Question about Refrigerators
The water inside is not working. I have changed the filter, but it still does not work. What else should I do?
Model # 106.74252402
  • 603 Answers
Your water line is clogged or kinked. GOOD LUCK FRCICEND.
Posted on Nov 12, 2014
3 Suggested Answers
aborcass
  • 2651 Answers
SOURCE: Amana French door Refridge-water dispence inside the door not working
pull out crisper and deli shelf thers a tank behind them its probably froazen, hit it fora few minutes especally around top neck portion with a hair dryer, common issue
Posted on Feb 23, 2008
  • 24 Answers
SOURCE: I have a maytag refrigerator
The only time mine didn't work, and I have this exact model, is when I had it loaded with stuff and the air would not circulate well inside. I think the water line running through the refrigerator portion froze. Try to let the inside warm up a few degrees (put a thermometer in there and see what the temp is near the back). If it's below 32 degrees, you may have found your solution.
Posted on Nov 08, 2009
Have changed water filter but water dispenser not working
Does it still make ice cubes??? If yes then its not the filter. It may be one of these problems. !/2 the water inlet valve may be defective. 1/2 is for the icemaker the other 1/2 is for the water dispenser. Some companies have had problems with the water line inside the freezer door actually freezing up. Is some cases a heater kit is required to be installed in the door dispenser area. With out a brand/model number I can't be more exact.
Apr 12, 2015 | Refrigerators
It making a noise and the ice maker stop working
Thank you for your inquiry, Joann siefert!
I see that your Frigidaire refrigerator is making noises and no longer producing ice. Have you attempted to replace your water filter? If your filter is bad that could cause ice to stop producing. I would recommend changing your water filter to see if that would help correct your issue. The noise could be a normal operating noise. If you have your manual you can look inside for normal operating noises. If you need your manual could you please provide me with your model number? You can locate the serial tag (which lists your model number) on the inside wall of your refrigerator. With that information I can further assist you. -Matt
Jan 23, 2015 | Frigidaire Refrigerators
Water dispenser does not work
Good Afternoon Friend,
I understand that the water dispenser on your Frigidaire refrigerator does not work. First, I suggest changing your water filter, making sure that the filter is flush with the filter housing. Secondly, I suggest resetting your appliance, by either unplugging it or shutting the power off at your home's circuit breaker, for 3-5 minutes. Restore power and try to get water out of the dispenser. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your refrigerator status has changed successfully. If further troubleshooting is required, please leave me the model number of your refrigerator. Typically you can find this number inside the refrigerator on the right hand wall. Hope this is helpful.
-Best Regards-
WP
May 26, 2014 | Frigidaire 22.6 Cu. Ft. Side-by-Side...
Frigidaire Side-By-Side not dispensing water and possibly ice
It is possible the water line inside the refer is frozen, you will be able to see a resevoire or loop behind the bottom drawers that is where it could be frozen
Mar 24, 2014 | Frigidaire FRS6HR35K Side by Side...
Hi, I have a thermoplastic sand filter t450 model. Every time I leave it in filter mode, water from the pool seems to drain out rather than filter water from pool. When I leave it in backwash mode,...
The "spider"gasket in the backwash valve needs to be replaced. It is not hard to do. If you undo the 6 bolts on top of the valve lid the "key assembly" will lift straight out. Inside the valve body you will see the gasket.
Aug 06, 2013 | Pool & Spa
How to change the water filer on a rf4267hars 25.5 ft
You must shut the water valve to change the water filter. If you don't havewater valve near the fridge, shut the main water valve for few minutes. If you turn the water filter to change without shutting the water valve, lots of water flooring the fridge and you do lots of work to remove the water inside the fridge. Shut the water valve, and then replace the filter. Then turn the water valve.
Apr 02, 2013 | Samsung RF4267HARS 25.5 Cu. Ft. French...
Water dispenser stopped working then the tce maker
The fridge isnt getting water check supply line and filter.
Oct 04, 2009 | Kenmore Refrigerators
I have a maytag refrigerator model number mfd2560heq and the inside water spout is not working. I have changed the water filter-that has not helped the problem
Jul 06, 2008 | Maytag Refrigerators
Jan 14, 2008 | Frigidaire FRS3R5EMB Side by Side...
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
