Question about Epson Office Equipment & Supplies
My Epson, when printing from my laptop, prints the long way across on the paper, not the usual when reading a letter. Not sure what I did to cause this or a mind of its own!!
How do I correct the way the printed copy prints the 'wrong' way on the paper...not the usual way if reading a letter. Guess it's difficult to explain. Does 'rotate 180 degree' have anything to do with this?
    Master:
  • 477 Answers
It is nothing to do with your printer but the printer settings on your laptop next time you go to print something open the preferences tab & change the settings from landscape to portrait , save these changes, press apply & this should solve your problem
Posted on Nov 11, 2014
New cartridges, letters in misalignment and double struck words
What Causes a Printer to Be Misaligned? ' Chron.com
smallbusiness.chron.com > ... > Setting Up a New Business Basics
A printer that has alignment problems will not print documents accurately. images and text ... Install new manufacturer's cartridges in the printer. If the cartridges ...
How to Replace & Align Canon Ink Cartridges ' Chron.com
smallbusiness.chron.com > ... > Computers
Misaligned cartridges cause poor overall print quality by producing print lines slightly... Remove the new cartridge from its packaging and remove the colored ...
PDF]Stylus Photo R300 / R300M - Product Information ... - Epsonhttps://files.support.epson.com/pdf/r300__/r300__pg.pdfEpsonEPSON Stylus Photo R300 Series - 1. Printer Parts ... asterisk (*). The printer also works with plain paper. Cartridge. Part number. Black. T048120 ... Letter. SCR1001. PremierArt Matte. Scrapbook Photo Paper for Epson. Letter ..... Unwrap the new inkcartridge. .... misaligned, align the print head (see page 11). Related ...[PDF]Epson Stylus NX430 - Quick Guidehttps://files.support.epson.com/pdf/nx430_/nx430_qr.pdfEpsonAfter you set up your Epson Stylus® NX430 (see the Start Here sheet), turn to this Quick. Guide and ..... Load letter- or A4-size paper in the sheet feeder. 2. Press ... Use the following list when you order or purchase new ink cartridges: Note: We ..
Jan 05, 2016 | Office Equipment & Supplies
Printer will scan but doesn't print all colors when printing
Hi Donald,
  • First,make sure you're printing on original Epson cartridges.
  • If the ink cartridges are old,replace them.
  • Select BEST as the quality setting.
  • For the best print qualities,use the Epson special papers which are highly designed for the best prints.
  • Make sure you load one paper at a time.
  • You may also need to do a print head cleaning on the printer to unclog the nozzles and enable smooth ink delivery.
  • Check whether the printhead needs cleaning by,
  • Turn on the printer.
  • Load a letter size paper that is plain.
  • Press setup.
  • Then press the< or > to select maintainance.
  • Press OK.
  • On the highlighted NOZZLE CHECK option,press OK.
Hope this helps.Thanks!
Please rate this answer.
Nov 10, 2011 | Epson Stylus RX580 InkJet Photo Printer
HOW TO CLEAN ROLLERS FOR EPSON RX680 PRINTER
Follow these steps to print the nozzle check:
  1. Make sure plain, letter-size paper is loaded in the sheet feeder.
  2. Make sure the CD/DVD tray is not inserted in the Epson Stylus and the CD/DVD guide is in the paper printing position.
  3. Press the Setup button.
  4. Press cp_button_41_er.gif or cp_button_42_er.gif to select Maintenance and press OK.
  5. Select Nozzle Check, then press OK.
  7. Press cp_button_6.gif Start to print the nozzle check.
Oct 28, 2010 | Epson Stylus RX680 Color All-in-One InkJet...
At college we have a w7200, how can we print across the paper rather than down it, for example a panoramic image across the width of the paper and say 20cm high
Try selecting LANDSCAPE as opposed to PORTRAIT by using the proper print menu in your application rather than the simple print icon from most tool-bars.
You can usually find it in the FILE menus
Apr 20, 2010 | Canon imagePROGRAF W7200 InkJet Printer
When I try to print paper will come out without printing
1. Try to align printhead
2. Head cleaning with epson software
3. Reinstall driver and try to print
4. Check printer component, and ensure that's no broken part
Oct 09, 2009 | Epson STYLUS R230 InkJet Photo Printer
When printing to an Epson R1800 have a problem
Make sure the paper size is not set to US letter sheetfeeder borderless use just US letter. the borderless function slightly enlarges document content to ensure that it bleeds overthe edge. If your has a bleed, use in page setup - US letter sheetfeeder borderless - In the print dialog box click printer button which brings up a warning about using a different settings dialog box, - continue on to the r1800 print dialog box. about midway down is a pull down menu - choose expansion and adjust it to the lowest setting. if your printout does not bleed to the edge bump the expansion adjustment up 1 measure.
Apr 11, 2009 | Epson Stylus Photo R1800 InkJet Printer
My photo prints have lines across them?!
the glossy paper you are using (hp) is smearing the ink... there is now ink on the feed rollers and you need to get in there and clean it all up with alcohol...also run epson matt paper for a few prints to get the color to lay down ..good luck
Oct 08, 2008 | Epson RX620 All-In-One InkJet Photo...
Out of memory printing across paper
you need a tool to reset your printer if you dont have it let me no
Aug 26, 2008 | Epson Stylus Photo R2400 InkJet Printer
Partial printing of epson TM-T88III
hi,
what you can do is to make sure that from you application you should choose the right size of paper and on the printer driver go to its printing preferences and select layout, from there you must select the roll paper.
you should be well from there..
Dec 05, 2007 | Epson TM-T88III Thermal Printer
Printing letters
If you are printing a page from online, copy and paste it onto a word processor first, then print. Printing it straight from the page may cause that problem in any printer.
Nov 12, 2007 | Epson Stylus CX3810 All-In-One InkJet...
Top Epson Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
