Just need to kno how to put it back on
SOURCE: program instruction garage door opener in 2005 chrysler pacifica
if your garage motor have rolling codes you need to put your car inside garage near the motor leave ignition on go to the motor locate learn button press it then quickly go to the car and press and hold one of the buttons for approximately 30 sec or until it start blinking rapidly, if you have a regular motor take one hand held opener go inside car ignition on same time press open button on handheld remote and on the car button 30 sec and it should be programmed.
SOURCE: 2006 Chrysler Pacifica serpentine belt routing
here are a couple diagrams...
If you need anything else, let me know.
SOURCE: 2007 Chrysler Pacifica heater blows cold air - A/C
Hello, seems like your thermostat may be stuck open. After the vehicle been running more than 10min feel the upper radiator hose it should be hot to the touch and if not a new thermostat is needed.
SOURCE: how to replace the rear bumper cover on a Chrysler
1. Open liftgate. 2. Remove both taillight assemblies by removing 2 hex-head bolts located in the area revealed when the liftgate is opened. 3. Remove 4 plastic retainers on the very bottom of the bumper cover in the rear. 4. Remove 2 phillips head screws in the wheel well rear lip. 5. Remove 4 pop-up plastic retainers in liftgate area. Use two screw drivers to lift the head and then pull the entire retainer out. 6. Remove a hex-head bolt from each side in the area revealed when the taillight assembly was removed. 7. Bend the bumper cover outward on each side to clear the wheel well lip and remove the bumper. Have a blanket or carpet on the ground to protect the bumper. 8. Remove metal clips from tabs that connect the upper bumper cover to the lower bumper cover. 9. Drill out pop-rivets that connect upper bumper cover to lower bumper cover. 10. Push tabs out of slots to separate the upper and lower bumper covers. 11. Release tab locks on chrome trim pieces and remove from upper bumper cover. 12. Reverse this process to replace the bumper cover.
