Question about Exercise & Fitness
How to reset er5 on treadmill vl0917
Wont stsrt
Weslo Cadence 340 power shut down while i was on it, tried the reset button and it actually fell inside, i took the front off and the reset button wont budge. Put the key in and I do have power, just...
If it doesn't have a fuse Only the reset button that is your over current protection, if it's broke the treadmill won't work tell it's repaired. ... hope this helps ?
Feb 24, 2015 | Weslo Cadence Treadmill 340CS
What does the error code ER5 for a EDW154E Eurotech D/W mean?
e5 error is drain error. need to check all drain related items.
drain pump, drain hose, and of course garbage disposal knock out.
Jun 06, 2014 | EuroTech 24 in. EDW154E Built-in...
No power
Check the reset/off circuit breaker located on the
treadmill frame near the power cord. If the switch
protrudes as shown, the circuit breaker has
tripped. To reset the circuit breaker, wait for five
minutes and then press the switch back in.
Mar 07, 2014 | Proform XT 70 Treadmill
My treadmill wont re-boot
follow this steps and fix it. God bless you
Unplug the treadmill. Locate the console key and place the safety or reset key into the treadmill console. Replace any parts that need replacing, or is large enough to trigger with a pencil eraser or Q-tip. Plug the treadmill plug back into the wall. Use the Q-tip to press the reset button. It may be necessary to hold the reset button down for a few seconds. "CL11" will appear in the display of the treadmill.
    • 3
Press the reset button one more time with the Q-tip. "CL21" should appear on the screen. Press the enter key. The display will change again and show "CL22." Keep pressing the enter key until the numbers cycle through to the number "CL26." Press enter one more time. The letter E should appear on the display screen.
    • 4
Press enter twice more. The letters "SS" should appear on the screen. When this happens, press the start/stop key. Making sure to keep well away from the tread, press enter to start the treadmill. The treadmill will start on its own. The treadmill will stop on its own after a few seconds. When it stops, press the power key two times. Remove the safety key and put in a safe place. Your treadmill is reset.move on to the next step.
    • 2
Locate the reset switch on the underside of the treadmill console. Usually the button
Nov 11, 2013 | Epic A30T Treadmill
Norditrack a2550 model stopped working while I was on it. The control panel will beep then light up like a Christmas tree but just goes into a nonperforming demo mode. Treadmill wont work! Help
1.
    • 1
    • 3
    • 4
    • 2
Oct 06, 2013 | Nordic Track NordicTrack Treadmill, A2550
Er5 not starting but backfiring through airbox when i try to start
air filter need changing maybe, valves maybe need adjusting
Mar 08, 2013 | Motorcycles
We just bought the floor model of the weslo cadence 58 treadmill and it wont work, we have the key, but it is not working. is there a switch we should be turning on to get it to work?
Plug in the power cord . Next, locate the reset/off circuit breaker on the treadmill frame near the power cord. Switch the circuit breaker to the reset position. Then put your safety key and it should start up for you.
May 03, 2010 | Weslo Cadence Ct 5.8 Treadmill
My rev counter does not work on my kawasaki er5 1999
The ER5 has got an electronic rev-counter, no cable.
Like the oval rear brake-drums this is another ER5 bugbear, the rec/rec fails, the battery boils and the rev-counter is usually a victim too.
Often on ER5 specific forums there will be someone who repairs the circuit board and sells the repaired units much cheaper than a new one. it's usually a tiny zener-diode that is killed.
May 04, 2009 | 1999 kawasaki ER-5
Exercise & Fitness Logo
52 people viewed this question
Top Exercise & Fitness Experts
Howard
Howard
Sportsmith LLC
Sportsmith LLC
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
