Question about Air Conditioning and Heat for Lexus RX330
Yellow button on the 2004 Lexus rx330. It is in the middle of the steering column / speedometer , and it pops up and has an annoying beep. Any idea?
In your owners manual
We don't have info here
Have to use the internet for a manual
if you don't have one
Posted on Nov 25, 2014
My 2004 lexus rx330 makes beeping noise when i turn thr wheel, whats causing the beeping?
Without knowing exactly what the beeping noise is, if it is an electronic beep it could be a signal that your power steering fluid is low. When pressure (the steering wheel turning), is put on the system, if it is clogged or has low fluid it will strain the system and you get more of a squeal but Lexus could have a beeping to notify you The fluid is low. If you check the fluid and it is at the right level than your system needs a flush. It's about $80 at Jiffy Lube
Jan 30, 2015 | Lexus Cars & Trucks
How do I change the middle tail light bulb on a lexus rx330 2004?
Remove the top bezel of the gate. It pops/prys off. Then you will see how to remove the socket(twists out) the remove the bulb/s
Dec 12, 2014 | 2004 Lexus RX 330
How to replace high beam switch in rx330 lexus
You must remove the steering wheel this means you must disarm the steering wheel airbag. To do this disconnect the battery negative cable while working on the car. Remove the **** shell plastic covers on the steering column the screws for them are on the underside they should be cross points, now remove the steering wheel nut and apply the puller you must purchase to the bolts holes and turn the jack screw in until the wheel pops free. After the steering wheel is off remove the clock spring ribbon contact drum under the steering wheel and then the switch just slides up and off once the clamp is released that holds it to the steering tube...
Nov 08, 2012 | 2005 Lexus RX330
I want to replace the hood support on a 2004 lexus rx330. The factory support does not appear to be removable from the mounting ball. Any ideas how to remove the factory support from the factory mounting...
To remove the support cylinder you nee a small flat head screw driver. The metal band at the top of the cylinder can be popped off. Slide the screwdriver up the channel slot to get under the metal band. It can be reused again. TIP: Becareful it does not shoot upwhen you lifter the hood to pull it off frm the ball. Good Luck
Apr 23, 2010 | 2004 Lexus RX 330
2005 Lexus RX330 All warning lights come on while I am driving
Believe it or not, it is the brake switch!!!.
I did not believe it either but our 2005 RX330 had the same problem. Car still was running but all lights came ON. Dealer fixed in a short time and replace the brake switch. OK now.
Mar 20, 2010 | 2004 Lexus RX 330
Where is the fuse box inside a Lexus RX330 '04
he fuse box is in the car on the passenger side under the glove box by your feet. Lay on your back and you will be able to see it. It is about 3" X 2", white with all the fuse info on the cover. Pop the cover and you will be able to read it better. Hard to read on your back.
Sep 21, 2009 | 2004 Lexus RX 330
Lexus RX330 rear hatch open indicator light and buzzer stays on
the switch to detect hatch close is not being pressed down ..check at the striker there is a switch there confirm it is is working by pressing down on it with your finger and watching the light on the instrument panel
Jan 20, 2009 | 2004 Lexus RX 330
Vehicle Parts & Accessories Logo
Top Lexus Vehicle Parts & Accessories Experts
Timllfixit
Colin Stickland
Colin Stickland
Thomas Perkins
Thomas Perkins
Are you a Lexus Vehicle Part and Accessory Expert? Answer questions, earn points and help others
