Question about Yamaha RX-V659 Receiver
How can i locate the fuse because my Yamaha RX-V659 won't power on ?
Hi it was working one day and the next day it won't start, it won't power on at all. I appreciate your help, i think to check the fuse is a good way to begin.
    Problem Solver:
  • 13 Answers
If you open the unit up you will void any warranty including extended warranty but if the unit is out of warranty you can open it up and where the power cord enters the unit you will see glass the glass fuse or fuses, you should be able to look at the fuse and see if the element is intact and you can always check it with a meter, if it is the fuse make sure to only replace it with the same fuse and you want to find out what caused the fuse to blow so check all of your speaker wires and makes sure nothing has crossed and it could have also been a power surge so if you don't have a good surge suppressor that provides Clean Power definitely invest in one, I like the ones made by Panamax and Monster power, both companies make either strips or component ones that you can place on the shelf with your gear and the ones that have a convenience outlet on the front are great because you never know when you need temporary power for a cam etc and this why you don't have to go digging for an outlet that is unprotected. Good luck...
Posted on Nov 12, 2014
How can i locate the fuse because my AV receiver no longer powers on ?
Have you checked the wall outlet first? Then make sure the cable is firmed plugged into the receiver.
Nov 12, 2014 | Yamaha RX-V659 Receiver
I tried hooking up an old polk sub to my yamaha rx-v659 av receiver. smelled wires burning smell. before i could unplug it, receiver shut down. now it will power up for about 5 seconds and shut off. manual...
If a fuse was blown, it likely would have no power. However if the power board has overheated, the capacitors may have swelled up and burnt out and will only allow it to power on for a few seconds, then shut down. The capacitors can look swelled up or burnt or have burn marks on the power circuit board. You can test them with a continuity meter. Each component has a printed number of it's voltage and ohm resistance so you can test them.
Jul 26, 2010 | Yamaha RX-V661 Receiver
Hope it hasn't been fried but unit is not powering up via remote or unit power-on buttons. Have tried different power socket.
Try checking the internal fuse(s). Then check the on/off switch. The other thing to consider is the transformer.
Mar 05, 2010 | Yamaha RX-V659 Receiver
Connect Airport Express to Yamaha RX- V659
Since you're using a standard mini jack to double RCA cable, it's safe to assume you'll be sending line level signal into your reciever, so i think any of these audio inputs will do: AUX, CD, DVD, MD, TV.
Also try the inputs on the front of the unit (i guess they are meant to be used with a video camera or similar but they are designed for line level signals so it should be ok if you decide to use them).
Anyway, keep the source signal at a moderate
level when you test any of the inputs and raise it to a suitable level after you're sure it is coming thru well.
Normally, the AUX input is suitable for any AUXilliary signal source that puts out a line level signal, but if it is already being used, you may use other free inputs.
If you use TAPE or PHONO inputs, you should keep the signal level from the source a bit lower since these inputs will amplify the signal a bit more (especially the phono input which works with signals that are lower in level than the line signal).
I hope this helps.
Regards
3rq8 (Triarcuate)
Sep 06, 2009 | Yamaha RX-V659 Receiver
Is rx-v659 compatible with new ipod dock YDS-11
Both docks will work with your receiver.
Dank
Jan 11, 2009 | Yamaha RX-V659 Receiver
How do you connect wireless headphones to back of receiver?
use the front pre-outs located immediately over the red "right" A&B speaker connectors in the rear of this unit. connect with a high quality stereo  gold plated rca cable.
Jan 08, 2009 | Yamaha RX-V659 Receiver
Sync clock with yamaha RX-V659
Hi eventwave
Are you using the 48khz or 44.1 for you spdif output. check that you have the output correctly formatted or it will not sync correctly. You should not need to have clocks synced to get spdif to work.
I am more than happy to answer any other questions you may have about it, please get back to me here, or use the ASK function to go straight to me :) If you are still unsure, have problems, or we need to look at the situation more deeply, then before you give a rating for this advice, hit the ASK button Thanks for using FixYa, If you consider the advice I have given you as sound, a FixYa rating is a great reward for my efforts to help you. Cheers.
regards robotek
Jul 05, 2008 | Yamaha RX-V659 Receiver
Receiver turns on and clicks off when volume is raised over 8 or 9 on the dial
I had the same problem with my Yamaha amp. It turned out to be a shorting speaker wire. When I resoldered the speaker wall outlet connection it worked fine!
Feb 27, 2008 | Yamaha RX-V659 Receiver
Won't stay powered on
There is a relay right next to the fuses on the inside dg1u it says on the top. I cleaned it and pressed down firmly on it and it seem to have fixed it. It fired up for the first time.. The relay might need to be replaced if this doesnt work for ya.
I found a solution at: http://www.diyforums.net/forums/domestic-electronics/11098-yamaha-rxv795-receiver-shuts-itself-down-after-some-time.html
Dec 23, 2007 | Yamaha RX-V795 Receiver
Optical Dtv sound
Hi, I have located a manual for you, and if you go to Page 41 of the user manual there are instructions on how to select the audio source type - ie your optics from cable box. The best setting is to select AUTO, or manually set for your optical connection. This should solve your lack of audio, if you have any dramas, get back to me here. Good luck
Oct 13, 2007 | Yamaha RX-V659 Receiver
Open Questions:
See all Yamaha RX-V659 Receiver Questions
Yamaha RX-V659 Receiver Logo
165 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
