Question about Health & Beauty
Hi, on my JB5538 Wristech, even with brand new batteries, the unit never seems to inflate ! It developed this problem about 3 months ago out of the blue. Keep getting Err message. How do I fix it ? Th
It worked fine for about a year. It stopped inflating about three months ago, and keeps showing Err message, even when I use brand new batteries.
    Master:
  • 477 Answers
Either the compressor unit seals are damaged or you have a hole in the inflatable section either way it is not an easy fix and as they have come down in price dramatically over the past year i would suggest buying a new model & chucking this one away
Posted on Nov 12, 2014
evwood
  • 50 Answers
SOURCE: I have a mabis 04-203-001
You must inflate far enough to stop blood flow, or the machine can not sense the systalic pressure. I suggest that you have your blood pressure checked. It looks like it my be HIGH!
Posted on Feb 06, 2009
Max J
  • 22 Answers
SOURCE: Starts to inflate then stops and get
Wrist BP monitors never give you correct BP, especially Systolic BP.
Posted on Sep 06, 2009
SEGlover
SOURCE: Omron hem-704C blood pressure monitor show down
If your HEM 704C fell hard, it is probably the pressure transducer that is faulty, broken. To my experience it is cheaper to buy a new one then to have it repaired by a technician
Posted on Jan 19, 2010
Testimonial: "Sound advice."
SOURCE: Does not inflate, even after NEW batteries and reset of data.
i dont have my paper work to my cuff,how can i find another so i can fix my problem. s.cantu
Posted on Jan 22, 2010
fjmurdock
  • 82 Answers
SOURCE: I keep getting an error code E83
How old is the cuff? If it has written on it "single use" and you've been using it a while you may have microleaks which means you need a new cuff. Also, check the hose for holes (usually found where the hose splits and connects to the cuff). Last, check the Dinamap to hose connector are the black orings still on the connecting posts?
Critikon/Ge utilizes the oscillitory method for determining NIBP. In other words, it pressurizes the cuff, stabilizes, decreases pressure slightly, stabilizes, etc. so a leak in the cuff or hose won't allow the pressure to stabilize resulting in an E83 error.
Posted on Dec 31, 2010
Ryobi will not start
The saw you're asking about is battery powered, not gas. If this is the actual model you have, I don't know where you could even put the gas. Have you charged the battery?
Aug 05, 2014 | Ryobi Brand New... 18v Cordless...
Resolving err message
http://manuals.harborfreight.com/manuals/67000-67999/67212.pdf
Jul 24, 2013 | Jobar Wristech Blood Pressure Monitor...
Laptop sometimes switches off when moved.
Sounds like a loose connection where the laptop opens and closes hinge there are wires that run from the main screen to the main board. If you know how to take the unit apart it maybe a cheap fix if not then a new laptop maybe the way to go the prices have really dropped from 4 years ago
Jan 12, 2013 | HP Hewlett Packard Compaq 6720s Laptop...
I got a wristech jb5538,i don;t have a manuel,can;t find 1 online.i need to know how to switch between kpa and mmhg
i got a wristech jb5538,i don;t have a manuel,can;t find 1 online.i need to know how to switch between kpa and mmhg.
the solution is when the unit is off, press and hold the left (<) button
until you see a kpa or mmhg in the display.
release then press and hold the same (<) button to choose between
kpa and mmhg .
press the start stop button to start measuring.
I also requested a manual from
info@jobar.com they sent me one.
Aug 10, 2011 | Asseenontvguys Wristech Blood Pressure...
Digital wrist model # SR303S, shows error 3, has new batteries
Possible explanations and work-arounds based on various blood pressure monitors..net is if it has worked religiously like mine had and this error comes up, and the simple fixes below do not work, there is something internally wrong with the unit..there does not seem to be any customer reset or obvious fixes..contact the manufacturer for service..
Error Description Potential cause and remedy
«Err 3» No pressure in the cuff
An adequate pressure cannot be generated in the cuff. A leak
may have occurred. Replace the batteries if necessary. Repeat the
measurement.
Error Codes
Err 0 No pulse is detected
Err 1 Inflation rate is too low
Err 2 Systolic reading unattainable
Err 3 Cuff pressure is too high
Err 4 Diastolic pressure is outside of operation range
Err 5 Cuff deflated too fast
Err 6 Cuff deflated too slow
Err 7 Systolic pressure is outside of operation range
Err 8 Overall pressure is outside of operation range
Err 9 Cuff is unable to inflate to the necessary pressure level
Error No. Possible cause(s)
Err 1 No pulse has been detected. Cuff may be positioned incorrectly.
Err 2 The arm was moved during the measurement.
Err 3 Inflation of the cuff took too long. The cuff is not positioned correctly.
Jan 04, 2011 | Samsung Health & Beauty
Sony erricson w705, wont charge the battery, it comes up with a message saying it cant charge the battery please put a sony erricson battery in, but it is a sony erricson battery and when the battery was...
my phone is the same model and did this but when i charged it, after about an hour it would come up with 'charging error stop ' and when i unplugged it, it hadn't even charged at all. and then the other day it just wouldnt charge, i plugged it in, it said it was charging but it wasnt. in the end, it worked by keeping the phone switched off and charging it while i was turned off. so try that, if not then i really dont know sorry
Oct 08, 2009 | Sony Ericsson Walkman W705 Cell Phone
I shot a wedding and got the ERR message 3
Take your manual reset a little further...remove the card and battery...press all the buttons...leave the camera alone for at least 20 minutes...insert the card and then the battery...turn it on. See if that works.
Oct 08, 2009 | Nikon DSLR D90 Digital Camera
Health & Beauty Logo
430 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
