Question about Yamaha RX-V659 Receiver
How can i locate the fuse because my AV receiver no longer powers on ?
It was working fine then the next day it won't power on. Any help will be greatly appreciated.
    Genius:
  • 1,342 Answers
Have you checked the wall outlet first? Then make sure the cable is firmed plugged into the receiver.
Posted on Nov 12, 2014
4 Suggested Answers
  • 120 Answers
SOURCE: my yamaha htr 6050
Make sure you speakers are turned on on the receiver,
Posted on Jan 24, 2008
robotek
  • 1512 Answers
SOURCE: Finding a compatible remote
Hi there, this may take a little research to find, back to you real soon
regards
robotek
Posted on May 11, 2008
dunnbiker
  • 8546 Answers
SOURCE: Yamaha Amp RX-V1700B Receiver - no power to head unit
Go to the shop.
Posted on May 28, 2010
Testimonial: "Thanks - I came to the same conclusion myself - hopefully something simple and not too expensive."
How do I troubleshoot my Onkyo AV Receiver TX-SR603?
Based on your account it appears that you may have an issue with the power supply of the receiver.
Jun 13, 2016 | Onkyo Audio Players & Recorders
What's your problem?The horn won't work, the light that is supposed to go on when you open the doors won't work, the cigarette lighter won't work, and the head unit won't work
on 1987 all you mentioned are on same fuse #11 located in fuse box below steering wheel 3rd row 3rd fuse from left next to either a blank space if you do not have power windows,or next to silver circuit breaker if you do have power windows.
May 23, 2012 | 1987 Chevrolet Camaro
Buttons won't work. Just returned from a 6 day golf trip where the SkyCaddie SG4 worked perfectly for the first 5 days. I recharged it in a wll outlet overnight, then on the next day the buttons...
Power On/Off and Key Lock/Unlock - Press the Power button located at the top right
of the Sky Caddie to power on/off or to lock/unlock the keypad. Upon pressing
the Power button you are prompted to choose either "Off" (Left Soft Key) to power
off the device or "Lock" (Right Soft Key) to lock the keypad. To unlock the keypad,
select 'Unlock" by pressing the Right Soft Key, then choose "Yes".
Jul 02, 2011 | SkyCaddie SG 4 Handheld GPS Receiver
Jvc tv av36230 was working fine one day tried to turn it on the next and nothing. its like its un pluged but it is. is there a fuse or something inside?
Yes, TV sets have a fuse inside (in a holder on the circuit board near the power cord connections) and it may be bad, but that's unlikely to be the trouble. Fuses seldom just go bad on their own, and if you find it's blown there's usually some other part that causes it. A dead TV is not always easy to fix, and you generally need the services of an experienced technician with the tools and information to track down the problem.
Have you tried unplugging the TV from the wall, letting it sit for a minute, then plugging it back in? This will reset the computer inside (if it's getting power), and sometimes that's all it takes. If not, you can take the back off the TV (MAKE SURE IT'S UNPLUGGED!) and check the fuse, but that's about all. As I said, if it's blown it will probably go again if you replace it, and if the fuse is good but the set won't come on it will need professional help.
Good luck, and thanks for using Fixya!
Jun 06, 2011 | JVC AV-36230 36" TV
Working fine one day the next day no power, checked outlet and remote
hello if the fuse is ok in the plug then check the glass fuse in side the tv's power supply make you use the same rated fuse hope it helps
regards
shaun
Jan 30, 2011 | Televison & Video
My av-d30 was orking one day and the next day it wouldn't power on is there a fuse or breaker switch somewhere?
There should be one either on the back of the unit or inside the unit on the C-board.
May 31, 2010 | Aiwa AV-D30 Receiver
TEAC DIGITAL HOME RECEIVER AGD 8900 AV
I changed the diodos from power supply.
I thought that help you offered
was free,but I forget that nothing here is free.
Thank you anyway
Dec 15, 2008 | Teac AG-D8900 Receiver
Fridge not working on 12V or 220V
hi simon, i would say your ac heater is gone bad. it could have open up and no longer heating when you have a power surge . these heating elemenent are also located in the gas generator. you have to replace this heating element.
Feb 22, 2008 | Refrigerators
NAD AV713 receiver won't power up
I had the same problem with mine AV713 it turns out to be the relais of the power unit (left site above the transformer). solution may be to replace it with http://ecb.omron.com.sg/pdf/relay/power/G5PA-1.pdf e.g. good luck TB
Nov 20, 2007 | Sony A/V Receiver
My Unit Will Not Power Up
Not sure if this is a solution for you. I had a problem with the DC power input jack on the player going bad. The batteries would no longer charge. I bought an extra battery and a USB charger from ebay. Now I'm good for two battery cycles and it works again. Although it will never charge it's own batteries or work off of AC power it does still work.
Dec 21, 2006 | Archos AV 700 160-Hours Video Recorder
Open Questions:
See all Yamaha RX-V659 Receiver Questions
Yamaha RX-V659 Receiver Logo
105 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
