Question about Welding Tools
My Miller 212 quit feeding wire after four tacks. The blue light for the auto set won't even come on. What could the problem be?
    Master:
  • 477 Answers
Feed rollers are probably not tensioned correctly
Posted on Nov 12, 2014
SOURCE: Miller 130 XP wire feed quit working, fan runs....
Usually either the Power Supply to, or, the Motor drive circuitry. Or even the "Feed motor" itself.
Posted on Feb 11, 2010
luxur4
  • 92 Answers
SOURCE: need wiring schematic for miller 140 wire feed welder
No problem,email, write or phone for this information, Miller personel are very obliging as are most Welding manufacturers.
Posted on Jan 23, 2009
SOURCE: wire feed comes and goes
your drive rolls may be to tight or the spool isnt and the holder all the way
Posted on Mar 12, 2010
  • 97 Answers
SOURCE: miller 175 trigger will not feed wire very
First thing make sure the lead cable is as straight as possible. and make sure the wire has a unobstructed path. then you should check the trigger input/output switch and see if the switch is getting power to it continuously. I hope this help please rate this thank you
Posted on Mar 15, 2010
  • 1212 Answers
SOURCE: miller cricket 115 volt wire welder stock #909071.
The contactor is stuck closed, the trigger wiring in the cabinet is shorted together or trigger switch stuck closed.
Posted on Jan 16, 2012
My miller 175 wire feed does not feed wire at low number settings
Usually, the drive motor voltage is derived from the weld voltage, so if you lose, the weld voltage, the motor will not turn. Feed some wire out in a setting that works, then switch to one that doesn't feed, and see if the wire will arc. If you have a voltmeter, check for DC voltage at the polarity changover. Might be a bad voltage range switch.
Mar 30, 2017 | Miller Welding Tools
I can turn the welder on and it can run all day but when I start welding with in a minute the overheat light will come on and it will stop feading wire. I'm trying to weld on mid temperature.
Have you checked so see if your power cable is the right size?? Is it a 220 or 110? If it is 110 then it will cut off after it gets hot, if it is 220 and the power cord is too small then the machine will be trying to pull more amps than the cord can handle causing it to overheat and shut off.. My husband has been a welder for 20 years.. I'm just passing along what he suggested might be the problem.. Hope this helps!
Oct 03, 2015 | Millermatic 212 907405 Auto-Set Mig Welder...
New welder, only fed wire a couple times now it wont work
the noise you hear is the relay for the wire feed,it means that your tension on the wire needs to be set,tighten it if it is too loose and loosen it if the roller on the feed is moving but the wire is not,also,make sure the wire moves easily in the handle,always keep your cords straight so they dont bind.
May 05, 2015 | Millermatic 212 907405 Auto-Set Mig Welder...
I have a miller 211 and the fan cuts on but nothing lights up and no wire feed
If this is the auto set version, is it under warranty? Less than 3 years old? If so take it to a shop and fix should be free. Otherwise, the fan motor is also a transformer, which puts out 24 vac to run the board. So could be fan motor or the board itself.
Feb 21, 2015 | Miller Welding Tools
Coil quit firing
If you have no spark from two of the four towers of your coil pack, you need to check the wiring between the coil pack and the ignition module. Since you have spark at two towers, that proves you have power to the coil pack. Both sets of coil windings in the coil pack are fed by the same B+ feed,(red and light green wires to both coil packs too). The control side wires from the ignition module to the coil packs are tan/light green and tan/light blue for one coil pack.-----------------------------------------------------------------------------------------
ELM 327 1.5V USB CAN-BUS Scanner
Mar 27, 2013 | Cars & Trucks
My trigger to my millermatic 250 won't stop feeding the wire even when switch is not pressed
Does it feed with the trigger plug removed from the machine? If so, then it is a circuit board. If no, then wires shorted somewhere in the gun.
Apr 17, 2012 | Miller Welding Tools
I have a Miller Shopmaster power source attached to a Miller model 22A wire welder. The problem is when the heat is set above 150 the wire feed pulsates and will not maintain a constant wire feed. Do you...
Check to make sure wire feed brake is not set too tight and that all cables and gun are clean. Also check wire feed wheels are clean and in good shape
Apr 09, 2011 | Miller Welding Tools
Hi,my 96 toyota corolla did not have a digital clock so i bought one off ebay, it has four wires coming out of it do you know were they go? Thanks
one 12 v feed permanant ,one earth ,one light feed and one 12v switchable from ignition switch to make it light up when ignition is turned on --- i think ??
Mar 15, 2010 | 1996 Toyota Corolla
Feb 10, 2010 | Welding Tools
Millermatic 140 w/ auto set powers on but will not feed wire or arc
If its a new unit its probably nothing. Miller makes good stuff. Open the side so you can see the spool. With the machine on, press the trigger for a second. Did the little wheel spin (trying to feed the wire) if it did then your problem could be kinked wire, **** on tip, or spring on small spool is loose and wire is slipping. Let me know.
Nov 20, 2009 | Miller matic 140 Mig Welding Package W/As...
Welding Tools Logo
42 people viewed this question
Top Welding Tools Experts
Bill Boyd
Are you a Welding Tool Expert? Answer questions, earn points and help others
