Question about Sony Bravia KDL-46V4100 46 in. LCD HDTV
My tv light keeps blinking and the input selection keep changing
    Top Expert:
  • Sony Master
  • 74,251 Answers
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Blinking codes details to many popular brand TVs are given. Surf the site with patience. If blinks continue without any pause, the main board is faulty.
Posted on Nov 12, 2014
I keep getting "no input signal". I have a small 32" Visio as a spare and it works fine using same cables, box, etc
try selecting the input source on your TV to the one you are using, sometimes auto-detect doesn't seem to work properly. This can be done by the remote control, or the buttons on top of your set.
You might also try changing the physical input socket, eg to the RF in, SCART, HDMI etc (you will probably need different cables for this), but if your set is selecting another source you will still get this message.
Also you might try using a different input device to check your TV, although this is unlikely to have any effect because the input devive plays on your second set.
May 19, 2016 | Panasonic TC-P55VT30
Wheni push input, i get the options but no arrow i push will move down to option to play vhs
not enough info , if your trying to change the tv input , make sure you select tv on the universal remote first , you either need to keep pushing input til it moves down to your desired input , or use the arrow key to move it down to the input. some require you to hit enter or ok to select , others just wait a second , it should change. if your getting the options menu when your hitting input , then the remote is not compatible with your TV / VHS / DVD...
If you get the input to change and your successful , make sure you hit VHS in order to call a command , if its still in tv mode , your only going backwards , make sure whatever your trying to control , the remote is selected to that device ... Good Luck ..
The Cable Guy .... hope that helps !!!
Mar 12, 2015 | RCA RCR314WR Universal Remote Control For...
Channel input displays keeps blinking
this is a faulty Main controller Board
part number : 715T2300-3
hope 2 help
www.bostonrecycling.net
LCD PARTS / PLASMA PARTS / LAPTOPS PARTS
Jun 25, 2012 | Dynex DX-LCD32-09 LCD TV
TV power comes on but then I just get a blinking green light. No picture or sound.
Make sure your cable input is in properly. The TV might be going into a sleep mode if it not getting an input signal
Apr 03, 2012 | Philips Televison & Video
After selection an input option the input menu stays up until you push "exit". Then it reverts to the tv input option canceling out any other menu selection. If you then try another route to get...
what has happened is there is a controller for menus and the selection of channel's av hdmi etcafter a hwile with some tvs they start to go on the blink it coud be worse i have had people with tvs that wont change channel keep jumping back and people without a signal atall the only thing you can do if it is unbearable is get the unit replaced or with some tvs a simple firmware update does the job as it resets everything but with most tvs the unit will need replaced it will cost no more than 100 dollars at a good tv repair store
Feb 26, 2011 | Vizio VX37L Television
I have a rca universal remote. how do i program it to my phillips tv?
turn tv on
on the remote, press tv and hold
input the corresponding number code beside philips (tv)
keep entering codes until the light on the remote is blinking
good to go
Jan 27, 2011 | RCA Televison & Video
No picture, green light keeps blinking, hear fan go on then off, blinking light changes to red
Count the blinks between the pause, Let me know or call a sony service center if your a novice at tv repair
Apr 24, 2009 | Sony KP-57WS500 57" Rear Projection...
HDMI connection
You should have an Input selection on your remote, keep pressing it until HDMI is high-lighted and that should be it. The other method is going into the menu under input and select HDMI. Let me know?
Mar 14, 2009 | Televison & Video
Mitsubishi WD-62525 timer light keeps flashing after lamp replace
There is a tiny reset button to the left of the timer light. Press with a pin or something small, wait 60 seconds. Viola!
Dec 29, 2008 | Mitsubishi WD-62525 62" Rear Projection...
Tv cuts off and green light flashes
the tv will try to reboot a few times. just let i try and eventually it will start blinking red. if you could count the red blinks then i can further assist you.
Sep 23, 2007 | Sony Grand WEGA KDF-60XS955 60" Rear...
Sony Bravia KDL-46V4100 46 in. LCD HDTV Logo
55 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
