Need to find out where the MAP sensor located on a 2004 Chevy Cavalier 2.2 ecotec dohc
SOURCE: 2.2 ecotec engine. Code says random misfire. What
did you fix it? if you did what did you do? i have the same prblm thanks!
SOURCE: MAF Sensor 2004 Dodge Stratus
If your car has a MAF (Mass Air Flow) sensor, it would be located in the air delivery tube that runs from the air filter box to the throttle plate assembly on the intake manifold. It will have a wiring connector going to it, also. The MAF does exactly what it is called: It "senses" the volume, or "mass" of the air-flow; thusly it needs to be in the intake air tube. If you do NOT have such a device in the air-tube, you have a MAP sensor, (Manifold Absolute Pressure); this is another way of measuring the same air volume, albeit older technology. You will commonly find this device on the firewall, with a vacuum line running to the intake manifold.
I hope that this sheds some light on your question.
Thanks for choosing FixYa for advice!
SOURCE: 1998 chevy suburban map sensor
Hi, The Map sensor on a Suburban is located.
Beside of the ignition coil. on the intake.
Is a litle sensor with a connector of 3 wires.
I hope this work for you. OK
SOURCE: Crank positioner sensor on a 2005 cavalier 2.2 ecotec
hello , yes it does . otherwise known as the CKP
a picture of its location is this link .
http://www.autozone.com/addVehicleId,2968401/initialAction,repairGuide/shopping/repairGuide.htm?pageId=0900c152800a2490
SOURCE: where is knock sensor located on 2004 chevy 2500Hd
Under intake manifold on top of block,you need to remove intake to access sensors there are two of them you can't miss them when intake is off. After replacing sensors you need a new intake gasket.
