Question about Photography
Yes I search for the hole you told me but couldn't find it. But Am charging it right now may be it can work later. I tried all what I could but if you have any idea to help me pls kindly let me know.
    Master:
  • 477 Answers
The only other option would be to contact the manufacturer via their website & ask for their help
Posted on Nov 11, 2014
Can I charge ev warrior with standard battery charger?
Yes, But. 2 pack so 6volt each, I will assume standard lead acid batteries as the is common, and that is what the pic shows. depends on what you call standard charger, I would not do it with my 40 year old standard charger, although at a push, it will still charge them, but need to keep a check on them, later chargers, monitor the battery voltage, and adjust output to suit. All chargers work the same way, so basically yes, but keep a check on them, not running to hot etc. check voltage if you can. But they all work the same way, just later cells are used to the controlled cct of later chargers. especially with them being so called sealed, they still let gas escape, via a pin hole, If they get hot, to much gas, going out, reduces the effiency of the electrolyte, so will reduce the life, BUT as long as you keep checking them and stop if they get hot no problem, they will get warm anyway.
Jul 29, 2014 | UPG 12V 18AH Electric Bicycle Co EV...
Will oil pan gasket cause check engine light to come on
it would have to be a very bad leak to cause a vacuum leak but that big you couldn't keep oil in it most parts stores will scan it for free in hopes to sell the parts to fix it
May 30, 2012 | 2002 Chrysler PT Cruiser
MWe have one of these tvs and this morning it wont turn on although the light in front is red and it still wont turn on
I had the exact problem and couldn't do the factory reset or another reset that a Westinghouse tech told me to do over the phone - BUT I FIXED IT! This is what I did. With the TV facing me and power on and connected to my cable antenna (like normal - ready to watch TV) I took my right hand and started pressing all different buttons on the side of the TV in different order at random. All of a sudden the big W came on the screen so I called back Westinghouse technical assistance and she told me go to menu - then TV - then scroll down to channel search. Since all my cable channels are on channel 3 on the TV - the search found that channel and the picture and sound came on and works fine!
Sep 05, 2011 | Westinghouse TX-42F430S Television
Battery went flat and radio would not work after battery replacement. Local Toyota dealers need to charge $70 Au to supply me with the code. Vehicle was purchased from a used van dealer not a Toyota...
It's going to be difficult to find this code without going through the dealer. If paying $70 is the case just for a code, you might want to consider just replacing the radio altogether. Yes is will cost more than $70 to do, but you will have many more function options with todays aftermarket radios. I'm sorry you couldn't get your code for cheaper or better yet for free.
Aug 26, 2011 | Car Audio & Video
Ok so this morning I turned my laptop on and the screen was all pixilated and weird. I couldn't use my mouse and so I pressed the off button. When I later tried to turn my laptop on a black screen...
If you hear the computer booting up and sound, then yes, there may be a problem with the lcd. Unless you are VERY comfortable working with repairing computers I wouldn't suggest attempting a repair yourself.
May 24, 2011 | Computers & Internet
I have a Garmin Nuvi 255. I have had it for about a year. It has worked fine until we headed to Tulsa, OK from Columbus, OH. Most of the way there, it was fine, but about half an hour to an hour after we...
There is a reset button on the 255 i on the bottom right edge as the unit faces you, and is underneath the serial number sticker. You'll either have to peel the sticker up for access or poke a hole through it. This should get you going again. I am am also attaching a link to garmin support. Let me know how you made out. Thanks for using FixYa
http://www.garmin.com/garmin/cms/site/us/support/supportcontact
May 16, 2011 | Garmin Nuvi 255 GPS Receiver
I have yellow check engine light on in my 2008 kia rio and just took it to autozone and they ran a scan on it said misfire cylinder 1whats that mean and how can i fix it ?
I had the same problem with the engine misfire on my 2006 Kia Rio, I took it to 5 garages, I took it to Kia, they were all ****, and had no answer to the misfiring of my engine, yes the "engine light" came on all the time, and sometimes the engine light stayed on.
They all tried flushing the fuel injectors, well that didn't work, and they were confused why it didn't work and said that they couldn't fix it, some said it was a piston, and you might have to overhaul the engine, after that and lots of money spent I had the same problem and thought to myself,well that was one ******** theory, they were so bemused by the whole misfiring of this engine and said they couldn't fix it.
They ran lots of computer tests on my car with a misfiring code that showed up, but a code is just a code with no step by step instructions to fix the problem, no one couldn't fix the misfiring problem.
$1500 later I was about to give up until my sister said that she had found a descent mechanic, told him about my problem and told me to bring my car in.
Well to my amazement, he found the problem, the misfire was caused by the coil that had been shortening (an electrical shortening), and there was evidence of a burn mark on the coil, well he changed the whole coil and changed the spark plug leads and now the car doesn't misfire and works great - I hope this is a solution to your misfiring problem, I thought I would share my story about my Kia Rio misfiring problem - Have a great day everyone.
Jan 28, 2011 | 2008 Kia Rio
Photography Logo
Top Photography Experts
Tony
Are you a Photography Expert? Answer questions, earn points and help others
