Question about Exercise & Fitness
Er5 treadmill reset instructions
Error 5 wat does it mean
2 Suggested Answers
Daniel S
  • 4323 Answers
SOURCE: We have model # FGHD2433KB1 dishwasher and it has
Hi
"Er S" is a common error with Frigidaire which means shorted keypad. The issue is with the touchpad/keypad that should be replaced. However, before replacing the keypad you can unplug it and take it apart completely and use a hair dryer to blow some warm air on the keypad assembly to blow the moisture off. Hope this helps...please post back for further assistance.
Daniel
Posted on Aug 09, 2011
What does the trouble code 70 h95 mean
What does the trouble code 70 h95 mean - Fixya
www.fixya.com/support/t25932829-trouble_code_70_h95_mean
28 mins ago - what does the trouble code 70 h95 mean - Bowflex Treadmills question.
What Does Your Treadmill's Error Code Mean? - LifeSpan
www.lifespanfitness.com/.../what-does-your-treadmills-error-code-mean
Free
May 21, 2015 - Please refer to the following table if your LifeSpan treadmill is displaying an error code. If after trying the suggested solutions your treadmill is .
Oct 30, 2015 | Bowflex Exercise & Fitness
What does the error code ER5 for a EDW154E Eurotech D/W mean?
e5 error is drain error. need to check all drain related items.
drain pump, drain hose, and of course garbage disposal knock out.
Jun 06, 2014 | EuroTech 24 in. EDW154E Built-in...
How do you get into the service menu of a precor 932i treadmill?
Typically on the Precor Treadmills if there are errors on the unit, you can press and hold the stop button for 3-5 seconds and it will go into the error log. Not sure what model you have.
E-2 is not what normally shows up on the screen. Do you mean Error 2 was displayed? From what I have read on Error 2's it could be a upper PCA issue, or possibly a dip in AC input during the power up sequence.
Treadmills require a dedicated line, meaning it is on its own dedicated circuit on your fuse panel/circuit breaker.
What exactly is the treadmill doing? Is it constantly showing Error 2 on the screen? Call up Precor tech support. They will be able to give you advice, and or get you connected with an authorized Precor factory trained technician who will be able to get you back up and running.
Nov 07, 2012 | Precor 932i Treadmill
How to reset treadmill T630
Dear Sir:
I will try to help you.
    • 1
When the treadmill is not in use, press the "Stop," "ENTER" and "QUICK START" buttons in rapid succession. The "RESET" button can also be used, in place of the "Stop" button.
    • 2
Press the "ENTER" button three times to access the treadmill's error log.
    • 3
Press the up or down arrows to scroll through the error codes, if necessary for club or personal logging purposes.
    • 4
To view the treadmill's odometer reading when a particular error code was elicited, press "SELECT" while a particular error code is displayed.
    • 5
To clear the error log, press "QUICKSTART" for a minimum of four seconds while viewing the list. Prompts will appear on the display and let you know when the log has been deleted
If you need further assistance, please reach me, sincerely.
God bless you.
E.CUADRA
MANAGUA, NICARAGUA. C.A.
Oct 24, 2011 | Exercise & Fitness
What does code 22 mean?
Error 22 - No Motor Pulses at Start Up
Description
Error 22 indicates that the drive motor (running belt) has been instructed to start, by either
manual or program control, and the monitoring system has not received any response from the
speed sensing system indicating that the drive motor has started.
Possible Causes
1. The treadmill utilizes an optical (infrared) speed sensor and the line of sight between the
speed sensor and the speed sensor target is obstructed.
2. Drive motor brushes are bad.
3. The speed sensor position relative to the speed sensor target is incorrect.
4. The speed sensor potentiometer adjustment is incorrect (when equipped).
5. The speed sensor is inoperative.
6. The lower PCA is bad.
7. The lower PCA to upper PCA interconnect cable is bad.
8. The upper PCA is bad
Jan 18, 2010 | Precor 9.21 Treadmill
I have a Life Fitness T3-0 which shows a "FET error".What does that mean?
FET Stuck on Error / Err 5 - This error is probably caused by the driver transistor on the motor controller is detected to be shorted out. The fix is replacing the motor controller.
Jan 13, 2010 | Life Fitness T3 Treadmill with Advanced...
My rev counter does not work on my kawasaki er5 1999
The ER5 has got an electronic rev-counter, no cable.
Like the oval rear brake-drums this is another ER5 bugbear, the rec/rec fails, the battery boils and the rev-counter is usually a victim too.
Often on ER5 specific forums there will be someone who repairs the circuit board and sells the repaired units much cheaper than a new one. it's usually a tiny zener-diode that is killed.
May 04, 2009 | 1999 kawasaki ER-5
Exercise & Fitness Logo
46 people viewed this question
Top Exercise & Fitness Experts
Electro Med Services...
Howard
Howard
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
