Hello - I followed your instructions to someone else`s problem & got as far as I could. To access the internal parts I`m sure I need to remove the silver top - but I cannot remove the black knob o
Hello - I followed your instructions to someone else`s problem & got as far as I could. To access the internal parts I`m sure I need to remove the silver top - but I cannot remove the black knob on the top - do I have to ???? Previous thread................ SOURCE: I have a FT series Mr Coffee (Black and Silver) Could be as simple as a hose that popped loose, or as serious as a cracked tank...the only way to know for sure is to pull the bottom plate and have a look. Most retailers have a generous return policy, and you never really know what you can't have until you ask...but if this is not an option, a 30 minute project could save you the replacement cost. Remove the base plate screws* and lift easy to reveal the heater element and hoses to the water tank. *Torx screws (a star pattern) require a special driver that can be found cheap at any auto parts store. Check the hoses one at a time for leaks (cracks, dry spots, tight fit, etc) and look at the bottom of the tank for a split or crack. Place the bottom back on (no screws yet) and add a little water...If it stays, then you got it. If it leaks, lift the machine to eye level, drop the bottom out of the way, and add a little more water so you can watch for the source of the leak. A broken tank means a new machine...but a bad hose can be replaced.
    Sergeant:
  • 311 Answers
Most likely the pump on your washing machine. Coins get stuck in there and break the plastic housing. You won't need to lift up the beast-just get to the back with a flashlight.
Posted on Nov 12, 2014
SOURCE: Whirlpool LXR94 leaks in front left
I have a different model Whirpool (GSX9885JQ0), but a similar issue. I took the cover off and saw the bleach inlet hose was broken in two places. After replacing that, still leaked!! I wiped everything dry, and ran it again, and traced the leak. The water pump has a small hole worn into the side of it. The pump is located in the btoom front, just under the tub. The hole was on the left side, between the two hoses. I just looked up the schematic for your machine on Partselect.com, and it looks like you have the same exact pump...
Posted on Jul 11, 2007
huuum
  • 750 Answers
SOURCE: my bendix washing machine doesnt
Welcome bcarro10'
You said,
My Bendix washing machine doesn't fill with water instead it leaks out the bottom. I'm not sure if a connection is loose, a hose cracked or a part missing.
My name is Huuum,
I'm not sure if you search more you will, find a connection is loose, a hose cracked or a part leaking and needs replacement! As you surmised.
Or if you do not do it your self, then service will find the same!
Let me know the location of the leak when you locate it!
Cheers, and Bless You!
Please remember to leave a rating when you finish!
Thank You.Huuum
Posted on Sep 23, 2008
SOURCE: Water Leak
is the pump gray or white? if it is gray then replace it.look where the pump mounts to the ,otor and see if there is a black line coming from the middle.this is probably where your leak is.
just change the pump.
Posted on Nov 05, 2008
breddi2
  • 126 Answers
SOURCE: top loading washing machine leaking at center bottom
remove panel below door and run it. Then you can see if it is the front seal or back at pump. Two screws on bottom of panel to remove it
Posted on Apr 26, 2009
jsrock516
  • 5911 Answers
SOURCE: The bellow cracked in 3 spots and when I use the machine, water leaks out. How do I change the bellow? I have the part, just need some instruction. Thank y ou
The following link explains all the steps necessary to replace the door bellow:
http://www.fixya.com/support/r385210-replacing_door_bellow_kenmore_elite
If you have any questions along the way, please let me know. I hope this helps you.
Posted on May 14, 2009
How to replace dryer belt on stacked Maytag washer/dryer?
Hello! There is a trouble shooting guide for major appliances that frequently suggest parts and video links on youtube that diagnose your problem & instruct you how to repair your appliance. The site is called Repairclinic.com. Make sure you have the model number before you begin since the instructions are model specific. Good luck. You can also access the information by part & those parts usually have installation videos.
Jun 21, 2015 | Maytag Washing Machines
Sherwood AX-4103 amp keeps clicking
Hello there.... Check your speaker wires and then if that doesn't do it? try replacing the fuses on the back of the amp.. make sure power is turned off and unplugged. If that doesn't work? Try one speaker at a time ... something is causing the system to short out. Hopefully it is not internally
Apr 21, 2014 | Sherwood Audio Players & Recorders
How do I change the handles from right to left?
If you don't have the print instructions for your lock, go to this web page:
http://www.kaba-ilco.com/access_control/literature/literature_grid_mechanical_pushbutton_locks.aspx?id=13
On the grid, go across from L1000 to the "Manuals" column & click on PDF, which will download the file of the manual for your lock.
If you cannot open the file to view it, you need to install Adobe Reader first. You can get the download (free) from here:
http://get.adobe.com/reader/
Now you should have the manual for reference.
Someone else who was wanting to change the handle sent me this information:
"I've got a Simplex L1000 series combination that needs the Outside Lever Assembly-Right Hand and Outside Sleeve Assembly changed on it. I have the parts needed but I can't figure out how to remove the Outside Lever from the Front Lock Housing.
I had the original question. For others viewing and needing the answer it's as follows: After looking and removing the internal parts I still couldn't find the solution, so I ended up sending it to a locksmith to replace the parts. They told me later that ALL internal parts from the Front Lock Housing needed to be removed, then rotate outside lever 180 degrees. Using spanner wrench depress the front knob retainer, then outside lever should slide off. Remove Drive Assemply and Front knob retainer from rear of front lock housing. *The key was rotating the lever 180 degrees. Nowhere in the directions was this mentioned nor was it mentioned in the email reply I received from Simplex.. So for all you out there, Good Luck! And make sure to add this key step to your directions."
As you will find in the manual, you need a special spanner wrench for this operation.
The spanner wrench (SMPBC201278 Simplex:SpannerWrench $9.00) referred to can be purchased from this site:
http://www.ckilock.com/Mpage18.asp
Aug 11, 2011 | Simplex Kaba Ilco Unican L1000 keyless...
We are replacing our timing belt and water pump on our 02 toyota tundra v8 4.7 ltr engine. My dad told me to go online and get the R&R (remove & replace) on the timing belt and the timing belt...
Here's some pictures for you but there are some procedures that need to be followed when installing to make sure everything is lined up correctly. I do have the factory service manual so if you need step by step instructions from start to finish with pictures you can email me at csautomotivecars@att.net and I will make up a PDF for you for that section & email it to you. Also as far as looking for parts, I would try these guys> http://rockauto.com/. I get quite a few parts from them on a regular basis. Even hard to find parts that you can only get at the dealer and I own a shop so I do get plenty of auto parts. So if you need those instructions just email and make sure you give me your make, model, year & engine size. I know you have it here but if you email me I will never remember as I answer many questions on here. I hope these pictures help and good luck.
Aug 01, 2011 | Toyota Tundra Cars & Trucks
Can any one help me replace the infinite switch for the warming drawer on my GE gas range JGB920bec2bb Spectra XL44. Switch part number wb24k10006. Thanks. I think I need to remove the burners and top...
Hello & Welcome to FixYa
Please view this video to follow the step by step instructions in order to replace the infinite switch in your GE Gas range:
Please get back to me if you have any other questions.
Kevin
Jun 15, 2011 | Kitchen Ranges
The wiper arm on the passenger side stopped wiping. Someone told me that a small screw on the end of it probably needs tightening but I can't find it. Can you help me ?
Hello! Is the cap nut that holds the external wiper arm missing?...If so you can purchase one at any Nissan parts department...If the internal linkage is broken...The cowl cover and cowl needs to be removed to access the wiper motor linkage...The linkage comes in one piece...See photo below and cost around $60...Guru....Saailer
Jan 26, 2011 | 1996 Nissan Maxima
Someone hacked my yahoo now i cant get in they changed my pw on it.. how do i change pw so i can access my mail..i w
Try resetting it using the Yahoo! Password reset tool. Kindly click on this link:
https://edit.yahoo.com/forgotroot?done=http%3A%2F%2Fmail.yahoo.com&src=ym&partner=&intl=us
Follow the on-screen instructions and you might need other information as well so just be ready with the answers.
Once you were able to reset it, I suggest you change all the information so that your account will not be compromised again.
Sep 13, 2010 | Yahoo Mail
When I take pictures with my My Nikon coolpix L100 it does not put them on the sd card anymore, I had lent it to my daughter so I don't know if she set something on it by accident, can someone tell me how...
If you mean that the camera is putting the pics on its internal memory instead of the card, then you need to reset the camera and format the internal memory. 1.Go into the menu and find "reset"...follow the on-screen instructions. 2.Remove the card, go into the menu and find "format"...follow the on-screen instructions.
Jan 22, 2010 | Cameras
American Standard Easy Touch 6310 kitchen faucet leaks at base
you must remove the faucet form the sink. under the plate in the middle is 2 screws. remove the screws to remove the body.
Jul 15, 2009 | American Standard Kitchen Faucet 6310 020...
No Sound From Internal Speakers
go to prefrence pane select sound then output bar and arrange the volume labeling , can you hear some sound.
Jul 02, 2009 | Apple MacBook Air
Washing Machines Logo
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
