Question about Bosch Vision 300 Series 6.7 cu. ft. Electric Dryer - WTVC3300
I purchased a Bosch 300 series from Sears. My son was home when the technicians installed the washer and dryer. They connected cold water pipe with the hot water hose and the other way around. The mac
I purchased a Bosch 300 series from Sears. My son was home when the technicians installed the washer and dryer. They connected cold water pipe with the hot water hose and the other way around. The machine is working only on hot water. We waste energy and my girlfriend wants to use cold water for the delicate clothing. I switched the hose cold with cold and hot with hot and the machine stops and gives me an error. Can you help me please ?.
  • Bosch Master
  • 744 Answers
Hello Ion;
My name is Peter. I am a retired (excuse the expression) Sears field service appliance technician.
First, The people who installed your appliances are not technicians. Sears contracts delivery people to deliver appliances.
Often, It is not uncommon for me to make service calls the day after an appliance has been installed.
First, shut both the hot and cold water supply valves off. Remove the connection hoses from the valves. Be careful, where I am going with this is, after years of not being operated your shut off valves my be bad and partially block with rubber seating material. So, when you turn off the valves some water will still be in the lines. Your valves could be turned off, faulty and full open.
Now, with the hoses removed, open each water valve. Check for full flow. If you have a blocked cold water valve you will get an error code.
Next, the connections on your washer are marked; 'C' & 'H'. Make sure you have the hot water line to the 'H' and the cold water line to the 'C'. You will get an error code if the lines are reversed.
Posted on Nov 11, 2014
  • 8 Answers
SOURCE: Bosch Axxis WTL 5400 Electric Condensation Dryer...Lint Filter Light
have you checked the vent line it could be stopped up if the line is bent same affect as the lint filter being full
Posted on Dec 15, 2007
  • 191 Answers
SOURCE: Error Code
open the thing up and locate the service manual. once located it should list what that error means. alternatively call bosch and ask them.
Posted on Aug 25, 2009
SOURCE: Bosch Condenser Dryer Classixx
I found this on justanswer.com, I am going to try it this weekend and I will post an update.
"Ok if you remove the left hand side panel then located at the back is the drain pump
remove the hose on it which goes up to the bottle and blow up it to make sure its clear.
If thats fine then remove the pump and clear any fluff thats in there and make sure the impeller is ok and turning fine.
Then refit and try again hopefully this should sort it out.
let me know if you need anymore info."
Posted on Jan 02, 2010
Macmarkus
  • 2605 Answers
SOURCE: I have a Bosch Nexxt 500 series dryer. Today I was
Hello, Welcome to FixYa. There are a couple of scenarios which may prevent the dryer from starting with Bosch, but based on your post it is most likely the emergency shut off/belt switch. It is located by the motor and in the event of too heavy a load or a broken belt it shuts the unit down & prevents any restart...until it is repaired or reset. To save time and back and forth dialog, I`ll mention what to do about it. **Unplug the dryer before attempting any repair tips suggested here please...safety first** This will require you to remove the back panel. Once you've remove the rear panel, It is located next to the belt pulley and all you need to do is push it to the right ( from the back ) Let me know if you require further assistance to do this. Keep me posted how you make out or if anything is not clear. I'm presently on my iphone, but I can post more info with pictures to guide you if necessary...but please let me know. Thanks for choosing FixYa and good luck. Regards, Macmarkus :)
Posted on Dec 21, 2010
SOURCE: water tank full (!) in bosch tumble dryer WTE86301gr
As a matter of fact I have solved the problem. The dryer is now fully functioning again. :-)
I'll try to explain how to fix the problem:
The water that condenses in the condensor (doh!) drips down into a container situated below the condensor. The moist air that passes through the condensor is the same air that circulates via the clothes, thus it also contains some lint that the filter doesn't catch. Over time there will be some build-up of lint and mucus (?), clogging the tank AND a sensor that sends a signal to the electronics to start the pump that evacuates the condensed water to the removable tank in the upper part of the machine. This messes up the function of the water evacuation system.
Alright, pull out the condensor and find a hatch in the 'floor' in the farther part of the compartment. Below the hatch you'll find the container that collects the condensed water. Start by cleaning it as thoroughly as you can. There are a few 'nooks and crannies', take your time, also flush with some fresh water and maybe some gentle cleanser to get rid of the mucus. The pump and the sensor for the pump are located in the left part (viewing from front of the machine) of the container. Try to flush there as well.
If this procedure doesn't solve the problem you'll have to disassemble the machine to also be able to remove the pump and sensor housing. I had to do this on mine. Quite a few screws to remove and keep track of, but pretty straight forward if aren't too uncomfortable with 'fixing things'.
I have some pictures of the 'project' somewhere, let me know if you would like to see them or if I may help you some other way.
BR /Hans
Posted on Aug 09, 2011
My Bosch vision 300/500 DLX series washing machine continually dispenses hot water no matter what cycle I have dialed in. What can I do?
if it's hot and cold fill machine , have you got the hoses connected correctly hot to hot supply , cold hose to cold mains supply
if its cold supply only to machine , make sure it's not connected to hot water supply, this could be worth checking.
Oct 28, 2016 | Bosch Washing Machines
Bosch nexxt 300 is extremely loud and moves during spin cycle.
machine not balanced on ground, check if it rocks without lifting it off ground, if it does not balanced, adjust the ground nuts or bearings are gone
Jul 19, 2014 | Bosch Nexxt 300 Series WFMC2201UC
Just bought a new washer (refurbished, therefore doesn't come with a handbook). our old washer had both the cold and hot pipe connected, our new one (a bosch 1400 classixx) only has a white valve. do we...
You just need to collect the cold pipe- the washer does the heating itself for hot washes. It uses the water cold for rinses ;-0)
And for a manual-
you will need to type into your search engine/web browser '(make) washer manual' and you should be presented with a number of sources from which you can either download for free or have to pay a nominal amount. During the process you will be asked for the actual model number!
Good luck,
John C
Feb 24, 2011 | Bosch Classixx WFL 2066 Front Load Washer
Water is too hot
My hot and cold is reversed. The red handle is on the cold and vice versa. Check that out first.
G.
Apr 15, 2010 | Bosch Nexxt 300 Series WFMC2201UC
I have a classixx 1200 machine and there is just one fill on the back. I have just moved and am confused as the pipe is red. I fixed it to the hot water supply but water is too hot. Should it actually be...
If there is just the one water inlet connection on the rear of the washer, then you must connect it to the cold suplly, as it is designed to work of cold fill only.
Please rate my solution to your question.
Thankyou.
Feb 01, 2010 | Bosch Classixx WVF 2402 Front Load...
Getting E:13 error on Nexxt 300 series washer
Try putting the washer on COLD and run "TWO" cycles. It must be on COLD. There is a chance there is too much soap or fabric softener in the washer. It may also help to clean the fabric softener tray where you add the softener.
Nov 22, 2009 | Bosch Nexxt 300 Series WFMC2201UC
Bosch Nexxt 500 is on rinse cycle, won't drain the water or spin
Hi
I would check two things that might cause this problem .
1. there is small palstic capsule that comes out from the tank and has thin rubber pipe that goes to the electric tap. the purpuse of the tube is to send signale to the tap to close the water , actually the tap has a sensor that sence the change in presure when the water tank is filled . check this capsule and make sure that its clean.
2.looks like the cycle of washing hasn't started or started but hasn't pass the stage of heating the water . that means there is some problem with the heater that lies in the buttom of the tank . make sure all wires attached properly .
try run whashing program of cold water .
consider replacing the heater .
hope it helps
goodluck
May 25, 2009 | Bosch 3.81 cu ft WFMC530 1UC Nexxt 500...
Re dishwasher unit / sgs46m78au. water pipe/hose/ connections
The water connection is the smaller of the two and generally near the front of the machine, usually a threaded fitting on a electric solenoid will need a pipe to compression 90 fitting if its not already installed, it needs to be hooked to the hot water and that can be found on the left side going up to the sink faucet to be sure run some hot water and the side that gets warm is the correct one, you will need to turn off the water and install a T to connect the dishwasher if an unused shut off is not already there for the dishwasher. The drain line takes a hose and clamp and will hook into your drain iether through a dishwaser t or the disposal if you have one has a connection for it.
Dec 17, 2008 | Bosch SHU3305 Dishwasher
Washing maching won't rinse in cold water
hi is this hot and cold water piped machine? ie two connections on rear of machine for hot and cold pipes ? if so are your pipes connected properly on machine and the water supplies? if cold supply is connected to hot supply then wash inlet allows water in washer then washes in cold? but when rinse is due? the elec valve that has hot water pipe connected?? is failing to open allowing water flow of hot on rinse so advise recheck pipes for flow of water from both? when disconnected from machine if flow ok then possible valve blocked/faulty hope you can understand above? if you can give more info on your machine it would help to offer a remedy?
Nov 01, 2008 | Hotpoint Washing Machines
Bosch Maxx WFL 2060
connect at random. put on a rinse cycle. if cold water comes in then pipes are correct. if hot water comes in then pipes are wrong way round and just swap them
Sep 13, 2008 | Bosch Axxis WFL 2060 Front Load Washer
Bosch Vision 300 Series 6.7 cu. ft. Electric Dryer - WTVC3300 Logo
76 people viewed this question
Top Bosch Dryers Experts
Lawrence Oravetz
MightyMikeJr
Are you a Bosch Dryer Expert? Answer questions, earn points and help others
