Question about Air Tools & Compressors
<!-- from fixya rte -->How do I change from 110 to 220 volt - Air Tools & Compressors
    Master:
  • 477 Answers
Move from the USA to Europe
Posted on Nov 12, 2014
How do I change my 4322 Hobart from 220 volt to 120 volts
I do not think it can be changed to 120 . will not heat properly . elements need 220
Feb 02, 2015 | Dryers
Dash changes colors an volt volt flashes on screen?
Have you installed a battery lately? Almost sounds like the battery is in backwards
Nov 04, 2014 | Cars & Trucks
T-30 wiring changing from 460 volts to 230 volt 3 phase
There are several items that will need to be changed or replaced. First rewire motor. Remove weather head cover. On the motor will be a tag that shows how to wire for 460 volts and 230 volts.Check the tag and present wiring to make sure they match. Then look at the 230 wiring and change wiring per motor tag. Again check the motor tag to see max amps at 460 volts and 230 volts. 230 volts will be higher than 460 volts. Check the starter (if so equiped) to see how many amps its rated for. You will probably have to replace the starter. Make sure it has a 230 volt coil. Next size the overload heaters for your amperage. This conversion is not a simple task unless you're familiar with electrical . Good luck!!!
Next the starter coil will need to be replaced with a 230 volt coil
Nov 27, 2011 | Ingersoll Air Tools & Compressors
I have a old tow motor w/ a wisconsin air cooled engine . I'm looking to change the 6 volt system to 12 volt system. looking for a basic 12 volt wiring diagram for GM alt. and wisconsin parts?
to change the points to electronic you will need to get the manufacturer of the distributor and contact them for a compatible electronic kit to replace the points or replacement distributor
to fit an alternator , get one with an internal voltage regulator ( talk with an auto electrician for the best unit --it is not necessary to go big amperage units so one about 35-60 amps will suffice and cheaper as well)
wiring will be the same as will fuses (neither volt sensitive)
gauges will have to be changed to 12 volt units
bulbs changed from 6 volt to 12 bulbs and switches will be the same as they are no volt sensitive
basically the same circuit can be used and the only place to be careful is the alternator wire to the battery and the charge light or volt gauge ( auto electrician can advise here )
starter motor will have to be changed to 12 volts and you will again have to get the replacement unit from an auto electrician as the bendix pitch , movement and mounting neck will be critical
wisconsin did not make electrical components but used off the shelf companies such as delco remy, lucas , bosch, ac etc for the accessories to the engine
it is an interesting project so collect as much information from auto electricians and web sites to help you
Jun 06, 2017 | Cars & Trucks
I have a electric dryer Model WED5810SW0 THAT I WAS TOLD I COULD CONVERT TO 120V from 240v is this true and if so how do i do this?
If you consider doing this the first thing is SHUT THE MAIN BREAKER OFF. Use an auxiliary light source to see when working in a dead panel. Always keep in mind an ARC FLASH ACROSS HOT MAINS HAS ENOUGH HEAT TO PEAL THE SKIN OFF OF YOU. Before an explanation of how to do it you should keep in mind that this is for a single receptacle only. If any other receptacles are on the same circuit they will also be changed to 240 volt receptacles and if you plug any 120 volt device into them, the 120 volt device will be destroyed. That said OK, any 120 volt outlet can be changed to 240 volt by removing the 120 volt circuits neutral, re identifying the white wire with red or black phase tape and connecting it to a new 2 pole 15 amp breaker. The maximum that this circuit will now load up to is, on #14 wire at 80% = 12 amps at 240 volts. The 120V receptacle must be changed to a 15A - 240V receptacle so that 120 volt devices can not be plugged into it. Never use 2 single pole breakers together because code requires that on a fault trip both legs of the 240V circuit must be disconnected simultaneously. OR USED A Quick 220 Voltage Converting Power Supply
Voltage converter buying guide. Voltage Transformer Buying guide.Voltage converters also known as voltage transformers are devices that convert foreign electricity to power devices from different parts of the world. A step down voltage converter is a 220 to 110 volts converter. A step up converter is a 110 volts to 220 volts converter. Our 2-way converters are voltage transformers that convert power from both 220 to 110 volts and 110 to 220 volts. They also work with 100 volts, 110 volts, 120 volts, 220 volts and 240 volts. This model is a 2 way voltage converter / voltage transformer available in many different sizes including 100 watts, 200 watts, 300 watts, 500 watts, 750 watts, 1000 watts, 1500 watts, 2000 watts, 3000 watts and 5000 watts.
Sep 07, 2011 | Whirlpool Dryers
Rolling screen? Mitsubishi tv model vs 60705. It rolls right to left, but when you turn the pip on it doesn't roll on the pup screens. What is the problem? What part do I need to fix it? I already have...
I want you to know I have been where you are on this same TV and what I found is there are three ICs all in close proximity on the SIGNAL BOARD that I recommend strong you try REPLACING all caps on the ICs as follows:
IC2P02--12 volts input and 9 volts output
change C1P01 on input 47 mfd/35 volts
change C2P03 on output 100mfd/16 volts
IC2P01--11.9 volts on input and 9 volts output
change C2P04 on input 47 mfd/50 volts
change C2P05 on output 100 mfd/16 volts
IC2P03--4 volts on input pin 5 and 3.2 volts on output 1 and 3.7 volts input on pin 2 and output pin 4 is 3.2 volts.
change C2P07 47 mfd/35 volts
change C2P09 100 mfd/16 volts
I know this is a bit technical but it is what is wrong with your set. Caps have polarity (positive and negative connections) They all must be unsoldered and new ones soldered back
The Signal Board usually has the tuner on it where the coax connects. The board needs to be removed by unplugging it to change the caps.
May 21, 2011 | Mitsubishi VS-60607 TV
I'd like to know how to change a 115/230 volt pool pump motor to run on 115 volts after I've already change to internal possition to 115 volts
IF YOU SEE ON THE LABEL ON THE MOTOR HOW TO CHANGE FROM HI - LO VOLTS . THATS ALL YA GOT TO DO ..THE WIRES HOOK UP NORMALY
May 21, 2010 | Hayward 3/4hp Super Pump Inground Pool...
Diagram of wiring on Miele dryer
Hello cpopp101,
Please follow the link and goto page 30 for the electrical requirements. The manual is for the T8012 but all the dryers are the same for electrical. Goto page 30. There is usually a seperate fuse box for these (Depending on how old the dryer is) in which you may want to contact Miele to see if you have
http://www.mieleusa.com/manuals_pdf/Residential/Dryers/T8012C_8013C_us.pdf
Good luck
Sep 17, 2009 | Miele Novotronic T1515A Electric Dryer
Can the input voltage be changed in the field?
Yes you can. Then it would now operate on 12 volts.
May 26, 2009 | Xantrex Technology Xantrex DR Series...
Air Tools & Compressors Logo
53 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
