Question about Tools & Hardware - Others
How to disassemble the exhaust cover on a hitachi nv45ab2
My hitachi nv45ab2 was blowing air so I bought a rebuild kit I rebuild all my bostitch nail guns.i cant seem to figuar out how to get the exhaust cover apart anybody know it I could get therest im sure looks like the rest once past this
    New Friend:
  • 131 Answers
No need to take cover off for repair.
Posted on Dec 04, 2014
rowdy45176
  • 2176 Answers
SOURCE: A Bostitch F28WW that spontaneously fires a nail when coupling.
When was the last time this tool was serviced? Bostitch makes an Oring kit for this part #N890RK I could not find the price. I would start by looking at the safety to make sure that is moves freely and is not bent. Then I would think about putting new rubber in this tool. First go to Stanleybostitch and navigate into tools and then support to look at a breakdown for this one. It is not that difficult to rebuild, if you do make sure that you put lube on the new orings and take your time rebuilding to ensure that you dont pinch one of the new rings. Hope this helps
Posted on Jan 15, 2009
comax
  • 154 Answers
SOURCE: Help with Bostitch N60 air nail gun.
If it is a N60FN you will have to install a new trigger valve P/N TVA6. Any Bostitch service center should have them.
Posted on Apr 13, 2009
  • 384 Answers
SOURCE: bostitch nail gun model n62fn when hooking up air
It is passing gas.
Posted on Sep 02, 2009
  • 122 Answers
SOURCE: anybody know where i can get spare parts online
The best is ereplacementparts.com or you could also try toolbarn.com.
Hope this helps!
Posted on Feb 02, 2010
  • 885 Answers
SOURCE: bostitch roofing nail gun soon is i plug up my air
You need to replace the o-rings in the trigger.
Posted on Aug 23, 2010
Air slow to build pressure after the trigger is pulled not sinking nails completely
Tear the tool down and install #18001 Rebuild kit. Just because the O-rings look good doesn't mean they are not worn.
Also make sure you grease the orings with the grease provided in the kit.
The entire cylinder has to move up and down in this gun so it is important it is clean & lubricated.
Mar 06, 2015 | Hitachi NV45AB2 Roofing Coil Nailer
How do i rebuild my bostitch n80 frameing nailer
Bostitch nailers are simple to rebuild. Bostitch company was sold to Dewalt so parts are now easier to obtain from local Dewalt service center. Use Ork11 oring kit and tva6 trigger valve. These parts are also available on ebay. Good luck or your nailing projects.
Sep 18, 2014 | Stanley Bostitch N80CB Coil Framing Nailer
AIR BLOWING OUT OF EXHAUST PORT DO NOT NAIL AT ALL
you have a problem with a split o ring or a seal that has gone bad. I would suggest buying a rebuild kit and redoing all the internal parts. It is not that hard to do and I would suggest taking some pics along the disassembly to make it easier when rebuilding. Let me know if you need more help.
Jul 09, 2011 | Stanley Bostitch Nail Gun
Looking for rebuild kits (parts) for my N16 nail guns. I have 3 of these older guns and would like to rebuild them.
Stanley Bostitch doesn't make kits to rebuild their nail guns, you have to order each o-ring, seal, etc. seperately. The N16 was a good gun however there are very few parts available for them. You can go to www.bostitch.com to see what's available through them. You can also get part numbers for what you need for your guns and research any available parts on the web.
Dec 22, 2010 | Stanley Bostitch N16 Nailer rebuild Parts...
Hi, when I nail also it leak. when I make a shot, the gun nailer blow for the middle. but when I don't nail it does'nt feel any leak.
Your description makes it clear that it needs a head rebuild kit. You can order this from Hitachi, or send it in to local Hitachi center. Good machine, straightforward repair. If you are a little handy, you can do this repair yourself. remember to oil the gun frequently to make your repair last longest. Farmerbear at FixYa
Oct 14, 2010 | Hitachi NV45AB2 Roofing Coil Nailer
I have a Bostitch BT200 that is dry firing. It seems that the "hammer" is not retracting after it fires a nail. I have to push it back manually and even then it seems to dry fire a few times before a nail...
The check seal is what causes the piston to retract. Remove cylinder and examine check seal. It is a small band that covers a series of holes and should fit snuggly around cylinder. Other factors that have effect on piston retraction are, split/cracked cylinder, bent driver and lack of lubrication. This gun is tricky to rebuild. Make shure that all the parts in the head are placed correctly. The kit does contain all the parts that you need. Good luck
Sep 07, 2010 | Stanley Bostitch Bt200 Brad Nailer Rebuild...
NV45AB2 worked great a year ago.hooked it up last week and it only shoots the nail 1/4 inch in a piece of wood and it wont advance the next nail.My framing nailer works so the hose presure is good.
if you havent used in a year the o rings could be dry and you can try and lubricate them, but sounds like it needs them replaced. You can try going to Nailgundepot.com and buying an o ring rebuild kit from them. It contains all the needed parts except for the grease to lube the o rings. Let me know if you need more help
Dec 23, 2009 | Hitachi NV45AB2 Roofing Coil Nailer
Leak inside Bostitch N80 Nailer, won't drive nails
If the unit is leaking it most likley need a rebuild kit. Go to a Bostitch service center and ask for an ORK-11 kit. That is all the o-rings needed to do an over haul. Or just have them do it.
May 23, 2009 | Stanley Bostitch N80s Nailer -rebuild...
Rebuilt nail gun and now it just blows air out the exhaust port
This probably is the problem,
The cylinder that the piston moves up and down inside is probably to low, and not making contact with the rubber piece in the head cap.
The cylinder has a spring that allows for movement up and down, take a pliers and gently pull up the cylinder if it does not move freely on its own. It will stop when it reaches the cylinder plate ( the part with 2 screw holes for easy removal). Be careful not to mar the cylinder though.
When reassembling the cylinder should make contact with the head cap. Hope that works!
Apr 23, 2009 | Hitachi NV45AB2S Coil Roofing Nailer
Tools & Hardware - Others Logo
Top Tools & Hardware - Others Experts
J.D. Browning
J.D. Browning
Are you a Tool and Hardware - Other Expert? Answer questions, earn points and help others
