Question about Rival Crockpot SCVP550-B 5.5qt. Slow Cooker- Black
Is #1 the highest setting? - Rival Crockpot SCVP550-B 5.5qt. Slow Cooker- Black
    Master:
  • 477 Answers
Yes
Posted on Nov 12, 2014
Ryobi 725r trimmer carburetor adjustment
Turn both low and high adjustment screws carefully clockwise all the way in - do not overtighten.. Then back out each two full turns. Set the idle speed control for highest setting. Prime and start and let it run and warm up for about 15 seconds - then lower the rpms a tad and then adjust the low end screw for highest rpm. Then reset the idle to lower reasonable level. You may have to go back and forth with those two adjustments till it runs fine at low idle speed..
Then accelerate to highest speed and set the high adjustment for highest rpm. Then go from idle to high speed. If not smooth a small adjustment on the high speed screw is in order. Keep doing that until you get a nice smooth transition form low speed to high speed.
Mar 11, 2017 | Ryobi Garden
Why do all toasters have a setting that burns all my toast to a crisp?
The highest setting on most toasters is not meant for sliced bread straight from the bag. The highest setting should be used for frozen bread.
Jul 15, 2012 | Franklin Machine Products DIAL, THERMOSTAT...
Hi there I just bought a Polaroid two instant print camera but the quality of pics is really poor very washed out and even a bit blurry do I need to set it up?
set your pixel ratio to the largest setting, this means less pictures per memory, but higher picture quality. Also if possible adjust your iso to the highest setting, as well as the shutter speed, having both of these settings set to the highest point will require more light for picture taking, however will result in the highest quality image.
May 05, 2011 | Polaroid Cameras
Somebody was using my Yamaha piaggero NP-V60 and they ruined all of the factory settings, I have no idea how to fix this problem, Is there a reset all settings function? What are the original settings...
Well, that thing's not a receiver, but here goes...LOL
your manual is here:
http://www.americanmusical.com/ItemFiles/Manual/YamahaNPV60DigitalPianoManual.pdf
going to most settings and pressing the + and - together resets the value for that parameter to factory.
Taking the settings back to factory without wiping data uploaded from the computer
hold the highest white key while powering the unit on.
Clearing computer uploaded data
hold the highest white and 3 highest black keys while powering the unit on.
That first one should FixYa!
Feb 27, 2011 | Yamaha Audio Players & Recorders
Monitor screen is almost completely black - i can only see the desktop very slightly. is there a light bulb that can be replaced to fix this?
Change the display resolution in Windows To change the display resolution to the highest resolution, use the following actions.
  • In Windows 7 , click Start , click Control Panel , find the Appearance and Personalization area , and click Adjust Screen Resolution . Move the slider bar until the highest resolution for the monitor is set, and click OK .
  • In Windows Vista , click Start , click Control Panel , find the Appearance and Personalization area , and click Adjust Screen Resolution . Move the slider bar until the highest resolution for the monitor is set, and click OK .
  • In Windows XP , click Start , click Settings , and then click Control Panel . Double-click the Display icon, and select the Settings tab. Move the slider bar until the highest resolution is set, and click OK .
If the screen is still blurry, please contact an HP support technician for further assistance.
Also see To troubleshoot this problem, make sure the AC adapter is connected. For specific steps, see HP Notebook PCs - Troubleshooting Black Screen Displays with No Error Messages During Startup or Boot .
Nov 02, 2010 | HP G60-127NR Notebook
Screen will flicker a few times at random periods
Change the display resolution in Windows Change the display resolution to the highest resolution using the following actions:
If the screen is still blurry, the notebook display might need servicing.
Feb 13, 2010 | HP Pavilion dv4000 Notebook
Fan switch only works on the two highest settings
the various speeds are controlled through resisters (spring-like in apperance) one of different value for each speed, none for highest speed as the power gets to the blower uninpeeded . the resistor pack should be located on the center of the firewall, held by 2 screws. thats under the hood. where the engine bay ends....
Jul 22, 2009 | 2003 Buick Century
Air conditioning blowing only highest setting but HOT air
Sounds like your freon has leaked out and your heater blower resistor is burned out. Deffinitly take this to the dealer.
May 20, 2009 | 2001 Honda Odyssey
Heater issue - only works when on highest setting
this is caused by the blower motor speed control resistor being defective, this part is located near the blower motor.
Oct 30, 2008 | 2000 Chevrolet Prizm
Rival Crockpot SCVP550-B 5.5qt. Slow Cooker- Black Logo
48 people viewed this question
Top Rival Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Ed Mac
Henry  Thomas
Henry Thomas
Are you a Rival Kitchen Appliances - Other Expert? Answer questions, earn points and help others
