Question about Jabra Products - BT2080 Monaural Convertible Bluetooth Headset - Sold As 1 Each - Incredibly easy to use. - Loud clear sound. - Two wearing options. - Intuitive LED displays. - Quick and easy pairing
I have a Jabra Clear that won't match up with my phone
When I turn it on, the light blinks but in following direction, I hold it down but it does not stop blinking.
The first thing I'd suggest you do is to turn your cell phone off and, if possible, remove its battery for 10 to 15 seconds. Then replace the battery and turn the phone back on. If taking the battery off the phone is not possible, simply delete everything on the Bluetooth pairing memory. Also, we will need to reset the Jabra headset to the factory settings.
Turn the headset ON. Then press and hold the volume down and answer/end buttons at the same time for approx. 5 seconds until the battery icon and Bluetooth® icon flash 5 times simultaneously - then the pairing list is reset.
Turn the headset OFF. The next time you power on, the headset will go into pairing mode as the first time you powered your new Jabra headset on.
Once in pairing mode, your cell phone should be able to add the Jabra headset as a new device from within its Bluetooth menu.
Posted on Nov 11, 2014
Hello, i cannot pair my jabra sp5050 to my htc desire hd phone. i have followed all the online instructions but cannot seem to "find" the jabra on my handset. thanks!
To get the Jabra SP5050 into pairing mode: Start with the unit turned off Press and hold the answer/end button Hold until the light starts blinking constantly, without pauses Release the button - this is pairing mode Your phone should be able to "find" it when it's in this mode.
May 13, 2011 | Jabra SP5050 Bluetooth Headset
I have 2630 nokia phone i use my jabra bt 2070 for this one and then i bought a new phone 6120 nokia but i cant use the headset on it every time i search for jabra device my phone cant find it
First turn ON your bluetooth on phone, then hold on/off button to turn ON Jabra headset for 5 SECONDS, then vill light hold ON (NO BLINKING) and then find it on your mobile phone....
Hi from Serbia ;)
Nov 23, 2010 | Jabra BT125 Headset
My Jabra headset won't pair with my phone--my phone can't "discover" the headset. The headset is charged and when it is turned on, it blinks three times in a row
Assuming you're talking about the Jabra BT2050 headset press and hold the center (round) button for at least 10 seconds; light will stay solid entering the pairing mode. Follow instructions on your phone.
Dec 14, 2009 | Jabra BT2050 Bluetooth Headset
Can i pair jabra bt125 with samsung blackjack ??
Mine is a Blackjack II, but i did get it to connect. Hold the clear button down on the Jabra until it lights solid blue, keep holding it with one hand while you use the other hand to operate your Blackjack. I went to Settings, then Connections, then Bluetooth, then "Add new device". As long as my Jabra was lit solid blue, the phone found the headset. Then it will ask you for the pin code, which i found by accident (0000 - four zero's).
Jul 11, 2009 | Jabra BT125 Headset
BT150 not going into discoverable mode
First turn on the Jabra BT 150 by holding the power button for about 4 seconds. Then hold the + key and the the power button together for about 4 seconds and the power light will go steady. Then have your bluetooth capable cell phone search. It'll find it and when asked for a PIN just enter 0000. Tjis will change the jabra power light to blinking when paired successful.
ribaf@cox.net
Feb 11, 2009 | Jabra BT150 Wireless Headset
Jabra VBT2050 Bluetooth won't pair with LG Voyager
Something similar happened to mine. It worked for 2 months, and my phone received a message from jabra to reset pass key. It did not accept, and it stopped working with my phone. I tried everything. I was told to hold the power down for 10 seconds to place in pairing mode, that did not work. This did. Hold the volume up down and the answer button down at the same time for 7 seconds. You have to make sure they are all down or it will not work. You will see that the light will stay lit continuously. This means it is in pairing mode. Then place the bluetooth on your phone on. Tap find device at the top. It will then locate the jabra. Follow any other prompts. If it asks for a passkey, or code, 0000 will suffice. Hope this helps. I looked for almost an hour and a half for the answer.
Jan 08, 2009 | Jabra BT250 Consumer Headset
Pairing Jabra BT135 with motorola L2
okay, try this, turn off the jabra headset, and then, hold the power button but hold it down until the lights flash in a different way, and make ur phone search for devices and if it finds it then its all good, just use the 0000 password to pair it.if this works give me a fix rate. thank U
Feb 11, 2008 | Motorola Mobility L2 Cellular Phone
Jabra BT 350 has stopped connecting
Hey everyone! I had the same problem, and I actually got it to work again! I hope these directions will help you get yours to work (from the manual):
1. Put the headset in pairing mode
• Make sure the headset is off.
• Press and hold the answer/end button until a solid blue light comes on. <== THIS IS VERY IMPORTANT! HOLD THE BUTTON UNTIL YOU SEE A SOLID NON-BLINKING LIGHT! (This is where I was going wrong with the directions.)
2. Set your Bluetooth phone to ‘discover’ the Jabra BT350
Follow your phone’s instruction guide. This usually involves going to a ‘setup,’ ‘connect’ or ‘Bluetooth’ menu on your phone and selecting the option to ‘discover’ or ‘add’ a Bluetooth device.
3. Your phone will find the Jabra BT350
Your phone then asks if you want to pair with it. Accept by pressing ‘Yes’ or ‘OK’ on the phone and confirm with the passkey or PIN = 0000 (4 zeros).
Nov 30, 2007 | Jabra BT350 Bluetooth Headset Headset
How to pair my Jabra BT125...
Instructions for the Jabra BT125 Bluetooth
For people who are having problems pairing their cell phone with their Jabra BR125 Bluetooth, here are a few simple steps:
First, make sure that the Jabra BT is off (the light should be off). If it's on, hold the flashing button until it goes off.
Second, turn your Jabra BT on. Continue holding your Jabra button (EVEN AFTER IT STARTS FLASHING). Hold onto it UNTIL YOU GET A SOLID LIGHT.
Third, as soon as you get a solid light try pairing up with your cell phone.
Fourth add your Jabra to your cell phone's Bluetooth list by having it search for the Jabra.
Fifth, the cell will ask for a passcode. The default passcode is 0000.
Aug 17, 2007 | Jabra BT125 Headset
Pairing with a phone
this happened to me too.. i googled a user manual for it.. if i recall it said, turn the headset power off, then once the phone is in pairing mode, hold the power button on the headset till the light stops blinking and becomes a solid blue light. then the headset is in pairing mode as well and your phone should find it
Mar 20, 2007 | Jabra BT250 Consumer Headset
Jabra Products - BT2080 Monaural Convertible Bluetooth Headset - Sold As 1 Each - Incredibly easy to use. - Loud clear sound. - Two wearing options. - Intuitive LED displays. - Quick and easy pairing Logo
81 people viewed this question
Top Jabra Radio Communications Experts
TO Lady
Greg Cann
Greg Cann
Michael Vincent Cruz
Are you a Jabra Radio Communication Expert? Answer questions, earn points and help others
