Question about Shimano Dura-Ace 7900 Di2
I have an early version of the Shimano DI2 electronic shifting gearset and I cant remove the battery. I flip the release and press the release button but the battery won't budge. Must not have lubed
I tried to pry it off but no luck. Should i use a WD40 type product or pull it with pliers?
    Master:
  • 477 Answers
Try wd40 first then try pliers etc
Posted on Nov 12, 2014
I can't get my Shimano Di2 battery to charge. Do I need to replace it? I purchased the bike in 2012 and have never had this problem until now.
Rechargeable batteries have a finite number of recharge cycles. If yours will no longer fully charge, including after you run it all the way down. then it needs to be replaced, assuming your charger is working properly.
May 26, 2017 | Shimano Cycling
Dura Ace di2 front derailleur 10 speed (7970) not shifting correctly. Moving back and forth with clicking sound. How do we fix?
First, is cable tight, it may be that the cable has loosened or stretched. In this case, Put chain on inside spocket, loosen hex head bolt, pull tight, retighten hex head.
It also could be the limit screws have vibrated loose. There are two of them on the top of the derailleur. Make small adjustments in one screw, check to see if it improves shifting or makes it worse. You didn't say whether it was the small or larger spocket. The limit screws control how far in or out the derailleur moves. Read more on Shelton brown .com under derailleur heading
Sep 16, 2014 | Shimano Dura-Ace Di2 7970 Front Derailleur...
Shimano 7970 di2 trouble shooting
Disconnect brake cable at brake. Check operation without any cable resistance. If its OK, remove cable from brake lever end. Check lever operation without resistance. Use a bit of sewing machine or light oil to lubricate lever pivot, cable. If no problem found reinstall in opposite order.
Jun 28, 2014 | Shimano Dura Ace Di2 ST-7970 STI
3rd Di2 install and first 2 worked perfectly. On this bike when on big ring big cassette (23) get pretty good chain rub on front derailuer. Have tried setting tail of derailuer in more than usual and...
Derailleurs are mass-produced and are essentially identical to each other, so unless damaged it's unlikely to be the derailleur. A sticky cable could keep the derailleur from trimming properly. It also can lead you to think it's tight enough when it is not. Otherwise it's hard to diagnose remotely. Derailleur must be both at proper angle and height to shift well, cable both move freely and be at proper "tension."
Di2 Shimano Electronic Intelligent System Installation
Apr 15, 2017 | Shimano Dura-Ace 7900 Di2
Macbook a1181 works for a couple days and then does not want to start again for another couple days. please advise
Your best bet is to reset the System Management Controller;
(I'm not sure if your model has a removable battery or not, so I'm providing both methods)
Resetting the SMC on Mac portables with a battery you can remove
Note: Learn about removing the battery on MacBook and MacBook Pro.
  1. Shut down the computer.
  2. Disconnect the MagSafe power adapter from the computer, if it's connected.
  3. Remove the battery.
  4. Press and hold the power button for 5 seconds.
  5. Release the power button.
  6. Reconnect the battery and MagSafe power adapter.
  7. Press the power button to turn on the computer.
Resetting the SMC on portables with a battery you should not remove on your own
Note: Portable computers that have a battery you should not remove on your own include MacBook Pro (Early 2009) and later, all models of MacBook Air, and MacBook (Late 2009).
  2. Plug in the MagSafe power adapter to a power source, connecting it to the Mac if its not already connected.
  3. On the built-in keyboard, press the (left side) Shift-Control-Option keys and the power button at the same time.
  4. Release all the keys and the power button at the same time.
  5. Press the power button to turn on the computer.
    Note
    : The LED on the MagSafe power adapter may change states or temporarily turn off when you reset the SMC.
...and then reset the Parameter RAM:
  2. Locate the following keys on the keyboard: Command, Option, P, and R. You will need to hold these keys down simultaneously in step 4.
  3. Turn on the computer.
  4. Press and hold the Command-Option-P-R keys. You must press this key combination before the gray screen appears.
  5. Hold the keys down until the computer restarts and you hear the startup sound for the second time.
  6. Release the keys.
Nov 17, 2010 | Apple 13-inch MacBook - Intel 2.0GHz Intel...
Code change for trilogy lock D2700
First find out if you are dealing with a D2700 or the newer enhanced version. Press any 2 buttons and *,if you get a green LED and 6 beeps it is the new version. Old version remove battery and press any button. New version remove battery, press any number for 10 seconds,release, reconnect battery, press and hold the A button within 3 seconds, 6 beeps, release A button. the lock is at default and ready to program. To program new version 12345 A1A new combo A new combo this will set a new master code, if you are only using 1 code to open the lock this should suffice.
Jan 27, 2009 | Trilogy Alarm Lock T2 TRILOGY® Digital...
Shimano Dura-Ace 7900 Di2 Logo
124 people viewed this question
Top Shimano Cycling Experts
Michial Gueffroy
John Egan
John Egan
Eric Hidle
Level 1 Expert
Are you a Shimano Cycling Expert? Answer questions, earn points and help others
