Question about Hawk Front Quiet Slot Brake Rotors & Lts Brake Pads, 08-08 Honda Ex-l
How do I install rear brake pads on a 2007 Mercedes benz s550
    Master:
  • 478 Answers
Jack the rear end up, put it on axle stands, remove the wheels, remove the brake calipers, remove the old brake pads, replacement is a reversal of the previous info but be sure to add a smear of copper grease to the back of the new pads before installation to stop brake squeal
Posted on Nov 12, 2014
a 6ya Mechanic can help you resolve that issue over the phone in a minute or two.
click here to Talk to a Mechanic (only for users in the US for now) and get all the help you need.
2007 mercedes s550 passenger side tail light wires diagram . The wires were cut and the harness was taken
Right side turn/brake light wire is green. Running light wire is always brown on all four cornets. Left/drivers side turn/brake is always yellow. This is pretty much a universal standard.
Jun 25, 2017 | Mercedes-Benz S-Class Cars & Trucks
How do I deactivate the sbc control on a 2007 s550 Mercedes benz to install rear brake pads
Hello, No need to deactivate anything on your S-Class, Just compress the Caliper pistons, install the new pads and sensors and you are all set to go.
Nov 13, 2014 | Mercedes-Benz S-Class Cars & Trucks
How do you install rear brake pads and rotors on 2007 s550 Mercedes benz
hi,first off all open bonnet and undo cap on brake master cylinder reservare,(put a nice absorbant cloth round the reservare just to be shore not to get the brake flued on eney paint work,as it will damidge it),then jack car up and take road wheele off,(make shore hand brake is off and car has some wedge shape wood under front wheele so that car cant move eneywhere),the calipper that holds the brack pads in place has two bolts at the back off the calipper,if there is wires coming out of the brake pads undo at connectors,(these are brake sensors to worn you when the brake pads are worn out,not all mercedes have them),right you need to fist get a screwdriver and put it between the pad and disc and push gently so the piston thats in the calipper(on the inside of the calipper)moves in so that the pads can now move back and forth a little bit in the calipper,now you can undo the two bolts on the back of the calipper the calipper will come off the car,now push the pads apart so that the piston is pushed right into the calipper,(you can do this with a g-clamp or grips then put a spanner in between the brake pads to stop the piston from moving back out)now you can carefuly put the calipper aside being carefull not to stretch the brake hose, now the brake disc (rotor)if you look at the disc where the studs are you will see a small screw or allan-key fitting undo that and the disc will come off(some times you might have to just give it a little bit of help by hitting the disc gently with a hammer),
then put it back in reverce of taking apart(dont forget when you have put it back together press the brake peddle a couple of times then top up the brake fluid in the reservare in between the recarmended lines on the reservare.
Hope this helps,good luck,its quite a strate forwould job.
(sorry about spelling.
Nov 12, 2014 | 2007 Mercedes-Benz S-Class
How do i deactivate the sbc control on a 2007 s550 mercedes benz
as far as i am aware you will have to take to a dealer or some where that has the equipment to turn it off its not really a diy job if any light come on there is a problem with that system abs srs lights all need resetting
Nov 12, 2014 | 2007 Mercedes-Benz S550 Sedan
Malfunction light on wit arrow pointed up 07 s550 Mercedes Benz
check your fuses.. its the orange 40w fuse in the front of the fusebox.... if that doesn't work then its your air pump..
Aug 10, 2014 | Mercedes-Benz 2007 S550
Where is the bleeder valve for 2007 s550
You need to remove the front wheels and the bleed valves for the front brakes is on the top of the brake caliper at the back of the wheel.
If you have not done brake bleeding before i recommend getting a garage to do it.
Mar 07, 2012 | 2007 Mercedes-Benz S550 Sedan
How to replace a taillight bulb on a S550 Mercedes?
how to change tail lights on 2007 Mercedes benz s550
Nov 23, 2011 | 2007 Mercedes-Benz S550 Sedan
Fuse location on Mercedes Sprinter 312D 1999
Mercedes Benz S550 problem with taking park and wont turn on
Apr 26, 2010 | 2007 Mercedes-Benz S550 Sedan
What is esp on a mercedes 2007 s550
Could it be, your vehicle has Psychic intuition? Just kidding... :-)
Well, actually...it's not far from it !!!
ESP was co-developed between Daimler-Benz & Bosch, and was later adopted by Mercedes (across their range) from 1999.
As you know, most vehicles now have ABS braking...and some now have a form of Traction control.
Well, ESP exceeds the safety boundaries:
It's an intuitive system, connected to your vehicle's ABS, steering, dampers and Drive-train management.
ESP has saved countless lives since its implementation by reducing the risk of skidding on cornering and by maintaining the vehicle’s directional stability – even in critical conditions.
How exactly does it work?
1) This is achieved by selectively braking individual wheels, thus counteracting the tendency to skid in critical handling situations and allowing the driver to maintain control of the vehicle.
2) Oversteer is corrected by applying brake to the front outer wheel, understeer by applying brake to the rear inner wheel. Engine power can also be limited in some applications
3) The system can measure steering angles, lateral forces, and can compensate the damper ride height (optional).
Hope this helps....
** If this has helped you, please rate this solution **
Nov 13, 2009 | 2007 Mercedes-Benz S550 Sedan
Hawk Front Quiet Slot Brake Rotors & Lts Brake Pads, 08-08 Honda Ex-l Logo
107 people viewed this question
Top Pilot Vehicle Parts & Accessories Experts
David Payne
David Payne
Ted Maxwell
Paul Gustar
Are you a Pilot Vehicle Part and Accessory Expert? Answer questions, earn points and help others
