My dynex keeps going off for no reason
Cable states its not cable
    Top Expert:
  • Televison & ... Master
  • 74,468 Answers
Fault with its main board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ . In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Posted on Nov 12, 2014
A BOX WITH THE FOLLOWING INFO KEEPS POPPING UP ON THE SCREEN: 480P SD, HOWEVER I HAVE A 1080P FLAT SCREEN. IS THIS A CABLE ISSUE OR A DYNEX ISSUE?
It is most likely a cable issue. If you have a 1080p television your tv might be trying to communicate with your cable box. If your cable is broadcasted in standard definition that message can show up. I would recommend checking with your cable company and see if you have HD channels or not.
Aug 01, 2012 | Dynex DX-L42-10A 42 in. LCD TV
Now that I don't have cable, should I disconnect by Dynex 32
All electronic devices will go bad if you do not use it for a long time. Just switch it on at-least weekly once and play your DVD to keep it alive. Otherwise, the capacitors will become dry and ultimately might become defective.
Jul 31, 2012 | Dynex 32 in. LCD Flat-Panel HDTV
My dynex lcd tv keeps saying no signal when cable is plugged in?
It sounds like the CATV portion of the TV tuner is bad--Cable band.
You may have an option---with a cable box that has the audio/video jacks for output of signal on its rear side connect to a unused video input on rear of set--go to that input and change channel via the box---BY PASS THE TUNER IN THE SET THIS WAY.
May 25, 2012 | Dynex Televison & Video
I cain't get cable or antenna to work on my 19"dynex flat screen tv to work
if it keeps saying no signal make sure all the cables are plugged into the tv
and select the appropriate input on the tv
Nov 05, 2011 | Dynex DX-LDVD19-10A LCD TV
When setting up a new TV, it keeps telling me to "Please run channel auto scan." But it also states that if I sellect Cable/satellite, that the tv does not need to run the auto scan. When you...
you need to select cable from off your remote and run the auto scan.even if it says you does not need to run auto scan still run the auto scan.good luck.
Sep 25, 2011 | Dynex Televison & Video
Dynex tv works. bought ps3. when hooked up to
I would suggest you check if your PS3 is set up on going through the HDMI Cable.On your PS3's XMB scroll to settings -> Display Settings -> ANd from there go down to the one that says "Y Pb/Cb Pr/Cr Super-White (HDMI)" and hit X and select the option Yes... That sets the PS3 displaying through the HDMI
If you are already have done that I'm pretty sure you know you have to change the Input on your TV to HDMI... Take your remote and hit Input -> Scroll down to HDMI on the Input Source menu and hit Enter when you get to HDMI
If the AV on your PS3 works and not your HDMI sounds like Display Settings issue...
If you have done all that, that is strange if it still doesn't work.
There are some people that are having problems with the AV Cable with the PS3, I tried this and it really does work. I switched from HDMI on one tv to a AV Cable on another and when I did that neither TV would display content from my tv. The fix for this is resetting your PS3, like on a iDevice you hold the home button and lock button, for the PS3 you hold the Power off button and the Eject button for around 10 seconds. This resets your PS3 into default video settings. Until it Turns on, Beeps, and Turns off. This should work.
Jan 01, 2010 | Televison & Video
Driver not supported
Here is the website.  Download the driver if need be. The website states that win2000 is supported.
http://www.dynexproducts.com/p-190-dynex-51-channel-pci-sound-card.aspx
Jan 13, 2009 | Dynex DX-SC5.1 Sound Card
Dynex wireless modem
Your expert Geokohler helped me fixed the problem and soved it for me. I sent an evaluation giving him a "fixit" rating.
Jul 21, 2008 | Dynex DX-E401 Router
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
