Question about NetGear DG834G Router
<!-- from fixya rte -->The up and down light is not on what do I do - NetGear DG834G Router
    Master:
  • 478 Answers
Reset the router
Posted on Nov 12, 2014
Lennox G10 pilot light is out how do I light it. There is a red button next to the knob that if I press down the knob turns. Help!
Turn knob to pilot press down red button light pilot hold red button down for 45 secs let go of red button turn knob to main flame should light .
Oct 29, 2016 | Heating & Cooling
Electric window will go up but not down
either your switch or window motor have gone bad. remove switch and using a test light with ignition key on test power coming out of switch by pushing window switch up and touching wire on switch it should light the test light ( wire on test light must be grounded I like to hook it on parts where door opens to get a good ground) than test down on switch by pushing switch down and touching wire on switch again it should light test light . If it lights when switch is pushed up and down switch is good and motor is bad .if switch will not light when pushed down but does light when pushed up replace switch . if this was helpful please leave me good feed back
May 23, 2013 | Ford Econoline Cars & Trucks
Theres a ring around the disc
the ring is from the console being moved when the system was on you can resurface the disk or theres a disk replacement program but with that ring it most likely will not work
Nov 29, 2010 | Microsoft Xbox 360 Console
Xbox 360 power button light keeps flashing and disc tray does not open
Hi when the power button flashes red if you hold down the little round white button under the dvd tray and keep holding it down then press the open button for dvd then it will flash a number of lights write this down.
it will be flashing 1 2 3 or 4 lights so write it down then hold down the white button again and press the draw open button again and write down how many again.
do this 4 times all together and tell me what code it has given you then i can tell you exactly what the problem is
so for instance
you hold down the little white wireless button and keep holding it down then press the open button for the dvd tray and say 4 lights are flashin
so write down 4
then hold white button down again and press open button again
it may flash 4 again
then do it again and it may flash 2 lights
then again and it may flash 2 again
when you have gotten these 4 codes post me a message and tell me exactly what they tell you and in the correct order so it may look like this
4 lights flashing
2 lights flashing
1 light flashing
2 lights flashing
if you look at where the button is where you turn it on well you have the green light in the middle well around this is four outer lights that light up red their are 4 of these 2 at the top and 2 at the bottom either side of the green light, their the ones that flash green when its spinning rounf with green lights so write this code down then ill be able to tell you exactly what the fault is ok
let me know then i can assist you further ok
Oct 05, 2010 | Microsoft Xbox 360 Console
My light bulb fell down inside the tail light area
inside the boot unscrew the complete light assembly, unplug the wiring harness fron its socket. remove the bulbs turn unit upside down and gently shake the lost bulb out, re assemble
May 14, 2010 | 2007 Volkswagen Jetta 2.5 Sedan
The ligth drop down after start
chk your tail light bulb and groundong.. Make sure the short filiment is the one coming on with the brake light and not the tall one The tall one is the tail light element.
Nov 11, 2009 | 2006 Derbi Atlantis City 100
There is a light on the dashboard that I do not
I believe it's the washer fluid light
Here's a list of your dash lights and their meanings
Left
1. Door-ajar warning light
2. Oil pressure warning light
3. Check engine warning light
4. Tour or Sport for the ECS
5. Security indicator
Center Warning Lights
1st space down
Left: 4-wheel steering oil level warning light
Right: Brake warning light
2nd space down:
Left: Anti-lock brake warning light
Right: Active Exhaust Tour indicator
3rd space down
Left: cruise control indicator
Right: cruise control ON indicator
4th space down:
Left: charging system warning light
Right: High-beam indicator
Right Warning Lights
1st down: Not used
2nd down: Seatbelt warning light
3rd down: Washer fluid (2 storage containers)
4th down: Supplemental restraint system (SRS) warning light
Oct 07, 2009 | 1994 Dodge Stealth
Light pilot light
Turn control knob to "Pilot" and press it down. While holding knob down, light pilot with a match. After pilot lights continue to hold knob down for about one minute. When you release the knob the pilot should remain on. If it goes out then the thermocouple needs to be replaced.
Jul 18, 2009 | Pool & Spa
Changed water filter red light stays on
Afer you change the filter and have run the water for about 1 minute you then hold down the light & lock button together and this should turn the change filter light off.
Apr 23, 2009 | Refrigerators
NetGear DG834G Router Logo
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
