How to connect to wifi on pro 950
I can't connect to wifi need to use a usb cable
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 99 Answers
I found this on google. Hope this helps:
Q: I've tried to install the product's software for a wireless connection, but cannot complete the installation. What should I do? A: Do the following: Important: You'll need to know your network name (SSID) and network password before you can set up your product. If you don't know them, contact the manufacturer of your router or the person who set up your network.
If you know your security settings, continue with these steps:
  1. Reset the product's network settings. Press the How to connect to wifi on pro 950 - home_button.gif home button, if necessary. Select Setup. Scroll down and select Restore Default Settings. Select Wi-Fi/Network Settings. You see a confirmation screen. Select Yes to reset the selected settings. (Select No if you want to cancel the operation.)
  2. Turn your router off and back on. Important: If your router is connected to other devices, you may need to re-establish the connection for the other devices on the network.
  3. Close all applications (including any screen savers, virus protectors, and firewall software) before you install the software.
  4. Uninstall the printer software (Windows only), then reinstall the printer software.
If the steps above for a wireless connection do not help, check the additional troubleshooting tips below, then try steps 1 through 4 again.
  • If you're setting up the printer for the first time, make sure you have the correct SSID (wireless network name) and if security is enabled, the wireless network password (WEP key or WPA passphrase). This information is stored in your network's router and you may be able to access it by logging onto the router from your computer and checking its setup screens. If you are unable to access the information, contact the person who set up your network or the manufacturer of your router or access point for details. (Epson will not be able to provide this information to you.) You'll need to know the SSID and wireless network password before you set up the printer.
    Note: The SSID and security key or passphrase are case sensitive. Be sure to correctly note uppercase, lowercase, and numeric/special letters.
  • If your wireless router or access point is set to not broadcast its Network name (SSID), you'll need to enter the SSID manually in the printer's setup software. If your wireless router or access point has wireless security enabled, you'll also need to know what kind of security it is using. Epson will not be able to provide this information to you. If you don't know this information, you'll need to contact the manufacturer of your router or the person who set up your network.
  • Make sure the product is within range of the wireless router or wireless access point.
  • Avoid placing the printer near a microwave oven, 2.4 GHz cordless phone, or large metal objects such as a filing cabinet.
  • Check to see if access restrictions, such as MAC address filtering, are set on the router or access point. If access restrictions are set, add your product's MAC address to your router's address list. If you're unsure on how to do this, contact the manufacturer of your router for instructions. To obtain your product's MAC address, print a network status sheet.
  • Disable any settings (such as AP Isolation, Client Isolation, or Privacy Separator) on your wireless router or access point that would prevent wireless devices from communicating with each other.
  • Make sure your system meets the requirements.
  • Make sure all applications (including any screen savers, virus protectors, and firewall software) are closed.
  • Make sure you have administrative rights or software installation privileges to your computer.
Posted on Nov 11, 2014
Why doesn't my tablet pick up wifi
Open your tab and check the wire or flix of your wifi connection maybe it's broken connection then fix it by soldering iron
Sep 13, 2015 | Evecase Evecae Black PU Leathe Folio tand...
Why does my macbook pro keep disconnecting from wifi?
your in an apartment an there are several more 2 ghz wireless near , you can change channels on the router an that will help.
they have a default .
this means every machine needs to be changed that contact the router wireless.
or get dual band router an a 6ghz cisco usb wireless 10.00 adapter from amazon
Jul 25, 2014 | Apple MacBook Pro Laptop Computer with...
My dad gave my son an elderly (2001) HP Pavilion xf145 notebook with windows xp. We can't figure out if we need to add a wifi card of some sort, if it can even connect to our wifi or what. It seems to...
You can use either external wifi modem and connect it to the notebook by ethernet cable or (better) use PCMCIA wifi card (second-hand e.g. from eBay?) or wifi usb modem connected direct to usb port. Just check if choosen wifi modem supports your OS WIN XP (and service pack - e.g. WIN XP SP3). In the Reference guide of the notebook is not specified USB version - it seems to be v. 1.0, so it is necessary to get an USB wifi modem compatible with USB 1.0 standard.
Nov 11, 2013 | HP Pavilion xf145 (F3413HR) PC Notebook
Do i need to use usb lead to install wifi on labtop use brother dcp j125
On most wifi printers, you need a USB cable to set it up the first time.
Aug 17, 2012 | Brother Office Equipment & Supplies
It takes 7 and a half minute to print a page. What's wrong. HP Officejet Pro 8500 Premier
It takes 7 and a half minute to print a page....
Depends on many factors my friend:
if u print big amount of data (big color pictures) through wireless connection and the WiFi connection is weak, then it takes time to collect data, evtl. stopping data-transmissions and reconnecting takes awful periods. check ur WiFi connection.
try to connect through USB and test again.
If then printing is normal, ur WiFi is to check, change security evtl. or change location of the printer to strengthen WiFi connection,
good luck
Ganimidis
Mar 04, 2011 | HP Officejet Pro 8500 Wireless All-In-One...
Theme, games and wifi
are downloading straight to cell (you need a data plan from your carrier, go to download and games) this will cost $ depending the size of theme/games and time it takes to complete.....okay #2 this way is using a laptop/pc you will need a usb cable (to fit pc) to a mini usb (compatible to your cell), go to site you wish to download game / theme download to pc........then connect cell to pc via usb go to my computer open cell...copy / paste (make sure any games downloaded is placed in the games folder on cell, themes placed in themes..
try this site also
  • http://www.zedge.net/
Dec 19, 2009 | Dopod 818 Pro Smartphone
Wifi from pc to ipod via usb
You need to connect your wifi router to the Internet connection first, then your router to your computer. After connecting, follow the setup instructions for the router.
Oct 13, 2009 | Computers & Internet
Hi i m not getting my phone with broadband net connection
For broadband you have to connect either with a LAN cable or USB cable to the PC or the WiFi way. LAN cable you cannot connect. USB cable connects to the PC and not the router. WiFi is the answer. If you have WIFi (wireless router) then all you have to do is to search for the WLAN and give the WEPkey when it asks for it. You can try to connect to the router thru USB cable if you can, I doubt, but there is no harm trying. If you do succeed, do let me know how you did it. I will spread the word around for you.
Jul 31, 2009 | HTC Touch Cellular Phone
I am trying to locate the usb port on the nikon 950.
the 950 has no USB connection, its pre USB, there is a rs232 serial port but it is incredibly slow.. i mean really slow.. hours to download a 64mb card.. its the headphone like socket under the rubber flap on the edge near the shutter button. If you don't have a cable getting one may be a problem these days
By far the best way to get pictures downloaded is with a CF card reader available from almost anywhere and would download your images in seconds over usb2 and wont need special drivers.
Happy snappin
Jun 08, 2008 | Nikon Cameras
71 people viewed this question
k24674
