Question about Stoves Ovens
Atlas embassy stove - how do I turn of the automatic timer. This stove has three clocks one is for the time (how do i set time) and timer. The other two are start and end automatic there is no off set
Atlas embassy
  • chriswhite Nov 12, 2014
    Yeh fixed. These are manual clocks not digital. The repairman talked me through how to fix. The top clock said "push to manual". When pushed in turn the lower clock clockwise until it clicks then everything works.
melnavz
  • 1226 Answers
SOURCE: smeg electric oven timer controls
first is unplug the the oven from the wall outlet, to hard reset the setting. wait for almost 20 minutes then plug it again.
please tell me if there is still problem after this, melnavz
Posted on Apr 10, 2008
  • 12 Answers
SOURCE: Gaggenau EB 270/271 Electric Clock
To set the clock:
1. Press the clock key 3 items until the hr/min icon flash.
2. Press the + or - key until it come to your desired time.
3. Press the confirmation (check) key.
You have your time.
If not, call the service support.
Posted on Sep 01, 2008
  • 492 Answers
SOURCE: My GE Oven heating element and timer clock went
Try unplugging the oven and let sit for 10 min. This will reset the curcuit board and reboot the electronics. You may have to pull out the stove o get to the cord.
Posted on Apr 30, 2009
  • 547 Answers
SOURCE: oven doesn't work, stove does
If it's a Whirlpool or Kenmore oven (or one of several other brands that are made by Whirlpool) then this error code means:
F1 - E1 Safety flip flop Replace Electronic Range Control/Clock (ERC)
The system believes that the control board has failed and needs to be replaced.
This page has a list of diagnostic codes by brand and model number. You should check there to look up your particular brand to confirm what I just said.
Posted on Aug 04, 2009
barkencoa
  • 3463 Answers
SOURCE: Creda Solar Plus Model 48339N Clock/Timer not working
You have to remove the complete top assy as one unit. To do this you need to remove the side panels, there are screws at the rear, and some at the front of the oven, you will then be able to see the screws securing the top
The top then slides towards the rear, then you can gain access to the timer unit.
Hope this helps.
Posted on Dec 08, 2009
My clock does not work on my stove
Hi Jason. Have you performed the following actions?
Electronic Timing Center (Analog Clock w/Digital Display)
Synchronizing the analog and digital clocks
1. Press the "timer" and "start time" buttons simultaneously.
2. Turn the set knob to move the hands on the analog clock to any time setting.
3. After five seconds the display will go blank. Press the timer button and using the set knob, set the digital time to the exact time on the analog clock. This will synchronize the two clocks. You can now set the time of day.
Setting the Time-of-Day
The time-of-day must be set before any other program can be used. When your oven is first connected to the power in your home, the digital display will show 00:00. To program the time-of-day:
1. Push and hold the "timer" and "bake hours" button at the same time.
2. Turn the "Set" knob until correct time is displayed on the digital clock.
3. Release "timer" and "bake hours" button
The analog clock will automatically set after the digital time is set
Let me know so that I may follow up if need be.
Jul 14, 2014 | Viking DEDO205 Stainless Steel Electric...
I have a stoves 720ef oven and cannot get rid of the auto
The handbook says:-
To cancel the automatic setting and return the oven to manual operation, press the cook time and ready time buttons simultaneously. These are the second and third buttons from the left. If you have done that and it is not working, try turning the complete oven off for awhile - say 30 mins and turning back on. If this still doesn't work then it may be that the timer/clock has gone faulty.
Nov 10, 2011 | Stoves 720EF Electric Double Oven
Stoves 900 ef heritage doubel oven. I cannot seem to get the oven to work as my daughter has fiddled with the clock which has to twisting knobs - one saying cook time and the other saying start time. I...
For the 720ef , this is what you need to do. Hopefully this will translate to your 900.
There are five buttons on the clock panel and from left to right they are:- Minute Minder, Cook time, Ready Time, Plus and Minus.
TO SET THE TIME OF DAY
Press the Cook Time button and the Ready Time button simultaneously. Use the Plus and Minus buttons to set the time.(24hr clock).
TO SELECT AN ALARM TONE.
Press the Minus button to listen to the first tone. Release it and press it again to listen to the second tone etc (3 tones)
Releasing the button after the tone has sounded will automatically set that tone.
SETTING THE MINUTE MINDER.
Press the Minuter Minder button and either the Plus or Minus buttons simultaneously to set the time.
You can cancel the timer at any time by setting it back to 00.00 by using the Minus button.
After setting, the display will revert to the time of day, but by pressing the Minute Minder button again, the display will show the remaining time.
To reset the cook time, use the plus and minus buttons to set it to zero.
To cancel the automatic setting and return the oven to manual operation, press the COOK TIME and READY TIME buttons simultaneously.
I hope this helps.
Jul 28, 2011 | Stoves 720EF Electric Double Oven
Need to set clock on oven
Instructions
    • 1
      Check the oven to ensure that it is off and that the timer isn't running. The buttons used to set the clock are the same buttons that adjust the oven, and you may end up making unintended adjustments to the oven.
    • 2
      Press the "Clock" button to enter the clock setting mode. The LCD will show the current time set on the oven.
    • 3
      Use the "Set Temp/Time +" or "Set Temp/Time -" buttons to adjust the clock to the current time. Depending on your model of stove you may need to use the "Hour," "Min" or the "Temp/Hour" up and down arrow buttons to set the time.
    • 4
      Save the new clock setting by pressing the "Start" button. Depending on your stove model, you may need to press the "Clock" button a second time if the "Start" button does not work.
Read more: How to Set the Clock on a Whirl Pool Stove ' eHow.com http://www.ehow.com/how_5692616_set-clock-whirl-pool-stove.html#ixzz1H3Wfexf6
Mar 19, 2011 | Ovens
Just moved address, new house has a Stoves 720 EF built in oven.Model 059040437. I can't work out how to turn on the grill or set the timer, don't understand what any of the symbols on the front left next...
I don't know if this will help. For the 720ef , this is what you need to do.
If you want all the information, then it is best if you supply a vaild email address and this will give you access to my BT Digital Vault, where you can have a complete copy of the handbook that I have scanned in.
Jan 10, 2011 | Stoves 720EF Electric Double Oven
Can not re set time
Are you trying to reset the timer or the Clock? It's a bit different on each stove, but usually if it's the clock, you press the Clock button TWICE, the time will then begin to flash on and off. then press the + or - sign to increase or decrease the time. When you have gotten to the time you desire, PRESS the Clock button ONCE more. The time will be set, & then you should be all set :).
If it's the KITCHEN TIMER, Press the Kitchen Timer button ONCE, the timer will start flashing. It will usually flash all 0000's. Press the + sign to add minutes, then Press the Timer Button ONCE again, it will be set to the amount of time you added and will beep once the time runs out.
Disclaimer: This instruction is primarily for the General Electric Stove. If you state your specific model, I could be more specific.
Nov 12, 2010 | Ovens
Lost handbook for cooker. Cant remember which
After setting, the display will revert to the time of day, but by pressing the Minute Minder button again, the display will show the remianing time.
Dec 13, 2009 | Stoves 720EF Electric Double Oven
A (automatic cooking)remains in the digital reader which means that the electric oven/grill and fan oven won't work. It will not clear from the box.
What happens when you turn the power off to the whole oven, leave it off for a few mins and then reapply? If the automatic is still set it could be the clock is faulty.
Have you tried resetting the clock as per the handbook?
Dec 01, 2009 | Stoves 720EF Electric Double Oven
I have an old whilpool kitchen range and I moved and the timer buttons got turned. How to set the timer buttons to get the stove burners and oven to work, lost the manual.
if you have a clock where the hands go around and smaller start and stop clocks, here's what to do. set the clock to current time, push in the stop button and turn it until it stays in, then push in the start button and turn it until it pops out. try this.
Oct 15, 2009 | Whirlpool Ovens
How do I set the clock time on Stoves Cooker efa700h. I would assume the clock is the same on most stoves models
Aug 02, 2009 | Stoves 720EF Electric Double Oven
Open Questions:
Faulty obsolete (20yr old) oven thermostat with separate fan/light switch. Can't find a 'universal' replacement. If I fit a standard 2 tab thermostat, the fan and light will switch with the element Stoves oven DF550 SI with a 46thc502/G5 thermostat which controls well (if 40C higher relative to the oven thermometer). However after an overnight cool down the oven element switches on when the mains is turned back on, even though the oven control is off. I just twiddle the oven thermostat control slightly and all is well. I can't find a 250C, 1m phile, 24mmx6mm spindle thermostat with a separate connection tab for the internal recirculating fan and oven light anywhere. Otherwise the single oven cooker works and looks like new (nearly). I was wondering whether I have to piggy back a switch on the back of a standard 2 tab thermostat (or vica versa) or attach a separate switch to the oven. Can't believe I'm the only one with this problem. I'm guessing some fragile electrical contact occurs in the thermostat on cooldown to turn on the element and its in-series lamp, and this contact easily breaks by slightly turning the thermostat. ps there is no timer and I do have the circuit diagram. I found a working solution to this problem: When turning off the oven, I don't take it to the end stop. I turn it passed the click when the element and indicator turn off, then further till the ligth and fan turn off and just a fraction further but not to the end stop. Now the oven element doesnt turn on each time I turn the mains on for some other reason ( eg grill or igniters). I guess there is something wrong inside the thermostat, but this work arround seems OK if not ideal. I've marked a new stop position around the oven dial to remind me. This was easier than making a physical stop for the oven dial.
Feb 24, 2018 | Stoves Ovens
Ovens Logo
94 people viewed this question
Top Stoves Ovens Experts
ashburton
Dan Webster
Dan Webster
Are you a Stoves Oven Expert? Answer questions, earn points and help others
