Question about Craftsman Garden
I have a problem with the linkage on my model #917.377190 lawn mower.
I had to replace the carburetor on the mower and I am not sure that I have linkage hooked up right because the mower will only run at idle.
    Genius:
  • Craftsman Master
  • 2,494 Answers
Hook the wire that goes to the governor to the butterfly on the carby , the other should go to the choke.
Posted on Nov 12, 2014
Testimonial: "this 917.377190 does not have a choke and it does not have a throttle control but I do appreciate your help."
SOURCE: carburetor linkages for riding lawn mower
Go to a tecumseh website and get a breakdown of the parts list and that should help a bit. Good luck.
Posted on Mar 26, 2009
  • 57 Answers
SOURCE: Need linkage hookup diagram for Toro Super
Go to TORO.com and view parts for your model.
Posted on May 19, 2009
  • 59 Answers
SOURCE: lawn mower ony runs at idle and dies after seconds
try holding the throttle open
Posted on Jun 26, 2009
  • 691 Answers
SOURCE: Lawn mower will not stay cranked unless you keep pouring gas into
common problems to all older lawnmower, lots of dirt and dust the mower goes through and ages. I would first start by taking the carb apart and clean the filter with soap and water, allow it to air dry. also carburetor prob need rebuilding or replacing. Pick up some Carburetor cleaner at any auto part store and spay it down the carb, dont be afraid to spray allot in there and let it dry for 1/2 and hours. carb tend wear and parts need replacing just like any engines. 99% of the time lawn mower carb goes out before the engine will and common problems with all lawn mower. If you not mechanical incline or dont want to rebuilt it, just buy the whole new carb and replace it, fairly cheap easy to replace and will last you another 10 + years or more. www.briggsandstratton.com
Posted on Sep 01, 2009
Testimonial: "This guy really knows what he is talking about. I would highly recommend him."
SOURCE: Craftsman lawn mower running bad with Tecumseh
http://www.tecumseh-parts.com/Tecumseh-Parts/tecumseh-vector-engine-and-parts
Posted on Oct 12, 2010
Need a throttle linkage diagram for a briggs & stratton engine model 9S502 type 0620-B1
David, This is what I found in google search for B&S carb. linkage diagram, you can also do a search because there are lots more.
Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Linkage Spring replacement on Briggs Stratton Quattro 4 HP Murray Lawn...
Repairing Lawnmowers For Profit Part 61 Governor Spring Help
briggs and stratton governor linkage diagrams Google Search
briggs and stratton carburetor linkage diagrams Google Search
Jun 10, 2016 | Briggs & Stratton Garden
How do I refit linkages and springs and in what order on unidentified lawn mower?
Linkage & Spring replacement on a Briggs & Stratton ...
? 7:13
https://www.youtube.com/watch?v=8atnwA4D5lM
Jun 26, 2010 - Uploaded by paisteboy
In this video I replace the two spings at the linkage on the carburetor of my Murray Lawn Mower that has a ...
4 HP Briggs & Stratton Quatro Motor Spring & Linkage Close ...
Nov 24, 2015 | Garden
The Throttle linkage on the carburetor came off where does it go
on the inner butterfly linkage on the carburetor closest to the engine
Feb 27, 2013 | Mtd 22" Yard Machine Push Mower
How difficult is it to replace a carburetor for YardMan by MTD push mower?
Depends on what engine. IF it is Briggs and Stratton you remove the aircleaner cover and air cleaner element. Behind that are three little 5/16 bolts,remove those and the aircleaner mount comes off.Behind that are 2 3/8 bolts that bolt to carb to a brackett that holds it to the engine. Remove the fuel line by removing the clamps. Becareful with the throttle linkage. Some models of Briggs had a plastic throttle and it breaks easy,The wire linkage has a Z bend ,so hold the wire while moving the carb off the Z. Why would you replace the carb. Its simple to rebuilt. You local Yard Equipment dealer would probabley do it for $20 bucks instead of paying 60 or more for a new one. Its probably only full of dirt or water and the needle and seat need changed.
Hope this helps.
Oct 20, 2009 | Mtd Yard - Man 160cc, 21" Self - Propelled...
Sep 01, 2009 | Omega Rear Drive Wheel Snapper Mowers
I inherited a lawn mower from my father's estate, which won't sta
There should be a wire that is a link between the governor arm & the carburetor butterfly (throttle) arm. Some use a small coil spring hooked to the same holes as an anti-rattle device.
Apr 10, 2009 | Garden
Carburetor linkages for riding lawn mower
Mar 24, 2009 | Tecumseh Lawn Boy Push Mowers Insight...
Lawn mower carburetor
It is a tecumseh , remove screws from intake pipe to block
mark holes for linkage don't stretch springs.
Remove bottom bowl nut it is reg thread so turn counter clock wise . parts needed 631021b bowl gasket and needle and seat,
36786 intake gasket,
632547 2 o rings,
36905 air filter .
Use a can of carb cleaner auto zone spray all holes even the one
on the bowl nut , take out center plastic main nozzle out put on the new o rings put back in , some time the nozzle will brake part 3 640019 .
Remove seat can use comp air or make tool out of paper clip don't
scratch the side when pulling out
Good luck
Feb 02, 2009 | Oregon Scientific Oregon Fusion Blade For...
Garden Logo
79 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
