Question about Cables 3.5MM AUDIO SPLITER 1 MALE SPLIT TO 2 FEMALE
How do I find an adapter to fit a toyota cd into my radio/cassette head unit.
What I need is the AVC-LAN split wire: 08695-00260. I have been told by Toyota UK that this part is discontinued with no alternative available. How can I fit an original factory CD player to the existing head unit? Thank you in advance for any advice which may help. Phil
Different or additional harness needed to install a Kenwood kdc 255u radio/cd player in a 2005 Scion XB?
YES.... to prevent cutting of any factory wiring (this use to be the old install method and requires much more time and expense) and potential electrical fires, you can now buy quite cheaply, what is called a Radio adapter harness.
As you wish to install a Kenwood radio to your Toyota Scion, simply buy an adapter loom which has a 2005 Toyota Plug on one end, with a Kenwood plug on the other (this essentially replaces the wiring loom that came with your Kenwood unit).
So, it's that easy .... Plug and Play.
And... if you sell your Toyota and wish to put your old Toyota radio back in, the original radio just plugs back in. PRESTO !
Hope this helps..
Cheers,
Scott
Jan 17, 2013 | Kenwood KDC 255U - radio / CD / MP3 player...
How to integrate the pioneer deh-1300mp into a 96 Dodge 2500 Centurion diesel truck to replace a radio/cassette player.
The simplest way to swap the stock radio out for the cassette player would be to go to a radioshack or bestbuy, normally they will carry a double-din to single-din adapter so that the smaller after market radio fits into the existing location snugly. They usually also carry a wiring harness adapter that will plug right into your dodges existing harness and you can just wire nut or solder & shrink wrap the adapter to the pioneers harness, saves a lot of time and insures everything is where it needs to be.
Normally you can get both adapters for under $15, hope this is helps.
Mar 08, 2011 | Pioneer DEH-1300 CD Player
How do i hook up my mp3 player to this car cd player
The only way to play an mp3 player through this head unit is through an adapter. You will need to go to Best Buy or some electronics store and buy a cd-to-cassette adapter. You just plug the adapter into the mp3 player's headphone jack and insert the cassette into the head unit. Let the cassette play and play your music through the mp3 player and boom, you have a mp3-capable head unit.
Mar 05, 2011 | JVC KS-RX177 Cassette Player
I have a Sony CFD 5250 Radio Cassette-Corder. Can I play music from an I-Pod through it? I cannot find the manual. Can I access a manual online?
The answer is yes, but the ease of doing so will vary. If the unit has an auxiliary input all you will need is a 3.5 millimeter to stereo RCA plug adapter. If it does not have an aux in then it gets more complicated, but it can be done. Do a little digging on the internet for an old cassette adapter. These were used in years gone by to allow the playing of a portable CD player through a cassette deck. The adapter looks just like a cassette, but it has a wire coming off of it with a 3.5 millimeter plug on the end. It will allow you play the I-Pod through the cassette deck just like a portable CD player.
Nov 23, 2010 | Sony CFD-S300 Radio/Cassette/CD Boombox
99 olds Intrigue factory CD player problem
I am not sure about repairing the unit. Do you have a CD cleaner?
You might check with a reputable auto electronics shop, one that specializes in car audio. They may have an adapter that will allow an aftermarket radio to be controlled from the steering wheel. Rosen makes a nice am/fm/cd/dvd navigation unit that also has XM and iPod inputs. The hard part will be to find supporting interfaces and wiring harnesses to fit a 99.
Jul 06, 2009 | 1999 Oldsmobile Intrigue
Cd player in toyota paseo
Very simple. DIN size head units fit without any adapters (assuming your car has the DIN size factory radio with pocket underneath {I have '93 Paseo and this was the setup of mine, though Crutchfield.com shows option of factory stereo with pocket and without [guessing there was a double DIN size option]}). All you need is a wiring harness. I've seen these anywhere from $5 - $20. This will connect to the wires on the harness for your new radio, then instead of cutting any of the factory wiring, you simply plug the factory harness into this new socket.
The trim ring around the radio/climate control/ashtray area is held in with clips. It just pops out (may have to use a thin screw driver to get your fingers under one of the edges to start). Four screws hold the metal frame where the head unit, climate control, and ashtray are. Take those out and pull the metal frame out a bit, then disconnect the wires of the climate control, power lead to lighter, and stereo harness and antenna. Two screws per side hold the stereo in to the metal frame. Take those out, slide out the factory radio and put in your new head unit (You will not use the metal cage or any other mounting brackets the head unit may come with). The holes on the metal frame should line up with mounting holes on the side of your new radio.
Not to endorse one vendor over another, but Crutchfield.com supplies instruction sheets and any needed install accessories free with purchase of new head unit. Their prices are often slightly higher than you can find elsewhere (comparable to retail stores, usually more than online stores), but you get the wiring harness and instruction sheets for your vehicle. At the very least, you can use their site to see what fits your vehicle (Note: Many other stores do this as well.)
May 31, 2009 | 1993 Toyota Paseo
Plastic box of wires to big for my new cd player after taking my old cassette player out
You wll need a stereo installation adapter kit. This will change the dash opening to the size you need, oftentimes by replacing an entire dash panel for a factory look.
http://www.bestbuy.com/site/olspage.jsp?skuId=8520442&type=product&id=1218019640369
Here is a link to the dash kit for your car at Best Buy. These will come with detailed instructions. Let me know if this helps :)
May 22, 2009 | 2000 Ford Focus
Wiring difference
If your installing a stock radio/cd player from another Dodge the wiring plug is the same and will fit.If your installing a aftermarket radio/cd player(JVC,Pioneer,etc)you will need to buy a adapter plug that wires up to the radio and is a direct fit to your factory wire harness,so your not cutting your wires.When you buy the adapter plug it comes with a wire diagram of which wire is what.Your aftermarket radio should have a diagram also,either on it or in the manual.Hope this helps you.
Mar 04, 2009 | 2002 Dodge Caravan
Is it possible: change cd changer input to ipod input
I'm afraid not. The best advice I can give you is to get a Radio Tuner Adapter for your I-pod. Most prople will tell you to use a Cassette adapter, and this is fine. However it sounds like you want the best sound you can get from your I-pod. The tuner adapter is the way to get it. You will get a better sound frequency range from your factory tuner than your cassette. The factory Head unit in your Sable isn't bad, just changing the factory speakers will make a huge diffrence. Good Luck, and don't forget to vote.
Jan 26, 2009 | 1998 Mercury Sable
Cables 3.5MM AUDIO SPLITER 1 MALE SPLIT TO 2 FEMALE Logo
94 people viewed this question
Top Cables Hand Tools Experts
Don Numinen
Don Numinen
Ivan
Ivan
Level 1 Expert
Bill Boyd
Are you a Cables Hand Tool Expert? Answer questions, earn points and help others
