Will Amazon TV stick work with Broksonic CCVG-3276?
    Champion:
  • 203 Answers
As long as your television has an hdmi port the Amazon fire stick will work.
Posted on Dec 17, 2014
  • 8457 Answers
SOURCE: I have owned my Broksonic CCVG-3276 since October
Ur LCD inverter backlght board is dead.Replaced this board will get ur picture back.It a long board in shape.Tries Shopjimmy.com,Ebay.com to buy a refurbish LCD inverter board for the replacement.
Posted on Feb 25, 2010
budmrtn
  • 11361 Answers
SOURCE: I have a Broksonic ccvg-3285. It is a 32" LCD +
You may have 24vdc power supply problem, bad backlight inverter board/s, main board not sending out signal to turn on the 24vdc supply and the backlights board, bad T-CON board.
Please try and read the link below to get more understanding.
First, look at the screen in darkened room to see if you can see any slight glow from the screen, if it does, then the problem can be the T-CON (not getting the 12vdc) or the main logic board not feeding the signals to the T-CON board.
if not, next place to check will be the power supply module, make sure it has 24vdc which is required by the backlight inverter to work, the reason for not having 24vdc can be from bad DC filter caps (leaking/bulging top, high ESR) or short circuits in the inverter board which will cause the 24vdc supply to go into shutdown mode, so you may have to disconnect the power cable that feed the inverter board to see if the 24vdc will work without the inverter board hookup, you will need to apply about 3~4 amp of load to the 24vdc to make sure it can handle that. There are fuses on the backlight inverter boards also. So there is some troubleshooting you will have to do to find out the causes of the problem you are having.
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Or www.digikey.com, just make sure to use caps with low ESR, 105c, high ripple current and long life rating such as PANASONIC FM or FC series.
Posted on May 18, 2011
Testimonial: "This information seems key and i will revise the device considering this information.. thank you so much. i will check all of this as soon as i can. "
e-Guru
  • 3917 Answers
SOURCE: My TV has sound but
Hi
Most likely it's a faulty inverter board. The inverter is what takes the line volts from your home outlet and converts it down to a voltage that the backlights can use. Otherwise they would be damaged instantly!
A good way to make sure that everything is working except the inverter is to get the room as dark as possible and shine a flashlight at the TV while it's on and see if you can see anything on the screen. If you can see images, then it's the inverter. If not then it may be something else
Please get back to us if you have further query or else please accept the solution.
Posted on Sep 14, 2011
  • 12 Answers
SOURCE: how do i get netflix on my tv
I use my wii. connect it wirelessly
Posted on Mar 05, 2012
SD Tech
  • 14553 Answers
SOURCE: broksonic 19 inch CCVG 1935 - no sound, no picture, just a blue screen
Blue screen means either no signal (if unit has rear connections hook a DVD etc to one and go to that input and see if it works) Or the blue may mean set is in shutdown----5 months old and it should still have a warranty?
Posted on Apr 23, 2012
How do we change our Broksonic TV from analog /to digital. We do not have the remote to this tv.we will be using an antenna. Model CCVG-3276.
You will need to find either a new remote or get a substitute one. I doubt you will be able to access the menus without one.
Apr 03, 2017 | Broksonic Televison & Video
Sound thru tv. from my new computer
How do you hook up the TV to the PC? HDMI or VGA cable. There should be a green audio line mini-phone jack to hook up the audio cable from the PC to the TV using mini-stereo phone plugs.
Please clarify your setup.
May 23, 2011 | Broksonic CCVG-3276 32 in. LCD TV
The tv keeps flashing
More detailes please ! Flashing in which manner ?
Nov 02, 2010 | Broksonic CCVG-3276 32 in. LCD TV
Cracked screen on my 37"" flat scrreen broksonic
Unfortunately there is nothing you can do to repair the screen, you will need to get a replacement screen & this can be just as costly as purchasing a new TV so it might not be economical to get it repaired
May 03, 2010 | Broksonic CCVG-3276 32 in. LCD TV
Acoustic solutions tv lcd32762hdf will not turn on
Power Supply board is dead.Replaced the power supply board.Tries these websites Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Mar 17, 2010 | Broksonic CCVG-3276 32 in. LCD TV
Turn tv on tv goes on for about a minute or two and then the picture goes out but the sound stays on
COMMON PROBLEM IS LOST CONTACT OF SOME HOT PARTS,POSSIBLE AREA ON POWER SUPPLY ON THE BACK LIGH OR LCD,
Feb 28, 2010 | Broksonic CCVG-3276 32 in. LCD TV
I have owned my Broksonic CCVG-3276 since October 2008 and on June 10th, I was able to get sound but the picture went black. When I turn it off for a few minutes then back on, it works for seconds, then...
Feb 25, 2010 | Broksonic CCVG-3276 32 in. LCD TV
Tv Codes
I need the security code of mode service of my televition Broksonic model CCVG -3276
Jun 25, 2008 | Televison & Video
Televison & Video Logo
56 people viewed this question
Top Televison & Video Experts
Electro Med Services...
