Question about Health & Beauty
What are contraindications of taking zoloft and trazadone
Having symptom of ssri's. I am suffering sycope. Also a problem with blood pressure is fluctuacting greatly. Have been hospitilized for a blood pressure reading of 55 over 47.
    Master:
  • 478 Answers
Ask your doctor
Posted on Nov 12, 2014
  • 2712 Answers
SOURCE: blood pressure measurements support
There are two positions for taking your blood pressure measurements: Sitting down - Place your elbow on a table. Using a flat object as support, position your wrist at heart level. Your blood pressure measurement will be too low if you hold your hand too high, or too high if you hold your hand too low. Lying down - Lie on your back. Rest your wrist on a support or cushion with the palm side facing up, position your wrist at heart level. On both of the positions you need to open and relax your hand with the palm facing up (closing your hand will cause inaccurate readings). Do not bend your wrist inward, as bending your wrist will cause inaccurate readings. If possible, empty your bladder before measuring your blood pressure, for a more accurate reading.
Posted on Aug 27, 2008
justclick_gy
  • 23 Answers
SOURCE: Only blood pressure result I get is 'EE'
please do contact me on my mobile no for your best work +91-9884462250
Posted on Mar 11, 2009
Max J
  • 22 Answers
SOURCE: Blood pressure reading 150/76. Manual Blood pressure 130/72
A monitor using Hg is only a valid monitor reading. Most electronic devices produce approximate results and are mostly good for taking several readings daily and obtaining a mean daily BP. Device calibration appears to be not accessible to the the user.Also, depending on age & condition of your dad, sequential reading must take place after elapse of enough time for circulation to be at steady state in the arm again, or if you immediately after a measurement make another, even with the same monitor you will obtain a different result.
Posted on Sep 07, 2009
SOURCE: How to clear memory on a ReliaMed wrist blood preassure machine
  • Make sure the unit is off
  • Hold down on the memory button until you see "CL" (clear)
  • Once you see CL appear on the screen release the memory button then tap memory once
  • You will hear a series of beeps
  • Memory is now cleared
  • Posted on May 14, 2010
    • 4736 Answers
    SOURCE: My blood pressure monitor is
    Contact the HoMedic's Consumer Relations Dept @ 800-466-3342 Mon - Fri, 8:30am - 5:00pm ET, they can help you.
    Keep in mind, that improper placement of the wrist cuff can cause higher or lower readings, than what they truly are. Also, not keeping your arm at heart level can cause an inaccurate reading.
    Posted on Mar 01, 2011
    What is the symptoms of high blood pressure?
    High blood pressure is often associated with few or no symptoms. Many people have it for years without knowing it. However, just because high blood pressure is often symptom-less doesn't mean it is harmless.
    In fact, uncontrolled high blood pressure, or hypertension, causes damage to your arteries. High blood pressure is also a risk factor for stroke, heart attack, and other cardiovascular problems.
    Some of the rare symptoms of high blood pressure are:
    Rarely, people with chronic high blood pressure might have symptoms such as:
    1. dull headaches
    2. dizzy spells
    3. frequent nosebleeds
    Other symptoms of a hypertensive crisis may include:
    1.severe headache
    2. severe anxiety
    3. shortness of breath
    4. nosebleed
    Mar 20, 2017 | The Health & Beauty
    When I take my blood pressure, the lower reading is regularly in the 50's. If it was higher would I have more energy?
    Possibly. Low blood pressure is good in that you will live longer, but can make you a bit fatigued. The ideal is 140/80
    Ideally, you should have a blood test to check your levels of iron, and a general check up. I am only an amateur doctor :>)
    Symptoms By Mayo Clinic Staff For some people, low blood pressure can signal an underlying problem, especially when it drops suddenly or is accompanied by signs and symptoms such as:
    • Dizziness or lightheadedness
    • Fainting (syncope)
    • Lack of concentration
    • Blurred vision
    • Nausea
    • Cold, clammy, pale skin
    • Rapid, shallow breathing
    • Fatigue
    • Depression
    • Thirst
    When to see a doctor
    In many instances, low blood pressure isn't serious. If you have consistently low readings but feel fine, your doctor is likely to monitor you during routine exams.
    Even occasional dizziness or lightheadedness may be a relatively minor problem - the result of mild dehydration from too much time in the sun or a hot tub, for example. In these situations, it's not a matter so much of how far, but of how quickly, your blood pressure drops.
    Still, it's important to see your doctor if you experience any signs or symptoms of hypotension because they sometimes can point to more-serious problems. It can be helpful to keep a record of your symptoms, when they occur and what you were doing at the time.
    low blood pressure Google Search
    Jan 25, 2017 | The Health & Beauty
    My blood pressure is 176 over 116 and been nauseous im hypertense And i taking pills ,but this 3 las days i been un and I having those symptoms is that Normalor a risk for stroke?
    Your blood pressure too high - Hypertension Stage 3
    Requirement for hypertension stage 3 is a value of over 180 over 110.
    If you are getting these values on multiple checks please consider finding a doctor as soon as possible. http://bloodpressureok.com/reading/176-over-166
    Nov 20, 2016 | Health & Beauty
    How is this treated my bpm has went from 84 to 54 in less than a month
    If your bpm goes down from 84 to 54 in just less than one month, you might suffer from low blood pressure. In this case, some food supplements can help you deal with this problem. However, before applying any of these treatments, you should consult to your doctors to ask for proper dosages.
    1, Coffee
    If you are a coffee fan then it can help with low blood pressure. You can consume a cup of coffee after waking up in the morning. Caffeine - rich foods can push up the blood pressure.
    2. Beetroot Juice
    In fact, this juice can help both high blood pressure and low blood pressure. To push up your bpm, you can take this juice twice per day until the condition is getting better.
    Mar 24, 2016 | Health & Beauty
    What are the common medications used to treat the symptoms of autism?
    fluoxetine (Prozac™), fluvoxamine (Luvox™), sertraline (Zoloft™), and clomipramine (Anafranil™)
    And of course ridlin
    Oct 21, 2015 | Autism Research Institute Android Apps
    What should my blood pressure be female 76 years old
    New blood pressure guidelines state " Adults aged 60 and older should take BP meds if their blood pressure exceeds 150/90". So, if you are below that and not experiencing any other symptoms, you should be good. I'd ask my doctor also.
    Sep 06, 2014 | Health & Beauty
    Does high blood pressures med.cause you to have memory problems? And is there a way to get back off high blood pressure meds.?
    As you know from watching television, all medications have many potential side effects. However, having said that, as a working RN for 25 years, I have never heard of blood pressure meds causing memory problems. If anything, it is the other way around: high blood pressure may cause decreased circulation to the brain and therefore possibly cause some memory loss. The thing about blood pressure meds is this: they are very very important! If you allow high blood pressure to go untreated, you can damage your eyes and your kidneys, both which have tons of small blood vessels. You can also wind up having a stroke. Generally, it is unsafe to get off blood pressure medications on your own.
    Jan 06, 2014 | Health & Beauty
    I am a 24 yr female. I am suffering from low blood pressure from last 2 month. It is 85/60. Doctor inject me METADEC 50. I want to know whether it is correct medicine for me or not. Because after injecting...
    Not sure this is the right forum for your question. As we normally don't deal with medical questions. I suggest you go to www.webmd.com and research the treatment for your condition, as well as the medication your doctor used.
    Apr 26, 2011 | Sunbeam Digital Blood Pressure Monitor
    Health & Beauty Logo
    79 people viewed this question
    Top Health & Beauty Experts
    Robin Hill
    Robin Hill
    wcdoc1953
    wcdoc1953
    Are you a Health and Beauty Expert? Answer questions, earn points and help others
