Question about Saws
My generador g1100 wont stay on after i conect a ligt or a small steam table
    Top Expert:
  • 26,753 Answers
What is it?
Posted on Nov 12, 2014
There is a small dint on my Stiga expert WM table tennis table. How can I fix that?
wooden table top
use a hot iron on a wet cloth over the depression
the steam produced swells the wood and removes the depression
May 11, 2018 | Miscellaneous
My delonghi esam3300 can not make any steam or hot water. The heater still get hot. There is voltage across the solenoid terminals on and off when I flip the steamer switch. Solenoid defective?
First I'm not a Delonghi tech. But I have worked on similar table top "Super Automatic" machines. You should call your vendor for service as there is no customer serviceable parts in this machine.
*** the following is for information only. ***
* There are usually separate boilers for table top units. There is a pump and heater system for each section. (usually 2 for this type of machine. But there may be a third system if you have the Coco option.
* Since each system is separate then your Latte/cappucino system has a problem. I will list the most common but all require a qualified service tech to repair/replace. (lots of small parts crammed into a very small space.)
* Cap/Latte Membrane button not working. If it feels mushy (not like the other buttons) then the button panel needs to be replaced.
* There is a CPU/PC board malfunction. Replace
* There is air in the water line to the Cap/Latte system. Make sure the water tank is filled. Power down. Wait 10 seconds. Power back up. Press the Cap/latte button to start the pump. Watch the steam wand if water flows out. If it does, then wait 30 seconds and try again. should be steaming.
* No steam or at least hot water? Just cold water? Then the steam heater and/or thermo-fuse, thermo-disk, needs to be replaced.
* Got hot water but little to no steam? Then steam unit and/or thermo disk needs to be replaced. (best to replace both as a whole unit; tank, Heater, and Thermo-disk)
* Heats up very hot but sputters water and steam. Clean steam wand and/or tip (if removable) If it leaks steam at the top of the wand near the body of the machine then the whole wand needs to be replaced.
* Still sputtering? The steam system is clogging up. Call for service.
* Final; I'm not a fan of de-scaling as it causes more problems for the machine. I've always found that using filtered water (bottled ok) is best. Water softeners if available is okay. BUT stay away from HARD water and Ultra Pure (100%) water as it leaches out the metal ions from the machine.
Aloha, ukeboy57
P.S. Since you have already taken things apart, I'm guessing you don't mind jumping to the 'guts'. Your probably looking at a clog at the vibration pump all the way to the hot water (or steam) tip. It can clog anywhere there is water. It may even be the water hose (with filter?) or the water tank. Start from the tank and keep trying to get water to flow through each section. You will need power for this so be careful! There are a lot of you tube vids showing how to check the common vibration pump. Bring your reading glasses as it have very small parts (and don't lose the spring or the small ball!) Good luck! Aloha, ukeboy57
Apr 16, 2018 | DeLonghi Coffee Makers & Espresso Machines
Can you fix an X3-X4 francis francis machine
First I'm not a Francis tech. But I have worked on similar table top machines. You should call your vendor for service as there is no customer serviceable parts in this machine. (To your question, Yes, it can be fixed but you may find it costs more to fix than to replace it with a new machine.)
Aloha, ukeboy57
Apr 09, 2018 | Coffee Makers & Espresso Machines
I have a delonghi esam 6900. It makes coffe but it doesn't make capuccino or latte or flat white and also no steam. What causing it?
* Final; I'm not a fan of de-scaling as it causes more problems for the machine. I've always found that using filtered water (bottled ok) is best. Water softeners if available is okay. BUT stay away from HARD water and Ultra Pure (100%) water as it leaches out the metal ions from the machine. If you must descale then follow the MFR instructions and use approved solutions.
Aloha, ukeboy57
Feb 08, 2018 | DeLonghi Coffee Makers & Espresso Machines
My Sunjoy L-PH007PSS-B wont stay lit.
Blocked pilot too small needs cleaning , or clean end of thermocouple ,or replace thermocouple
Nov 02, 2012 | Uniflame Table Top Outdoor Patio Heaters -...
What tipe of oil makita generator g1100 takes
Great generator, i use 15/40 Quaker State it seems to work well for my uses, i have same one, but is 2000. check your manual if your really concerned, the whole thing, is keep oil fuel, and changed often. Hope this helps mike
Jun 13, 2011 | Makita G1100 1100W Generator
Shark Euro pro mop the ligt wont turn on anymore.
my husband fixed my shark steamer by taking it apart and testing it wire by wire .the problem ?a fuse hidden inside the unit..unscrew the screws and get inside the steamer .at the bottom of the steamer there is a gold orange foil looking piece .under that is a small fuse .unless you can find another fuse just cut that one off and rewire the wires together .shark now comes on
Sep 27, 2009 | Euro-Pro Shark Steam Mop - Gray/ Purple...
TURN SIGNAL LIGT WONT BLINK ,JUST STAYS ON
dont replace the switch make sure you have the correct bulb installed correctly first. might save you another headache i take it the other blinkers work than you have a good relay good luck
Apr 14, 2009 | 1998 Volvo V70
Saws Logo
46 people viewed this question
Top Saws Experts
Tom Chichester
ray gallant
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Saw Expert? Answer questions, earn points and help others
