read instructions:
http://waterheatertimer.org/How-to-program-Utilitec-0155671.html
Timers go bad for many unprovoked reasons.
Check outlet with circuit analyzer.
This timer has 1 year limited warranty.
Extended warranty: If timer is defective, then buy new one from Target or Lowes, and return defective timer in new package.
To review:
Replace AA battery if this model has a battery carriage. Otherwise timer has internal rechargeable battery.
Press reset button with paper clip for a few seconds.
88:88-88 will flash on screen momentarily, and then 12:00 am will display. Timer is ready for programming.
If 88:88-88 does not roll over into the 12:00 am display, try resetting again.
If timer will not hold new programming, and keeps resetting, then see if reset button is stuck.
If timer does not reset and re-program correctly, then timer has gone bad.
Add a comment for more help
Take a moment and rate answer for accuracy:
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Sep 23, 2011 | Woods Industries 59377 Indoor Digital...
The power went out and now our GE refrigerator GFSS6KKX display on one side says 88 and the other is blinking back and forth from 86 and 88.
First try unplugging the unit for 7 minutes this usually causes the control to reset if it does not reset you may have to replace the control board 88 is a control issue. If you have any further questions message me back. I await your reply Thanks Rick
Aug 18, 2011 | Refrigerators
The digital display is displaying 88:88 and the machine stoppede mid cycle
unplug the washer for at least 5 minuter to reset the computer then plug back in. any power surge can "confuse" the electronics. if you continue to have problems let us know.
Feb 09, 2011 | Haier Washing Machines
Our power went out due to the snow storm, and the display panel shows 88 on each side...how do I reset this...will this cause the fridge temp to go up?
From http://www.samsung.com/us/support/supportMain.do
Your refrigerator is equipped with an onboard diagnostic system. If the diagnostic system detects a fault, it will display a specific line segment on you refrigerators LED display. If your refrigerator is displaying an error code, please note the error code, and reset the refrigerator by unplugging the refrigerator for 30 seconds. When the refrigerator is plugged in, it performs a self diagnostic check of the various sensors and functions. If the error code reappears your refrigerator will require service. Please click the "Create Online Service Request" button below this article to initiate the service process. After a power outage the display panel may start blinking "88 88." If you unplug the unit for 30 seconds then plug it back in the display will return to normal operation after several hours. The power outage/surge can cause a communication error between the circuit boards in the unit. It can take several hours for these boards to stabilize.
If the display does not reset, go to the Samsung Support link above, enter your model number, and follow the prompts to request a service ticket.
Good luck, and if this helps, please rate my answer!
Feb 02, 2011 | Samsung Refrigerators
Maytag Neptune MDE5500AY Electric Dryer Logo
111 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
