Question about Car Audio & Video
How can I repair cd playing making unusual noise?
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 86 Answers
Is it making popping and clicking noises? Only thing you can do is run the disc in a cleaner or disc repair machine if you don't have access to that you can take a lightly dampened super soft cloth and clean the disc from the center hole out and see if that helps.
Posted on Nov 11, 2014
CD player sound is crackly sounding
Laser, DSP or SDRAM circuit is starting to fail.
Call Iron Cross Audio for repair options
www.ironcrossaudio.com
May 17, 2012 | Harley Davidson 426290 AM/FM Radio
Humming noise from right front tire and front tire wear on the inside i changed cv joint and wheel hub still making noise
could be ball joint tie rods alignment lift it n check to see if the tire has any play wen u shoake it by grabbin both sides and just a small back n forth movement to see any unusual play. if your not good at this take it to an alignment guy n theyll check the suspension before they do anything
Sep 10, 2009 | 2003 Chevrolet Avalanche
When spinning washer making an unusually loud sound. Sounds like a bearing. Can you confirm?
Does it make the noise when spinning the drum by hand? If so, chances are you're right, the bearing is shot. No way to confirm without taking it apart and isolating the shaft and bearing then checking for noise or play. Good luck.
Aug 11, 2009 | Maytag Neptune MAH5500B Front Load Washer
Scratching sounds coming from laptop
There is lint or small scrap of paper rubbing on the cooler fan.
Without disassembly, Blow compressed air into the exhaust port while power is off, this might dislodge the debris.
Otherwise you have to remove outer cover and clean out that way.
Jul 29, 2009 | Toshiba Satellite A135-S4527 Notebook
Noise while playing cd or dvd
the top spin needs more plastic grease
Mar 11, 2009 | Audiovox VM9311TS
CD Error
No the loading mechanism has failed, it is a complicated peice of design and they are the most common thing to break on all CD players, you will have to pull the unit and send it out for repair at an authorized GM radio repair center, they are in the phone book and on line under car radio repair
Sep 06, 2008 | 2001 Cadillac DeVille
Strange noise
Unusual noises that start after a mechanical device is dropped are never good regardless of the device. I would suspect that something is physically bent or out of alignment and continuing to use the camera risks additional damage. As to if you should still use it that depends on how much its worth to you and if you plan on repairing it later.
Feb 24, 2007 | Sony Dvcam DSR-PDX10 DV Digital Camcorder
Car Audio & Video Logo
47 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
