I am replacing the inducer assbly on a carrier unit model 48gs-036090311 and need to know where the brown and yellow wires go to on the circuit board.
Therinnaiguy
  • 1420 Answers
SOURCE: control circuit board for carrier a/c unit xcb 183e
You are missing some numbers. It is probably a KCB_ _ _ _ _ _ .
Get back to us with all the numbers and letters of the unit and we can get you a part number for the circuit board if that is what you are looking for.
Posted on Jun 12, 2008
peyton32034
  • 410 Answers
SOURCE: thermostat wiring goodman model aruf032-ooa-1b
is this a heat pump or straight cool with heat strips?
Posted on Mar 16, 2009
  • 232 Answers
SOURCE: I'm seeking the wiring schematic for Carrier
http://www.docs.hvacpartners.com/idc/groups/public/documents/techlit/48gs,gx-7si.pdf
Posted on Sep 12, 2009
Therinnaiguy
  • 1420 Answers
SOURCE: Carrier 48gs-024060301. Rollout switch fault.
Juno out the switch and see if the unit fires. You may have more than one. Check the wiring diagram for sure.
Posted on Oct 18, 2009
  • 288 Answers
SOURCE: need to know were purple brown and yellow wire off
take off the door panel and look to the inside. It will have a wiring diagram, legend, and color codes for the wires. The combustion motor or inducer fan should be small enough that it doesnt need a capacitor. The indoor fan motor or squirrel cage does.
Posted on Nov 26, 2009
When the heater is on, should the fan outside on top of the unit also be working along with the blower from the heater ? When the heater is off, cold air is comming from the vent's, can I cover the
No. This is strictly a gas package unit, not a heat pump. the condenser fan motor should NOT run when their is a call for heat from the thermostat. The condenser fan only runs with the compressor on a call for cooling. Hopefully the compressor is not running @ the same time, but if it is, it would make sense that the contactor for the compressor & condenser fan motor is stuck closed OR the low voltage cooling wires are shorted straight to a 24Volt control wire.
Jan 15, 2015 | Carrier Heating & Cooling
Connecting replacement fan motor in HP condenser
What is the model number of the heat pump? What is the voltage that you are dealing with?
Nov 26, 2013 | Carrier Heating & Cooling
Need to know were purple brown and yellow wire off cumbustion motor hook back up to compasetor and circuit board on a carrier 48gs 03609 0301
Nov 26, 2009 | Sewing Machines
Wiring match-up
If this is a standard heat cool unit. You have a tstat with rygwcob. Just color code the wire to the unit. Some air handlers such as Rheem and carrier use different collors for there common Carrier black Rheem or Rudd Brown. Two wires that go outside use yellow blue. Yellow to Y fron Tsta and blue to common or blue,blavk or brown.or C
May 30, 2009 | Heating & Cooling
Replace thermostat
Typical color codes in Florida are;
white to W1 for heat
yellow to Y for compressor
red to R-RC-RH for power in
brown to W2 and or emergency /auxillary heat
green to G or Fan
orange to reversing valve(o/b)
blue to common.
You can open the control panel on the unit to verify these colors and components.
Feb 21, 2009 | Carrier Heating & Cooling
I have a carrier AC model#50ee036330, the fan motor went out it was an emerson2 speed with 3wires.IMtrying to replace it with a GEMOTOR no.3586 with6 wires at 1 side and 4 on the other.6wires arered black...
jenny,White and black is high speed,wire nut the yellow and blue by themselves(2) brown wires cap.yellow brown together and orange and purple together they should be direction wires.If the fan runs backwards change them
Aug 14, 2008 | Carrier Heating & Cooling
Compressor fan unit wiring
Should be OK to hook it up and try it, make sure the fan is blowing out, if not, reverse the wires..
Geno
Apr 04, 2008 | Carrier 38CKC036 Air Conditioner
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
