Question about Home
I have a small older atomic clock Need to know how to set time zone-controls are ---MODE--Wave +- Alarm and on/off
Need to change time zone
    Master:
  • 478 Answers
Need the make and model number to be able to help you further
Posted on Nov 11, 2014
  • 13 Answers
SOURCE: Changing Time Zone on Wind & Weather Atomic Clock
1. Press MODE to select the time with the day of week
display mode.
2. Select the time zone by pressing and holding the “ + ”
button for 3 seconds.
3. Keep holding until the desired time zone (Pacifi c,
Mountain, Central, or Eastern) is selected on the
display map
Posted on Mar 08, 2009
SOURCE: can't figure out how to set the time zone
I just pressed and held for about 3 to 5 seconds the button with the +/- on the bottom of the clock and until it showed the part of the US that I was in.
Posted on May 21, 2009
gopakumarg43
  • 75311 Answers
SOURCE: Clock Manuals How do you set time zone on Honeywell Atomic clock?
Hello
Get into this link. You can download the user manual for your Hoenywell Atomic clock. If you feel any difficulty in downloading the same, send your email address to me by FixYa. I've the downloaded manual with me, and I'll send a copy of it to you by return mail. OK.
www.honeywellcentral.com/clocks/atomic-clocks
Posted on Oct 24, 2011
gopakumarg43
  • 75311 Answers
SOURCE: how to reset an atomic clock
Hello
Get into this site. You can select and see the user manual for your SkyScan atomeic clocks here. OK.
http://www.atomicclocksstore.com/manuals
Posted on Nov 14, 2011
SOURCE: instructions for setting Sharp Atomic clock
mine is not digital it is like quartz movement there are no backup batteries in it, i put a new battery in it and hands are moving non stop.
Posted on Jun 23, 2013
How do I set the alarm on my Sharp Accu-Set Model SPC452?
  • 1 Insert batteries into your atomic clock. Without these the clock won't work. The number of batteries required depends on the clock. There is usually a panel on the back of the clock where you can insert the batteries.
  • 2 Set the clock. Usually, this is done automatically, as the clock will seek out and receive the signal within 6 to 8 minutes. If this doesn't happen, you'll need to do it yourself. Hold down the "Set" button. A figure on the clock will start blinking. Adjust this by pressing the adjustment button. Press "Set" again to go to a new time. Continue until the clock is properly set. No matter what you put time you put in manually, the clock should adjust to the atomic setting within 48 hours.
  • 3 Set the time zone on your atomic clock. How to do this depends on your specific clock. On some, there is a time zone slider; you simply slide it to your time zone. Otherwise, you will need to enter the manual mode you used to set the clock. Switch the mode until the time zone starts blinking. Now, adjust until your current time zone is selected. If it goes by Greenwich Mean Time (GMT), the time zones in the United States are -5 for Eastern time, -6 for Central, -7 for Mountain, and -8 for Pacific.
  • Read more : http://www.ehow.com/how_6403731_instructions-time-zone-atomic-clock.html
    Jan 29, 2015 | Audio Players & Recorders
    How do I adjust the settings on a 625-236 atomic clock
    If you have a Howard-Miller 625-236 atomic clock, do you need to change the time zone only or manually set the time?
    To set the time zone, press Mode (furthest left on the back of the clock) to get to the Alarm Time Mode. Then press Set (2nd from the left) to change the time zone. Then press Adjust (the middle button) to select the correct time zone. Press Mode again to exit the settings mode. To manually set the time, you need to remove the battery from the clock. Then reinsert the battery after 30+ seconds. Press and hold Set until the hour begins to flash, then press Adjust to change the time. Press and hold to quickly change the hour. Then press Set to change to the minutes and use Adjust to set the current minutes. Repeat this routine to set the seconds, month, date and year. Press Mode to exit to the Time mode.
    The manual is available here: http://www.theclockdepot.com/howard-miller-625-236-techtime-operations-manual.pdf .
    I hope this helps.
    Oct 06, 2014 | Home
    Need a user manual for skyscan model 31420e atom travel clock
    Late to the party I guess. Lots of entries for setting the clock, but not for the alarm. Press the plus or minus button. That's it. After you have the time set, you can then press the ALARM button above the WAVE/SET button to turn it on.
    May 06, 2012 | Audio Players & Recorders
    I live in Eastern Time Zone. My atomic clock shows map of USA in top right hand corner and it is set in Western Time Zone. How do I reset to Eastern Time Zone? I have had atomic clock for several years. I...
    The "mode" button is there to change the function of the + & - buttons.
    If you press the mode button several times you will cycle through the various setting features of the clock.
    Look for the one that sets the time zone and use the + or - buttons to select your zone.
    Some experimentation may be required!
    Feb 25, 2010 | Casio GW1500A-1AV G-Shock Atomic watch
    Need instruction for setting clock model # 38229-1 Atomic Clock - Sio/Scan (Equity Time). Need to set time, time zone and date. blainep
    Setting timezone: Enter alarm time preview, by pressing "Mode". Press "Adjust" to change time zone.
    Setting time: When previewing time, press and hold "Alarm on/off" Until time blinks. Press "Adjust" to change time; Press "Alarm on/off" to change to minutes, ect. Press "Mode" when done.
    Nov 29, 2009 | Audio Players & Recorders
    I need to change time zone on atomic clock to EST
    I need help setting the time zone on the sharp atomic clock model #spc364.
    Apr 18, 2009 | Bose Wave Radio
    Have a radioshack atomic wall clock model #
    1. Hold down WAVE/SET for about 2 seconds to enter the setting mode.
    2. The time zone and DST (Daylight Savings Time) blink. Press + to select your time zone. Press - to turn DST On or Off. The default setings are PST and DST On.
    3. Press WAVE/SET again to confirm the setting and enter the year setting mode.
    4. The year digits blink. Press + or - to select the year.
    5. Press WAVE/SET to confirm the year setting and enter date setting mode.
    6. The date digits blink, press + or - to select the time.
    7. Press WAVE/SET to confirm the date and enter time setting mode.
    8. The time digits blink, press + or - to select the time.
    9. Press WAVE/SET to confirm time setting and enter the clock and temperature setting.
    10. The time format and temperature blink. Press + to select between 12Hr and 24Hr format. Press - to select between Celsius and Fahrenheit.
    11. Press WAVE/SET to confirm whole setting.
    SIGNAL: To aquire the signal for the first time, place the clock near a window facing Fort Collins, CO. If it fails, it will try again every 3 hours.
    I hope this helps. I work for radioshack and i had a few extra minutes while at work.
    Brett.
    Mar 11, 2009 | SkyScan 86709 Atomic Wall Clock
    display mode.
    display map
    Jan 20, 2009 | SkyScan 86742 Digital Atomic Wall Clock
    Resetting the atomic clock to the correct time zone, and outside temp to work.
    For the Sharp SPC374T Atomic Clock - Time Zone setting- Press the 'Time' button once, the time zone will show where 'Day' usually is, use the Up or Down buttong to adjust.
    For the outdoor Thermo, credit to my neighbor for this one. Remove battery from main unit, wait 2-3 minutes. Reload batteries. Once you get a reading from the outdoor sensor, hit the reset on the main unit. You will have to reset the time zone as described above, but this worked for me after 10 months of no outside temp showing up!
    Good luck,
    Doc
    Dec 01, 2007 | Baby Gear
    Home Logo
    65 people viewed this question
    Top Home Experts
    john h
    Tom Chichester
    Are you a Home Expert? Answer questions, earn points and help others
