Question about Samsung Bp96-01103a Dlp Tv Color Wheel L6 Chassis
Samsung HLR5078 50" tv - replaced a shattered color wheel but the colors are way off with the new one - yellow in place of both red and greens.
I did the Option > DMD - Digital setting and tried changing the index relay as listed in the service manual with no help (on the Red, Green and Blue bars on the index relay adjustment mine are just different shades of yellow, yellow and blue no matter how high or low I go). Looked for the "jumper cable" others have mentioned, but got all the way to the circuit board and confirmed my model does not have that jumper cable on it. Is there anything else I can do to adjust it? Also, my new color wheel did not come with any numbers/instructions on it. I ordered the BP96-01103A on Amazon but the one they sent is L6/BP61-01024A - at first I thought that might be the problem, but when searching elsewhere I see both of those product numbers listed simultaneously for the same color wheels.
    Sergeant:
  • 295 Answers
I'm not sure you received the correct color wheel. Do you have anything left of the shattered color wheel to compare it to the new one? Seems if you got the correct wheel then the colors should of been the same. Color wheels spin at the same rate of 60Hz. The only reason why you would get the wrong color is that the color on the wheel is in the wrong placed at the right time. I would see if you can get a wheel the same # as your original one.
Posted on Nov 13, 2014
  • 1 more comment
  • Geoff Duncan
    Geoff Duncan Nov 13, 2014
    Thanks! Unfortunately when we originally installed the new color wheel and everything booted up fine, we threw out the shattered wheel and it wasn't until a few hours later when we had connected everything to the TV that we realized the color was off so badly. By then there was no way to get the old one back (down a garbage chute in our apartment building). I may try going back to the seller to clarify the difference between the model numbers and try to get a new one. I was just worried because I had read some other threads where people said colors being off like this could also possibly be damage to the optics drive or something else.
  • Philip Frye
    Philip Frye Nov 13, 2014
    I don't know how expensive that color wheel was that you bought but obtaining the original part# color wheel may be the answer. At least you could compare that wheel with the alternative part # wheel you currently have.
  • Geoff Duncan
    Yeah, they're about $120 each. I had already replaced the lamp for $40 as well before realizing the color wheel was the problem, so I'm hoping to not have to pay another $120 if I can help it since it's a 7 year-old TV. Trying to see if the seller will swap this one for the correct part. Thanks again for the help!
2 Suggested Answers
SOURCE: Samsung hlp5063wx - Just replaced color wheel and
The Lv values are for Red-Y, Green-Y, Blue-Y, White-Y
Posted on Sep 19, 2009
Tv samsung hls4266w all light are blinking replace the blud small fan and large fan running
Sounds like a bad color wheel----remove lamp---the wheel faces it--look for missing pieces or the wheel shattered---these are known for the wheel making a loud high pitched sound or even a grinding sound if the wheel shatters.
if wheel bad You Tube has video instructions for replacing it---seen several people able to do this themselves in about a hour. Google the model number to ("color wheel") to locate a replacement on the internet.10_24_2012_4_08_47_pm.jpg
Oct 23, 2012 | Samsung 61" Slim-Depth DLP HDTV
My tv only shows in green and purple
Have you examined the color wheel this set should have?
look for (remove lamp as it faces that) any segments broken or missing.
A color wheel also can have a high pitched or fan like sound but not always.
check the wheel first.
Jun 15, 2012 | Samsung HL-67A510 67" DLP HDTV
The color wheel on my Samsung HLN-5065WX shattered. I carefully replaced it with a new one. Checked all re-connected wires twice. The TV will not turn on. It doesn't make any sound. The lamp and temp...
The tv projection Lamp in the tv now has been in it like 1 1/2 or 2 years, tv in used like 4 or 5 hours a day.When ur colors wheel was destroy and shatter?Yes,it is the tv projection lamp is life are over.
Dec 11, 2010 | Samsung HLN5065W 50" Rear Projection...
Samsung HLN617W DLP 61" TV only show green color
BINGO! Light Engine, Maybe listed as- Assy Engine Go to website Encompass Parts Distr their you will find what you need or Call 1-800-638-3328 ,or Try UED 1-800-648-6657
Dec 01, 2009 | Samsung HLN617W 61" Rear Projection HDTV
Samsung DLP Facial Colors off after changing color wheel
Do you mean that red and blue are reversed? If so, you may need to remove a jumper, see end of linked article. Pinkish-yellow or orange sounds like a good description of skin tone, but perhaps too intense. If the color is too intense, can you just lower the color level with the color control? Or can you just change the tint with the tint control? Otherwise, see http://www.jangro.com/electronics/samsung-dlp-replace-color-wheel/ including the comments at the end.
Oct 11, 2009 | Samsung HLN4365W 43" Rear Projection...
Color changed suddenly, no red, just green/yellow/blue
Sounds like the color wheel has gone bad and needs to be replaced. This is located behind the back panel.
May 21, 2009 | LG 37LP1D 37 in. LCD Television
After color wheel replacement colors are wrong
you need to index the color wheel after repalcing it so its spinning at the correct speed
Apr 30, 2009 | Televison & Video
Samsung dlp 6163w color wheel
Ours was on the color wheel. I also went to samsungparts.com and entered my tv model number and we could veiw the color wheel. However, the one we needed is back orders . I hope your is not.
Mar 02, 2009 | Samsung HL-P6163W 61" TV
Clicking Noice after replacing shattered color wheel, ballast and lamp...
Not sure if this will help but I read in the manual that if you have
a clicking sound that the cable setting and the air setting are both turned on...Good Luck
Jun 04, 2008 | Samsung HLR5067WX 50" Rear Projection HDTV
Samsung Bp96-01103a Dlp Tv Color Wheel L6 Chassis Logo
62 people viewed this question
Henry  Thomas
Henry Thomas
