Question about Toro TimeMaster 30" Self-Propelled Lawn Mower w/ Electric Start
<!-- from fixya rte -->Blades hit each other when engaged - Toro TimeMaster 30" Self-Propelled Lawn Mower w/ Electric Start
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 140 Answers
You got a bent spindle shaft,or a timing belt issue,or the wrong blades on the unit !
Posted on Nov 12, 2014
    Champion:
  • 225 Answers
If the blades are hitting each other then they are no longer correctly timed. there is a toothed timing belt under the plastic cover on top of the cutter deck,you will need to slacken the belt and reposition blades so one is horizontal and one is vertical then tighten up the timing belt
Posted on Mar 20, 2015
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 91 Answers
Sounds like a possible bent shaft to me as well. If hitting is the only issue I would simply align the blades,loosen one blade,turn it slightly(two blade widths) so they don't touch, and retighten
Posted on Mar 19, 2015
  • Anonymous Jan 20, 2017
    cant do that with the blade adapter
Sounds like pebbles under cutting deck when blade engaged
jack up the mower and see if you can turn the blades by hand. sounds like the deck may be bend and the blade is hitting the edge. you may also see a shinny spot on the deck where it is hitting.
May 10, 2017 | Garden
Blades won't engage. I hit something, blades quit turning, check belt, its okay. When you hit button to engage blades, you hear click
When you look under the mower do you see two belts ? Top one goes to the rear axle and lower one goes to mower deck spindle.
Your description sounds like the electric clutch is engaging,so if you are seeing two belts coming off the bottom of the engine maybe the belt bounced off a idler pulley on the deck and is not tight enough.
Apr 09, 2016 | Garden
Mower blades won't engage
Did the smoking stop when you disengaged the blades? If so it is most likely your belt that is smoking. Make sure all the blades turn freely by hand to ensure you have not hit anything that may have bent a shaft on one of the blades. If one of the shafts is bent and wont turn FREELY, the belt driving the blades would slip and start smoking as it tried to turn them.
Apr 19, 2015 | Garden
After reverse, my cub cadet zero turn mower pto will not re engage the blades. sporadic up to the point of stopping altogether. is it the switch or clutch?
I would guess it is the switch. My Cub Cadet has a safety feature where the blades (PTO) stop when you hit reverse. There is an override where you turn the key back about a quarter turn or so and hit a button right above the key to make the blades run even in reverse. Therefore, I would guess the ignition switch is the problem but I can't be certain. Or it could be the electric switch that engages the PTO.
Aug 10, 2014 | Cub Cadet Garden
Toro 50" time cutter when engaging blade loud
I would remove the deck and belt, then spin each blade to isolate the loud noise. Also, make sure the blades are not bent hitting the deck. I always balance my blades after sharpening as well. By isolating the bearings spinning them one at a time, this will tell you where your problem lies. Hope this helps!
Aug 10, 2013 | Garden
Mower shuts off when blades are engaged
Remove the deck and check the blades and spindles. I suspect your issue is electrical and not mechanical though.
Sep 24, 2012 | Craftsman 21 Hp 42" Deck, Ys 4500 Lawn...
I have a 36" simplicity
There are two safety switches that work off each other when the blades are engaged. The seat switch and blade engage switch. Someone has to be in the seat when the tractor is not in neutral and or when the tractors blade engage lever is engaged. Other reasons for the tractor dying would be that the blades are hitting the deck. That could be caused by bent pulley shaft or bent blades or even a bent deck. First check the blades and make sure they spin freely by turning the tractor off and the blades are not engaged and spinning the blades (with gloves on so you do not cut your self)
Test the blades by measuring on side of the blade to the inside of the deck then rotating the blade 180 degrees and meandering it again (same side of blade 1st time measuring the blade is pointing towards the outside of the deck 2nd time of measuring the blade it is pointing to the inside of the deck). Do the same to the pulleys.If the blades are bent you may want to check the pulleys as well. sometimes both may be bent and the cost of replacing bothe is not worth it. You may want to check with a service repair person. If I can help further please contact me
Jul 06, 2011 | Garden
Cub cadet rzt 50, hit stump, blades wont engage but not bent
The blades on this cub cadet are activated with air pressure. Chances are that when you hit that stump, you either blew a fuse or the control module that allows the blades to spin. Begin by checking the fuses. J.
May 28, 2010 | Mustang Rzt 50" Zero Turn Riding Lawn...
My Cub Cadet i1042 tractor shuts off when the blade is engaged. This happened after I ran over a ***** and/or stump. Every time I try to engage the blade the engine shuts off.
Check for bent blade against deck housing.Possible you bent something on mowing deck,check all spindles and pulleys.You could have something hung on blade and making contact with deck. Rarely will the motor be hurt from hitting object on rider.
Apr 24, 2010 | Cub Cadet Street Sign- tractor lawn riding...
Zts has no Power when Blades Engaged
check your blades to make sure that they are not hitting the deck,, this would cause the knocking sound
Aug 19, 2009 | Craftsman 21 HP 42 in. Zero Turn Tractor...
Toro TimeMaster 30" Self-Propelled Lawn Mower w/ Electric Start Logo
1,375 people viewed this question
Top Toro Garden Experts
Joseph Mueller
Joseph Mueller
Mike Squire
Roland W VanLue
Roland W VanLue
Are you a Toro Garden Expert? Answer questions, earn points and help others
