Question about Canon Pixma MX922
How do I get printer to use paper from lower cassette. Error message states no paper in upper cassette
Paper in lower cassette. Error message estates no paper in upper cassette
    Master:
  • 477 Answers
You have to change the printer settings on the PC
Posted on Nov 12, 2014
Testimonial: "I cannot find an area on printer settings for cassette to be used. All that is found is paper size. I am using A4 but still does not find lower cassette. I have an all in one iMac"
SOURCE: CANON MF4140 'LOAD CORRECT PAPER CASSETTE : LTR'
I had the same cr@p of the problem yesterday. The problem was not in the paper. You have to do 2 simple things, from which one will solve the problem.
first, download the latest drivers and install them.
And the more important thing, the problem occurred due to incorrect paper format. Solution is very simple. Open MS word or something similar, file->print.. and before you print open Properties menu. There for the Output Size will be selected "Match Page Size". you don't want that (i don't know why it doesn't work), but the solution is manually select A4, or whatever your page size is.
Posted on Dec 27, 2008
I had the same cr@p of the problem yesterday. The problem was not inthe paper. You have to do 2 simple things, from which one will solvethe problem.
And the more important thing, the problem occurred due to incorrectpaper format. Solution is very simple. Open MS word or somethingsimilar, file->print.. and before you print open Properties menu.There for the Output Size will be selected "Match Page Size". you don'twant that (i don't know why it doesn't work), but the solution ismanually select A4, or whatever your page size is.
And there it is... printer starts throwing pages out like crazy :)))
SOURCE: Error - Canon MP830
this Model has a paper tray on the bottom. Put some paper in the bottom tray and then voila..I had the same issue and i looked and the tray was empty..put some paper in..works just fine
Posted on Feb 03, 2009
thbestofme
  • 64 Answers
SOURCE: printer wont feed paper through to print on
there are a lot of steps that u need to follow.. I tried to get the detailed link but it didnt seem to work properly.. so try this link below.. http://tinyurl.com/2kdp28 once on this page.. go to support & service.. and search for FEED PAPER... and select the second answer there.. and follow steps there.. let me know if this was helpful to u.. regards, guru
Posted on May 05, 2010
jayatithapa
  • 83 Answers
SOURCE: printer not taking paper from cassette
If this printer have control pannel then open menu then finde out factory stting ,set default it and save it other wise remove printer s/w and install again
Posted on Jul 26, 2010
I Have an EPSON Stylus TX700W Printer , & am having problems getting it to feed paper. Have tried all the Paper Jam solving problems to no avail. Printer just keeps saying "The Paper Cassette is...
This can also be caused when the upper cassette tray (for small paper stock / photo paper) becomes detached from the lower tray. There is a gear attached to the lower paper tray which handles movement of the upper paper tray. Make sure that moving this gear causes the upper paper tray to move. If it doesn't, then you need to snap the upper paper try on a little better.
Jul 10, 2011 | Office Equipment & Supplies
When i switch on my photocopier tohiba 2860, it asks for service and gives an error code 08221-918100. what could be the problem?
Hi tkasirye,
Welcome to Fixya.
You may need to check again the error code. According to the manufacturer's checklist for error codes, only the following are documented;
  1. Error Codes - Toshiba 2860
  1. "E01" Paper jam inside machine. "E02" Paper jam near the fuser. "E03" Paper jammed inside machine when power supply is switched on. "E04" Front cover open while copying. "E05" Paper jam near the aligning roller "E08" Paper jam at stacking area in the ADU "E11" Paper feeding jam at the ADU "E12" Manual feeding jam "E13" Paper jam from cassette 1 "E14" Paper jam from cassette 2 "E15" Paper jam from cassette 3 "E16" Paper jam from cassette 4 "E17" Paper jam from cassette 5 "E19" Paper jam from the LCF "E21" Paper jam in transport route 1 (LCF) "E22" Paper jam in transport route 2 (COPIER) "E23" Paper jam in transport route 3 (ALIGNING) "E25" Paper jam in transport route 4 (PFP) "E71" Original feed jam in ADF "E72" Original transporting jam in ADF "E73" Original exiting jam in ADF "E75" 2nd original feeding jam "E81" Paper jam before sorter "E82" Paper jam in sorter "E83" Sorter early arrival jam "E84" Paper in sorter when power is turned on "E85" Joint open jam while copying "E88" Paper jam outside the sorter bin "C01" Abnormal operation of the copier main motor "C04" Abnormal operation of the PFP main motor "C05" Abnormal operation of the ADU main motor "C11" Abnormal operation of the ADU side motor "C12" Abnormal operation of the ADU end motor "C13" Abnormal operation of the upper cassette tray "C14" Abnormal operation of the lower cassette tray "C15" Abnormal operation of the PFP upper cassette tray "C16" Abnormal operation of the PFP middle cassette tray "C17" Abnormal operation of the PFP lower cassette tray "C18" Abnormal operation of the LCF tray "C21" Optics carriage initialize error "C22" Lens initialize error "C23" Mirror initialize error "C26" Faulty exposure lamp "C33" Easy set-up is failed "C35" Developer material exists at the transfer separation adjustment "C41" Faulty thermistor or heater "C43" Faulty thermistor "C44" Faulty heater "C45" Sub thermistor is open
Shoulg you not find any of these mentioned error codes, I suggest you contact the tech support especially if the machine is still under warranty.
Hope this helps.
Takasashi
Jul 05, 2011 | Toshiba Office Equipment & Supplies
Trying to print - got Warning message THe paper cassette is no set correctly. Check for any objects in the cassett of block the cassett path and insert correctly
Jun 26, 2011 | Epson Stylus Photo 810 InkJet Printer
Paper cassette is not seated correctly. check for paper or objects blocking the cassette path. reinsert the cassette and press Start. keep getting this message. started after printing and installing...
I had this same problem and tried everything (I thought) to fix it. Then I saw the solution at:
http://www.retrevo.com/c/sohohelp/blogs/show/6633/I-just-had-my-espon-artisan-800-replaced-and-the-refurb-keeps-saying-that-the-paper-cassette-is-not-seated-correctly#replyForm
Basically there is a plastic pin that tends to break off and stays in the area where the cassette is loaded. It takes up just enough space to keep the cassette from being pushed in all the way. The solution is to turn the printer off, unplug it, then lift up the printer so the broken pin falls out. Once it comes out, the printer will work fine again.
May 12, 2011 | Epson Artisan 800 All-In-One InkJet...
Is there a lever or switch that tells the printer to grab from the front tray?
On the machine panel, the "feeder" button selects paper source and media type to be used. This must match the media/paper size selected in your software.
MP - multi-purpose tray
T1 - the upper paper cassette
T2 - the optional lower paper cassette
Dec 03, 2009 | Brother HL 2060 Laser Printer
Canon MP600 all-in-one printer.Out of paper?
Try this:
Go into the driver toolbox under printing preferences and select auto
continuous feed from the paper source dropdown box.
Both trays should be of the same size paper and type for this to work.
Jul 10, 2009 | Canon Pixma MP500 All-In-One InkJet...
Error 13-jam paper HP Laser 4+
HP LaserJet 4, 4m, 4 Plus and 4m Plus Series Printers - False Error Message 13 PAPER JAM ISSUE: After clearing all jammed paper from the HP LaserJet 4, 4m, 4 Plus, or 4m Plus series printer, the display still reads 13 Paper Jam . Even after cycling the power off and then back on, the error remains. SOLUTION: Open the rear door of the printer. There is a paper sensor near the upper right hand corner of the fusing assembly (just below the right edge of the long yellow warning sticker on the fuser) that can cause paper jam error messages even when there is no jammed paper in the printer. Toggle the thin black plastic lever up and down to make sure it is not stuck or sticky. The lever should be in the down position before closing the back of the printer. If the lever is stuck or missing, the printer will generate a false paper jam message. Hope it will help you !
Apr 02, 2008 | HP LaserJet 4 plus Printer
Brother Laser Printer HL 1440
tray this
The procedure for the factory inspection mode is as follows.
(1) Turn off the printer power switch, open the front cover, and remove the drum unit.
(2) Turn on the printer power switch while holding down the control panel button. The Drum
LED comes ON.
(3) Lightly press the panel button again.
(4) Check that all the LEDs except the Ready LED are OFF.
✒ If the toner sensor is ON, the Drum LED stays ON (error).
✒ If the front registration sensor is ON, the Alarm LED stays ON (error).
✒ If the upper paper cassette sensor is ON, the Data LED stays ON. (error) (HL-1250
only)
NOTE:
The lower paper cassette solenoid is turned ON/OFF even if the panel button is not pressed.
(5) Check the rear registration sensor.
✒ If the rear registration sensor is stuck backwards, the Ready LED stays OFF. (error)
✒ If the rear registration sensor is moved back and forth, the Ready LED comes ON at
any time. (error)
(6) Check that only the Data LED comes ON while pressing the panel button.
✒ If the paper eject sensor is ON, the Drum LED stays ON. (error)
✒ If the lower paper cassette registration sensor is ON, the Ready LED stays ON. (error)
If the registration sensor is ON, the lower paper cassette solenoid is turned ON, and
the Ready LED also stays ON. (HL-1250 only)
NOTE:
(7) Install the drum unit.
✒ Check that the Drum LED goes ON and the Ready LED goes OFF.
(8) Close the front cover.
(9) Continue to press the control panel button.
✒ Check that the Data LED stays OFF.
(10) Release the panel button.
(11) If all the sensors except the toner sensor are correct, the printer goes back to the Ready
status.
If any error is detected, the printer stays in the inspection mode.
Apr 01, 2008 | Brother HL 1440 Laser Printer
I can neither send or receive faxes
hi 003 - Recording paper jammed when feeding from the 3rd cassette. Remove the jammed paper. (1) Open the Printer Cover. (2) Remove the jammed paper. (3) Slide out the Paper Cassette. (4) Remove the jammed or wrinkled paper and reload the recording paper into the paper cassette. Caution: Make sure that the paper is set under the clips of the Paper Cassette. You can load about 500 sheets with standard weight paper (20 lb. or 75 g/m2). good luck
Feb 23, 2006 | Panasonic Panafax UF-885 Plain Paper Laser...
Canon Pixma MX922 Logo
358 people viewed this question
old marine
old marine
