Question about Zenith Televison & Video
Howtochangetv from cable to air
1988zenithswith fromcable toair
  • Zenith Master
  • 5,533 Answers
Press the AV button on remote!
Posted on Nov 11, 2014
Interior blower only blows up to warm on 1997 A4 2.7ltr
Check the blend door cable for proper attachment to the control panel and to the blend door. Try opening the door manually to see the you can get hot air out. If not, the door may be broken inside the heater box. If yes, correct/adjust the cable attachment for proper operation.
REMOVAL & INSTALLATION
1990-97 Passat Models
Install the cable ends marked with a white or blue band to the control head assembly. The cables must be attached to the control head before connection to the system air flaps.
  1. Remove the climate control head from the center dash assembly to access the control head cable ends.
  2. Remove the lower dash panels as necessary to access the cable lever arms.
  3. Attach the airflow distribution cable (cable 2) to the airflow distribution knob's lower control lever.
This cable can be identified as follows:
Operates the mode/central air flap Cable has a black sleeve and is 25.0 inches (634 mm) long Cable is marked with a white band
  1. Press the cable's sleeve against the control head stop and install the retaining clip.
  2. Attach the temperature control/air blend cable (cable 3) to the air temperature knob's control lever.
Operates the temperature control/air blend cable air flap Cable has a blue sleeve and is 21.0 inches (535 mm) long Cable is marked with a white band
  2. Attach the airflow distribution cable (cable 1) to the airflow distribution knob's upper control lever.
Operates the footwell/defroster air flap Cable has a black sleeve and is 37.5 inches (954 mm) long Cable is marked with a blue band
  1. Install the cable such that the blue band is over the retaining clip mount and install the retaining clip directly over the blue band.
  2. Install the climate control head.
  3. Set the air flow distribution knob to defrost.
  4. Connect the longest airflow cable (cable 1) to the footwell/defroster flap lever on the heater's air box.
  5. Press and hold the flap's lever toward the retaining clamp perch and install the cable retaining clip.
  6. Set the airflow distribution knob to the Vent position.
  7. Connect the short airflow cable (cable 2) to the central/mode flap's lever.
  8. Pull and hold the mode flap's lever away from the retaining clamp perch and install the cable retaining clip. Check the operation of both air flaps making sure they can be heard contacting their stops.
  9. Set the temperature control knob to full cold.
  10. Connect the blue-sleeved cable (cable 3) to the air blend/temperature flap's lever.
  11. Pull and hold the mode flap's lever away from the retaining clamp perch and install the cable retaining clip. Check the operation of the air blend/temperature flap making sure it can be heard contacting the stops.
Fig. Side view of the control head and cable location. 1. Footwell/defrost flap cable-2. Air distribution cable-3. Temperature control flap cable
Fig. Temperature flap cable location and adjustment
Nov 24, 2011 | 1998 Audi A4
The heater control knob will not turn all the way to either hot (right) or cold (left) so therefore I only get medium warm or medium cold. I assume the knob moves a cable but I cannot see it or remove the...
Cable is probably kinked or slipped adjustment. There are 2 cables connected to the knob. One move the blend door in the heater box to make the air flow thru the heater core, and the other cable opens a valve in the heater hose (engine compartment) to let the hot engine water into the heater core. Check both cables for kinks and fix and kinks. It is still doesn't work, first disconnect both cables at the blend door and valve and check the door and the valve for proper operation (can you open and close them by hand?--if not, these must be repaired or replaced), then, if good, adjust the cables according to this procedure from autozone.com:
CONTROL CABLE Adjustment
  1. Under the hood, open the clamp and disconnect the heater control valve cable from the arm.
  2. Under the dash, detach the air mix control cable from the clamp. Pull the cable from the control arm.
  3. Position the temperature control at MAX COOL.
  4. Turn the air mix control arm counterclockwise until it stops.
  5. Attach the air mix control cable to the arm.
  6. Snap the air mix cable hook into the cable clamp.
  7. Under the hood, turn the control valve to the fully closed position.
  8. Install the heater valve cable to the arm.
  9. Gently pull on the cable housing to remove any slack.
  10. Insert the cable into the clamp.
Oct 20, 2010 | 1996 Honda Accord
When i turn on heater or fan engine revs over 3000 rpm
Idle Air Control Valve Pintle may be bad If you disconnect the IAC and the problem ceases it can point to this being the problem.: Removal & Installation 3.5L Engine To Remove:
  1. Before servicing the vehicle, refer to the precautions in the beginning of this section.
  2. Remove the fuel injector sight shield.
  3. Drain the cooling system.
  4. Remove or disconnect the following:
    • The air cleaner intake duct. Figure of IAC and TPS electrical connectors disconnected. aurora_g1.gif
    • The idle air control (IAC) valve and throttle position (TP) sensor electrical connectors. Figure of cruise control and throttle control cables removed from throttle lever. aurora_g2.gif
    • The cruise control cable and throttle control cable from the throttle body lever.
    • The fuel pressure regulator vacuum hose, positive crankcase ventilation (PCV) hose and the throttle body vacuum port hose.
    • The throttle body coolant hoses.
    • The throttle control cable bracket, leaving the throttle and cruise cables connected.
    • The upper nut holding the throttle body to the intake manifold.
    • The throttle body assembly.
  5. Clean the gasket mating surfaces.
To Install:
  1. Install a new gasket and new studs if necessary.
  2. Install or connect the following:
    • Start the top nut by hand.
    • Position the throttle control cable bracket and hand start the retaining nuts and bolt.
    • Torque the three throttle body retaining nuts to 89 in.lbs. (10 Nm). And the bracket retaining bolt to 115 in.lbs. (13 Nm).
    • The throttle body vacuum port hose, PCV valve hose and the fuel pressure regulator hose.
    • The throttle control and cruise control cables to the throttle body lever.
    • The IAC valve and TP sensor electrical connectors.
    • The air intake duct.
  3. Refill the cooling system.
  4. Install the fuel injector sight shield.
4.0L Engine To Remove:
  2. Relieve the fuel system pressure.
  3. Remove or disconnect the following:
    • Negative battery cable.
    • The Mass Air Flow (MAF) sensor electrical connector.
    • The PCV valve fresh air tube. Figure of cruise control cable removed from throttle cable bracket. aurora_g3.gif
    • The cruise control cable and throttle control cable from the bracket.
    • The cruise control cable and throttle control cable from throttle body lever. Figure of IAC valve and TPS connectors removed. aurora_g4.gif
    • The idle air control (IAC) valve and throttle position (TP) sensor electrical connectors. Figure of fuel lines removed from retainer on throttle cable bracket. aurora_g5.gif
    • The fuel feed and return lines from the retainer on the throttle control cable bracket.
    • The transaxle shift cable clip from the throttle control cable bracket. Figure of throttle body removed from water crossover. aurora_g6.gif
    • The throttle body from the water crossover.
To Install:
NOTE: The Mass Air Flow (MAF) sensor inlet and the outlet of the air cleaner assembly must line up when installed. Misalignment may cause MIL illumination or driveability concerns.
  1. Install or connect the following.
    • The throttle body to the water crossover. Torque the bolts to 106 in.lbs. (12 Nm).
    • The throttle and cruise control cables to the throttle body lever.
    • The throttle and cruise control cables to the throttle control cable bracket. The transaxle shift cable clip to the throttle control cable bracket.
    • The fuel feed and return line retainer to the throttle control cable bracket.
    • The MAF sensor electrical connector.
    • The air cleaner intake duct clamp. Torque the clamp to 27 in.lbs. (3Nm).
    • The fuel injector sight shield. Torque the nuts to 20 in.lbs. (2.3 Nm).
  2. Install the negative battery cable.
  3. Pressurize the fuel system and verify no leaks.
Oct 07, 2010 | 2001 Oldsmobile Alero
How do you remove a 1999 Nissan Altima starter?
Nissan Car Altima & Sentra 1999-06 StarterRemoval & Installation
  1. Remove or disconnect the following:
    Negative battery cable Air duct Harness protector from the harness Starter wiring at the starter Starter-to-engine bolts Starter from the vehicle
    Fig. Starter location and mounting detail-3.0L Maxima with a manual transaxle
    Fig. Starter location and mounting detail-3.5L Maxima
To install:
  1. Install or connect the following:
    Starter and torque the long bolt to 57-72 ft. lbs. (77-98 Nm) on Altima and Maxima and 41 ft. lbs. (55 Nm) on 350 Z. torque the short bolt to 22-30 ft. lbs. (30-41 Nm) Starter wiring Harness protector Air duct Negative battery cable
    Negative battery cable Air inlet tube Harness bracket Wiring at the starter Starter
To install:
    Starter and torque the bolts to 60 inch lbs. (7 Nm) Starter electrical connectors Harness bracket Air inlet tube Negative battery cable
1.6L & 2.0L Engines
  2. Remove or disconnect the following:
    Negative battery cable Wiring at the starter Bolts attaching the starter to the engine Starter
To install:
    Starter and torque the bolts to 70 inch lbs. (8 Nm) Starter electrical connections Negaative battery cable
1.6L, 1.8L & 2.0L Engines
  1. Before servicing the vehicle, refer to the Precautions section.
To install:
    Starter and torque the bolts to 70 inch lbs. (8 Nm) Starter electrical connections Negative battery cable
1.8L & 2.0L Engines
To install:
2.4L & 2.5L Engines
To install:
2.4L Engine
To install:
2.5L Engine
    Negative battery cable Air cleaner cover and duct Harness bracket Wiring at the starter Starter
To install:
3.5L Engines
    Negative battery cable Air cleaner case (upper) and air cleaner to electric throttle control actuator tube. Harness protector from the harness Starter wiring at the starter Starter-to-engine bolts Starter from the vehicle
    Fig. Starter location and mounting detail-3.5L engine
continue...
Apr 05, 2010 | 1999 Nissan Altima
Yellow light blinking next toair bag light
If the light is an exclamation mark inside of a circle it is for trans problems and has to be taken to a dealer or trans shop to read codes. Normal code reader will not pull them up
Aug 28, 2009 | 2000 Ford Taurus
2001 ford focus defroster blows out ac vents
may be just a cable adjustment.
SECTION 412-01: Air Distribution and Filtering 2001 Focus Workshop Manual DESCRIPTION AND OPERATION Air Distribution and Filtering The new heating and ventilation system ensures even air distribution.
The temperature control and air distribution flaps are controlled by two operating cables. All vehicles have a recirculated air function, with the flap controlled by a servo motor.
Air is supplied to the windscreen and side windows regardless of the air distribution setting.
The clean air filter is fitted as standard in most countries. This cleans the incoming fresh air of pollen and dirt particles. It must be renewed after every 40,000 km under normal operation conditions, or after 20,000 km under difficult conditions. If no clean air filter is installed, a plastic grille is fitted over the air intake. This can easily be replaced with a clean air filter.
Air distribution operating switch
Face level The main flow of air enters the passenger compartment at face level.
Face level/floor level The main flow of air enters the passenger compartment in equal parts at face level and floor level, and a small amount flows to the demister nozzles of the side windows.
Floor level The main flow of air enters the passenger compartment at floor level, and a smaller amount flows to the demister nozzles of the side windows.
Demist/floor level The main flow of air enters the passenger compartment in equal parts at the windscreen and at floor level, and a smaller amount flows to the demister nozzles of the side windows.
Demist The main flow of air enters the passenger compartment at the windscreen and a smaller amount flows to the demister nozzles of the side windows.
Air distribution operating switch Air distribution operating cables
NOTE: The Bowden cables for LHD and RHD vehicles are identical. However, they are fastened to the air flap operating mechanism with the respective reverse side of their connectors.
The air distribution switch operates with two Bowden cables. The cables operate the air distribution valves in the heater housing.
To remove and install the cables, the rotary switch must be turned as far as it will go to the left. The air flap mechanism engages easily in this position, making the installation of the cables easier.
Air Distribution Cable Control Assembly Removal
s1y~us~en~file=ani_caut.gif~gen~ref.gif CAUTION: Disconnect the battery ground cable. For additional information, refer to Section 414-01 .
  1. Remove the radio/cassette unit and the CD player (if equipped). For additional information, refer to Section 415-01 .
  1. Remove the bezel with heater/air conditioning controls.
  1. Remove the bezel with heater/air conditioning controls (continued).
    • Pull off seven electrical connectors (six shown).
  1. NOTE: To remove the Bowden cables, turn the rotary switches as far as they will go to the left.
    • Unclip the Bowden cables.
  1. Remove the lower driver's side footwell trim.
  1. Unclip and remove the air distribution Bowden cables.
  1. Unclip and remove the temperature control Bowden cables.
    • Unclip and remove the temperature control Bowden cables.
Installation
  1. NOTE: Route the new Bowden cables without kinks and check for easy accessibility.
    NOTE: To install the Bowden cables, turn the rotary switches as far as they will go to the left. The mechanism engages easily in this position.
    NOTE: The Bowden cables are identical for RHD and LHD vehicles, although they are fastened to the air flap operating mechanism with the reverse side of their connectors.
    Install the components in reverse order.
  1. Check operation of the Bowden cables.
Mar 17, 2009 | 2003 Ford Focus
Televison & Video Logo
Top Zenith Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
