Lexmark X3350 All-In-One InkJet Printer Logo
Posted on Jul 06, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
When i double click on the removable disk,it says "Please insert a disk into Drive E :"
adhi wahyudy
Level 2:
Mentor:
An expert who has written 3 tips or uploaded 2 video tips.
  • Expert 64 Answers
  • Posted on Mar 22, 2010
adhi wahyudy
Expert
Level 2:
Mentor:
Answers
64
Questions
Helped
17534
Points
102
No need to worry, I will solve your problem follow this link to find how to solve it http://www.fixya.com/support/r4391734-usb_flashdisk_pen_drive_write_protect or you can see my blog, http://adhiwahyudy.blogspot.com, but this blog use indonesian languange
tip
Back up FAVOURITES from internet explorer
Step 1
Insert a blank disk into the floppy disk drive (or other removable disk drive).
Step 2
Double-click My Computer.
Step 3
Double-click the hard disk icon (usually C:).
Step 4
Double-click the Windows folder.
Step 5
Right-click the Favorites folder and choose Send To from the menu that appears.
Step 6
Select 3 1/2 Floppy (A) or the drive containing the blank disk. The favorites file is copied.
Step 7
Remove the disk from the drive.
Step 8
To use the favorites on this or another computer, drag the Favorites folder on the disk to the Windows folder on the computer.
on Feb 08, 2010 • Computers & Internet
7helpful
"insert a disk into drive"
right click my computer
manage
in right panel double click storage
double click disk management(Local)
right click on the pen drive shown and click format
3helpful
After insert Pen drive it detects drive but double clicking on that it shows message "insert disk drive G:"
1. Download this tool:
http://dl.dropbox.com/u/4040651/HPUSBFW.EXE
2. Format
(Before removing USB flash drive click on the Safely Remove
Hardware icon and then click on USB flash drive you want to remove)
1helpful
16 GB USB 2 MEMORY STICK I cannot format the pendrive. 2)when i double click on the removable disk,it says ''Please insert a disk into Drive E :'' 3)i used a pendrive format utility but the problem...
I'm a little confused as you mention both Drive E. which suggests Windows and gnome which suggest linux.
WARNING: Formatting the disk will erase any data on it. Do not format the disk if you are trying to get the data off it that was on it yesterday.
It is possible that the partition table has been corrupted.
If you are using windows. You can either try right clicking on the drive (not double clicking) from Windows Explorer (My Computer) and clicking format. Choose the file system type and go. Alternatively, you could work through the disk management administrative tool. Right Click on My Computer -> Manage -> Disk Management. Right click on the volume and format it.
If you are using linux, see if you have a valid partition table using fdisk for the device. Then, after creating the partition, use mkdosfs to format the drive. If you have formatted the drive as a linux partition, such as ext2, ext3, or reiserfs, it is likely that Windows will not see it as a valid drive.
3helpful
Pen drive insert disk problem.
I think there is a virus that has disabled your pen drive please follow these steps to try and remove that disability for the pen drive.
1. Click Start, and then click Run.
2. In the Open box, type regedit, and then click OK.
3. Locate, and then click the following registry key:
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\UsbStor
4. In the right pane, double-click Start.
5. In the Value data box, type 3, click Hexadecimal (if it is not already selected), and then click OK.
6. Quit Registry Editor.
Hope you like my solution.
51helpful
6answers
PLEASE INSERT A DISK INTO DRIVE(H): (pendrive problem)
1)I cannot format the pendrive. 2)when i double click on the removable disk,it says ''Please insert a disk into Drive E :'' 3)i used a pendrive format utility but the problem persists again. 4)i tried to format it using gnome also )I cannot format the pendrive. 2)when i double click on the removable disk,it says ''Please insert a disk into Drive E :'' 3)i used a pendrive format utility but the problem persists again. 4)i tried to format it using gnome also
Not able to access the Jaz Disk
Iomega has quite a bit of customer help info: https://iomega-na-en.custhelp.com Click: Other Products Then Click: JAZ 2GB Then Click: Windows XP Then Click: More Answers... Then type in "search text" area: "insert a disk" Then Click: Search Then Click: "Please insert a disk into drive X" error message when inserting or trying to read an Iomega disk If that website's search engine doesn't help, you can also log into: http://www.iomegasupportforums.com and ask the tech support people there.
Transfering pictures using the FlashPath Floppy Disk Adapter?
To transfer pictures: 1. Remove the memory card from the camera. 2. Insert the memory card into the floppy disk adapter. Make sure that you insert the memory card into the adapter with the gold side of the memory card facing you and to the right and the silver side of the adapter facing away from you. 3. Insert the floppy disk adapter into the diskette drive on your computer. 4. Double-click the PhotoMAX shortcut on your desktop to open the software. 5. Click Get Photo. 6. Click Album or FlashPath. 7. Click Downlod from FlashPath. The images appear as thumbnails on the album manager window. 8. Double-click the image that you want to edit. The image appears in the image tray. 9. Remove the FlashPath Floppy Disk Adapter from the diskette drive when you are done.
Top Lexmark Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
k24674
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
