Question about Polaroid New Original TTX2000AR Remote Control
My television will not come back on - Polaroid New Original TTX2000AR Remote Control
    Top Expert:
  • Polaroid Master
  • 43,113 Answers
The power supply may have failed abruptly.
Posted on Nov 11, 2014
    New Friend:
  • 26 Answers
Have you tried swithing it on with the power switch on the tv itself?
How do i remove the back of television
if you look at the back of the television there are usually a few small skrews that need to be delicately removed and carefully looked after. after all of the small screws have been removed the back can probably be removed carefully.hope this helps!
Apr 09, 2012 | Olevia LT42HVi 42 in. LCD Television
SCREEN SEEMS TO BE GETTING DARK
The problem and cause of your television is the back lights.The back lights have no supply cause of blown mounted fuse or bad or leak capacitor of back lights driver.Its also cause of loose connection in the connector of the back lights.
Aug 30, 2011 | Sony BRAVIA KDL-40S2010 40 in. LCD...
When I turn on the TV the picture comes on for about 30sec. to 1 min. then the picture goes off and the standby light(green) flashes continuously for approx. 30sec and then the pictures comes back for...
The problem with the television is that the lamp is bad and need to be replaced. This is as a result, of overheating inside the unit of the television. Be sure to have your television where there is proper vent.
Try to unplug the television for a while before working on it as the television stores high voltage in it. Then you Turn to the back of the television, then you unscrew the television and assess the lamp of the television and replace it with a new one.
Reassemble the television back together and power it on. That way it will work properly.
Dec 31, 2010 | Sony KDF-E50A10 50 in. LCD HDTV
My lamp when out so I replaced it and now I see a flashing yellow light displaying in the front, The television won't turn on.
There seem to be a problem with the television, and is power related. The television is receiving power but not utilizing it that is why you have the blinking power light, it most likely is caused by a bad capacitor on either the main panel or the power panel.
  1. Unplug the television, then get a screwdriver, a cup, replacement capacitor and a soldering iron.
  2. Turn the back of the television and unscrew it open,
  3. Then you assess the main and power board for any bad capacitor,
  4. Once you have detected the bad capacitor, melt it off from the back of the board,
  5. Then fix in a replacement capacitor and solder it back on,
  6. Then reverse the whole process to reassemble the television back together
Take care and good luck
Hope this helps you!
Dec 12, 2010 | Mitsubishi WD-65731 65" HDTV
Model #
Your model number is always posted at the back of the television either on a white paper or silver plate gummed to the back of the television or by the lower end of the back of the television or roght under the television. But it mainly used to be at the back.
Take care
Oct 11, 2010 | Televison & Video
65SWX20B 65 in. Rear Projection Television: how do i clean my Hitachi 65SWX20B 65 in. Rear Pro...
Remove the upper back cover of the television and clean the back of the screen, the mirror which reflects the image onto the screen, the focusing lenses (do not loosen or remove the wingnuts).
May 05, 2010 | Hitachi 65SWX20B 65" Rear Projection...
My RCA Home Theatre Television, P46920BL
Shorted Hori output Transistor.
May 01, 2010 | Televison & Video
TV won't come back on
You have the right idea. The problem is power. If you have had a recent electrical storm or your power grid is "dirty" (spikes and brownouts in electricity) then your television's power supply/converter could have been damaged. Or there is a short in the television. I recommend trying a couple of things before calling a local technician. First, try plugging the television into a different outlet. If the outlet was shorted out then the television could be protecting itself by shutting back down. There could also be a problem in the polarity. Most hardwar/electrical stores sell outlet testers that you just plug into the wall. The device will tell you if the outlet it working properly. If that does not work, then contact your technician. If they can repair the television then you will want to make sure you plug your television into a surge protector (not just a powerstip). Good luck. :)
Jun 19, 2008 | iLO 2600 Television
TV keeps shutting down
Sounds like it may be a bad ballast
Mar 24, 2007 | LG RU-52SZ51D 52" Rear Projection...
Polaroid New Original TTX2000AR Remote Control Logo
Top Polaroid Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Polaroid Televison and Video Expert? Answer questions, earn points and help others
