Question about Shimano Dura Ace Di2 RD-7970
How do i remove my di2 external battery for charging when it appears locked in
I flip the release and press the button but cannot remove the battery from it's bracket.
2 Suggested Answers
How to unlocking kyocera wx04k
Leyne: According to Facebook.com, "1. Remove the battery cover on the back of the Kyocera cell phone.
2. Open the flip once the back of the phone has been exposed.
3. Press the "Reset" button with the phone's stylus or a small pointed object.
4. Press the "Backlight" button located on top of the phone while continuing to hold the "Reset" button.
5. Release the "Reset" button after approximately 3 seconds.
6. Release the "Backlight" button when the display screen on your phone appears.
7. Select the "Yes" option by pressing the "Up" button when the "Erase all data?" message appears. You must select the "Yes" option to complete the hard reset."
May 12, 2015 | Kyocera Cell Phones
My daughters my tablet2 by bush has,frozen what do I do
if you can remove the battery start there. is not try to hold the power button for 1min. if that still doesn't work follow the bellow instructions
When Hard Reset is Necessary for Smartphones or Tablets ?
1. Forgotten Pattern Lock on Android Tablets or Smartphones.
2.Too many pattern attempts / Reset user lock.
3. Tablets PC,Smartphones stuck on Gmail account.
4. Android Tablet PC stuck / freeze on Android logo.
5. Tablet Android or Smartphones hang on start-up / Multiple errors generating by OS.
6. Android market having problems or generating errors.
7.Upgrading to new Android version.
Make sure to charge battery upto 60%.
How to Hard Reset Argos CnM TouchPad Android tablet pc ?
  • Make sure the tablet is charged up to 60%
  • Turn off the tablet completely .
  • Press Volume + button , while holding Volume + button , plug in charger.
  • Release the volume + button.
  • Press Volume + again and press Power button to boot the CnM Tablet.
  • When Android logo appear , release the volume + button.
  • Press Power Button again and press volume + button , Recovery Menu will be appear .
  • Press the volume down and select "wipe data/factory reset"
  • Power button to select it
  • You will see "Yes - delete all user data"
  • Select "Yes"press "Power" button to select it
  • Formating will start. it will delete all user data .
  • Few seconds later, you should see the recovery menu again. Select reboot.
  • It will take approximately 2 to 3 minutes to take you back to its factory (out-of-the-box) state .
you are done.
This Hard Reset method will work with all models of CnM touchpad tablets.
Jul 25, 2014 | Audio Players & Recorders
Forgot password unlock phone
You can remove the lock screen but your storage will be totally erased. This feature is enabled only for security purpose.
Step 1
Flip your HTC Evo over, and pull the rear cover off of the device. Lift the battery out of its recess, and wait for about five seconds. Return the battery to the HTC Evo, and replace the battery cover.
Step 2
Hold down the "Volume Down" button on the Evo's left edge. Press and release the "Power" button. Instead of the standard power-up and lock screen, a new menu will appear on the LCD.
Step 3
Release the "Volume Down" button after the menu appears on the screen, then tap the "Volume Down" button twice to highlight the "Clear Storage" option.
Step 4
Press the "Power" button to choose "Clear Storage." Press the "Volume Up" button to confirm that you want to erase everything on the Evo. After a few moments, the Evo will reset itself and the screen lock will be gone.
Nov 12, 2013 | HTC EVO 4G Sprint - /
I forgoy my input phone lock cod on my phone tw1 duo how to reset
Hello Dear Friend:::
1.Check the device's battery level for at least two bars of strength.
2.If the battery level is low, charge the battery.
3.If the issue is not resolved, remove the back cover.
4.Remove the battery.
5.Wait 10 seconds.
6.Press and hold the W key.
7.While pressing down the W key, re-insert the battery.
•The device restarts and after approximately 15 seconds, the 'Recovery' screen appears
•Release the power button but *continue holding the home button*, for another 30 seconds.
Step
Thanks
Jan 11, 2013 | Cell Phones
How to charge my channellock 4v drill. Can't find the instructions book
Traditionally the charge port is on the heel of the tool, it will be no larger than a screw head. It will have a small post terminal in the middle of it. If it does not have such a port, look for a soft polymeric button, it should flip out. If not, see if the battery can be released, the grayish buttons on the bottom of the handle may be what you need to press to release the battery for charging.
Feb 14, 2012 | Channellock Channel Lock 4v Dual Driver
My backflip is locked and i forgot my blur info , how do I reset/unlock my phone ?
  1. Power off the phone, press and hold camera button ( do not release), press power button until phone turns on.Release power button while holding camera button down.
  2. Release the camera button when prompted (following the Batwings boot screen).
  3. Press the volume down button and wait for 15 seconds for a "triangle !" to appear on the screen. ( message "volume up key pressed " will appear )
  4. With flip closed, tap bottom right corner of darkened display (just above back button).
  5. Select "wipe data / factory reset" on screen
  6. Press "Ok". Wait for "data wipe complete" message to appear
  7. Press "reboot system now"
  8. Press "Ok" . Phone will reboot and complete master reset function
Notes:
Dec 05, 2010 | Motorola Mobility Backflip Smartphone
Flip Mino HD will not boot, charge or reset
Call Flip support, problems are happening to too many people, contact Flip support, if they cannot help, contact MacWorld or other online reviewers and let them know.
Jul 06, 2009 | Pure Digital Flip Mino Digital Camera
Flip video won't charge
If you look on the bottom of the camera there is a button that slides from a locked to an unlocked position. Slide it to unlocked and then slide down the back of the camera (the side with the lens) there is a removeable rechargeable battery pack. Remove it for a moment and then put it back in. Try plugging back into the USB port. This should work.
Jan 09, 2009 | Pure Digital Flip Video Ultra Camcorder
Restarting
this should do the trick...press star, call button(the green one), three, and power button all together while powering up your phone..press them until formatting comes out then you release them..note: don't release buttons until formatting does not appear....try and try until you succeed
Jan 22, 2008 | Nokia 3230
Shimano Dura Ace Di2 RD-7970 Logo
Top Shimano Cycling Experts
John Egan
John Egan
Eric Hidle
Level 1 Expert
Mike
Are you a Shimano Cycling Expert? Answer questions, earn points and help others
