Question about Water Heaters
My water meter runs at random any time of day or nite for no reason at all. I am on rural water and live in the country. I had the meter changed and it made no difference. I have isolated the water
My water meter runs at random any time of day or nite for no reason at all. I am on rural water and live in the country. I had the meter changed and it made no difference. I have isolated the water heater, toilet and the rest of the fixtures in the house when it runs and nothing seems to help. It will run anywhere from 3 seconds to 9 minutes. I have a drive-by reader on it and someone suggested maybe the power from this would make it run??? The water company has no suggestions for the unwanted usage. Any suggestions?? I have no leaks. When it quits running it is as if a person just turned the faucet off.
  • 46 Answers
No idea if your having the same problem,but if you have houses on both sides of you go to one or the other and some how ask to use there bathroom and have someone watch your meter at your home. flush the pot and use some water at both places. If meter moves you got it. I had a rental and the water was on 2 house with the meter in one found this out after I bought it.
Posted on Nov 11, 2014
Testimonial: "thanks for the help, but this just started about 8- months ago and I have been living here for almost 15 years.."
    Master:
  • 477 Answers
You have a ghost in the machine
Testimonial: "I wish it was Paul, it wouldn't be so expensive!!!"
mrhotandcold
  • 248 Answers
SOURCE: rheem tankless water heater error code C4 13??
check diaphrapm valve or micro/switch best of luck
Posted on Oct 31, 2009
  • 186 Answers
SOURCE: Hello, I have a 50 Gal. Whirlpool water heater
Hello. One of your heating elements is probably burned out. You should have two access covers on the heater.One near the top and one near the bottom. The bottom one is usually the firs to go because of water deposit build up. The fix is quite easy however the risk of electrocution is evident. If your fairly handy it's a matter of TURNING OFF THE POWER, draining the tank and removeing the element. If it's bad it may show signs of bulging or swelling. If you listen at the access covers while the heater is running you may hear the good one working and the bad one will be silent. The parts are available at plumbing supply stores. building centers and some hard ware stores.
builderdale
Posted on Mar 04, 2010
SOURCE: Hi, I have a Rheem RTG-74PVN-2 tankless hot water
there will need to be a recall, everyone is having the same problems across the country. Rheem is finally taking notice. Call your dealer and they may replace unit.
Posted on May 08, 2010
#1 Taper
  • 1040 Answers
SOURCE: PTG2-42PVN - When I turn on water heater it runs
C4/13 refers to the "flow control valve".
And if you are getting a C8/13 code, this refers
the last sequence in the "burner ignition".
You should contact Rheem at this link: rheem.com/
or call 1-800-432-8373 and they can recommend a local installer in your area.
Good Luck!
Jim
Posted on Oct 05, 2010
  • 5245 Answers
SOURCE: I have a recently installed richmond water heater. When the shower is running and someone turns the faucet on in the kitchen the water gets drastically colder in the shower. We didnt have that problem
Which type Richmond water heater?
Is this a tankless water heater or tank-type?
Tankless are notorious for 'cold water sandwich' under exact conditions you describe. You might need tankless with larger BTU burner.
Don't install a tankless.
http://waterheatertimer.org/Troubleshoot-Rheem-Tankless-water-heater.html
If you have tank-type water heater, then I suspect a clog in the hot water line, or single-handle faucet cartridge in show is going bad.
Same problems can contribute to tankless problems.
http://waterheatertimer.org/Low-hot-water-pressure.html
Posted on Aug 07, 2012
After city changed water meter the water is not consistently hot.
There are two things to check. First, check the inlet water filter on the heater. The changing of the meter may have introduced debris in the line and partially clogged the filter, causing flow issues that affect turn-on/turn-off of the unit. Also, the new meter may have changed the water pressure/flow rate into the house, If the filter is not the problem, have the inlet water pressure/flow rate checked. If it is too low, there may be some adjustment that can be made, or the city may have to replace the meter with a different unit.
Dec 01, 2015 | Eemax EX280T2T Series 3 Whole House...
The pilot on our hot water heater randomly goes out for no reason. What could cause this? We've replaced all the parts service guys have suggested and nothing has changed.
pilot lights go out from --not enough pressure or wind drafts than can get to the area blowing them out
check for missing shrouds to protect the flame
Nov 07, 2015 | Water Water Heaters
I do not have any water coming into my house at all the lines are not frozen and there is water at the meter
usually there is also a main water valve where the water enters the house. often times just below an outside faucet on the front of your house. or if you live in a part of the world that freezes during winter, the valve may be in a laundry room or where the water heater is located. good luck.
Mar 24, 2015 | Water Water Heaters
In-home Hot water heater; I've changed elements, both thermostats, and the electronic circuit on my circuit breaker. Is there any other reason why it is not heating up my water?
Use a test meter between elements to see if your getting continuity
and between power lead before elements. There has to be a line break if your not getting power entering elements.
Nov 29, 2014 | Water Heaters
How much gas (energy) does a rheem HT55 use per hour in average?
I think HT55 is Australian water heater.
You can add a comment and describe the product in detail since I cannot find that number listed on Rheem site.
The problem with water heater ratings is they are meant as industry comparisons for new units that are operating at peak performance. They do not account for factors at your location such as mineral build up, incoming water temperature, faulty parts, un-maintained parts, obstructed venting, etc.
To get accurate number will require work on your part:
1) You can add a gas meter to that one appliance.
2) Or look at gas meter reading at beginning of day. Digital gas meter would be necessary.
Turn off all other gas appliances, or make sure just the pilot light is only thing operating.
For a full day, let the HT55 operate normally.
Read gas meter at end of day.
Analog meter would be hard to read with only one day.
3) Another way is to look at BTU rating of all gas appliances on the same meter.
Figure weighted average of each appliance based on amount of time each appliance operates and amount of gas it consumes when running. Then figure percentage of gas that HT55 consumes. Read the gas meter one day, and then read meter again 30 days later, and take percentage that HT55 consumes.
You can find some helpful information on following link:
http://waterheatertimer.org/How-to-install-gas-water-heater.html#clean
Upvote the help.
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
May 15, 2011 | Rheem Water Heaters
Have Model EX380T2T2 Serial # 777604. Have purchased two EX630 heating elements and installed them. Water got hot for about a week. One more old heating element burned out. Fixed it by reattaching to...
A lot of problems can contribute to this problem.
As you know, tankless cannot be exposed to water with more than 11 grains of hardness.
Tankless require softener and filter system which can affect line pressure and flow, which will adversely affect tankless unit.
The problem could be clogged sensor, bad board, but still that doesn't explain burned out elements unless the elements were coated with sediment.
Sediment build up will kill a tankless within 2 years and render it useless and unfixable.
Yearly deliming will not restore functionality.
If pressure is a contributing factor, you can add a pressure tank that will even out the pressure.
All in all it looks like the pressure sensors and other sensors are crashing.
Call service technician, and glean from that person the tips and tricks.
Read the manual for advisories and required yearly maintenance.
You can fix this tankless problem yourself, same day, by installing $207 tank-type electric water heater from box store. Offer 10% less and also buy flexible connectors to connect to existing water lines. The cost of running and maintaining electric tank-type is cheaper long term. All costs are energy.
http://waterheatertimer.org/9-ways-to-save-with-water-heater.html
May 01, 2011 | Eemax EX380T2T2 Series 4 Whole House...
Pilot will not stay lit..its random..stays on for days or just a few hrs
Open following link for Bosch tankless troubleshooting resources, including Bosch contact number and link for finding service technician, etc.
http://waterheatertimer.org/Troubleshoot-Bosch-Tankless-water-heater.html
Read manual cover to cover, make sure tankless receives yearly maintenance as outline in manual.
Add a comment with your experience so others with same-similar problem can benefit.
Also take advantage of fixya expert assistance live.
Feb 23, 2011 | Bosch & Tankless LP Hot Water Heater
Electric Water Heater Using Too Much Electric.
Maybe you want to think about getting a tankless heater.The gad unit works real good.But the electric water heater i want to think you should check the thermostate.Maybe it is struck and not cutting off every time.
Mar 13, 2009 | Rheem 30 GAL ELEC SHORT Water Heater 6YR...
Sluggish gas value in tankless propane water heater
I don't think clean until you remove it.the clean it well and fine waterless lub.for it
Mar 10, 2009 | Noritz 7.1 Gpm Propane Lp Gas Tankless Hot...
Rheemglas Fury DV leaking?
Rachel,
I don't know if you have resolved your issue by changing the T&P relief valve. However, if you have replaced it and it appears to have resolved the problem ... it will most likely be only a temporary resolve. And what has happened, it that the water that was being relieved via the T&P valve is now unknowingly leaking / being relieved by a toilet or some other means.
The reason of the leak in the first place is that the most likely the water purveyor has recently installed a DCV (dual check valve) at or within the water meter location. Not knowing where you live, but we are in NC and these DVC's are being installed all over the country.
Basically, your home's plumbing system used to be an "open system" and not it is a "closed system". In earlier times, when the water heater cycled it heated the water, which cause the volume to thermally expand ... and the water was pushed backwards through the meter and it did not allow the water pressures to build. However, with the DCV installed ... now when the water heater cycles and expands water, with no place for the excess water volume to migrate, it now causes a hydraulic effect within the closed system ... which causes the water pressure to become elevated, ultiamtely being relieved at the T&P ...
Here are a couple of links from Watts ....that will help.
http://www.watts.com/pro/divisions/watersafety_flowcontrol/learnabout/learnabout_thermexpansion.asp
http://www.watts.com/pro/divisions/watersafety_flowcontrol/support/support_DETsizing.asp
Locally, we have been on the Cross Connection / Dual Check Valve crusade since early in 1991. We concur that the check valves warrant installation. However the Buidling / Plumbing Codes are not up to speed with truly what is going and how much damage to personal property is occurring with failed water lines ... both inside the home and outside.
Best, Gary H.
Hestand Associates / hestassoc@aol.com
Dec 24, 2008 | Water Heaters
Water Heaters Logo
55 people viewed this question
Top Water Heaters Experts
Donni Steen
Gil Shultz
Are you a Water Heater Expert? Answer questions, earn points and help others
