Question about Tools & Hardware - Others
Which 1 3/4 siding nails will work with a Porter Cable rn174 nailer
Some coil nails have the bottom wire lower on the nail and prevents the lower bumper on the rn175 from advancing the nail. I can't find a brand that works.
    New Friend:
    Problem Solver:
  • 8 Answers
Hi Bill. I'm pretty sure the Stanley Bostitch nails will fit. Contact us & we can organise a coil for you to try. Tel 01202 855855 or email tracy@solentproducts.co.uk
Posted on Nov 24, 2014
2 Suggested Answers
  • 5603 Answers
SOURCE: I have a Porter Cable
This sounds like it might be a problem with the nails themselves. Have you tried another brand? If the place you got the nailer is nearby, ask them about the problem. Also look if the carrier strip MIGHT not be clearing and preventing the advancement of the nails. I would also try a light spray on the coil of CRC226 available at Home Depot in the electrical dept.
Posted on Oct 24, 2010
Can you use 30 degree nails in a Porter Cable FC350 34 degree nailer?
Yes, you can use 30 degree clipped head nails in the Porter-Cable FC350 framing nailer. The FC350A and FC350B nailers are newer models that specify the 30-34 degree clipped head nails. Make sure that the nails are between 2' - 3 1/2" in length. The manuals for each of the later models do not explicitly list the 30 degree nails. Their specifications page do list the 30 degree nails. See http://www.portercable.com/Products/ProductDetail.aspx?ProductID=11542 and https://www.homedepot.com/p/Porter-Cable-3-1-2-in-30-Degree-to-34-Degree-Clipped-Head-Framing-Nailer-FC350B/203555581 . The manual for the FC350 is available here: https://www.manualslib.com/manual/132288/Porter-Cable-Fc350.html . It is the same as the manual for the FC350B, https://www.homedepot.com/catalog/pdfimages/7e/7e0d0f88-a9e7-4411-ad0f-7fc5c1c1fbaa.pdf .
I hope this helps.
Mar 21, 2018 | Porter Cable Air Tools & Compressors
Porter Cable roofing nailer model are in 175 loses nails out the nose instead of shooting them often what's wrong with it
Usually, on any roofing nailer, the only nail to just drop out of the nose is the last nail of the coil. The nails are held together with two strips of wire welded to each unit. For a nail to just drop out of the nose, the two strips of wire would have to be broken or not totally welded to the nail. Poorly constructed nails will have bad welding or weak or broken wire within the roll. Carefully unwind a coil of nails and check for brittle wire or loose nails. If coils appear to be well constructed, check the condition of the tip of the driver. The driver should have a squared end to cleanly shear the two strips of wire. If the driver is rounded, the two wires will be pulled till they break off affecting the next two or three nails on the coil. Easy to check. Fire one nail, then open latch and examine the next nail to be fired. The head should be aligned with the other nails. If the head is pulled down out of alignment, the driver is not cleanly cutting the two wires. Good luck
May 09, 2013 | Air Tools & Compressors
Can My FC 350 A used 28 degree nails
The manual for your gun specifies 34-degree nails from 2 to 3 1/2 inches long. 28-degree, wire collated nails are a Stanley-Bostitch thing and they only work in their nail guns, they will not work in your nail gun. You need 34-degree, paper-tape collated nails. I know Senco framing nails will work in your gun and I think Duo-fast makes 34-drgree nails but check that before buying them.
Mar 03, 2013 | Porter Cable Factory-Reconditioned...
Jam
I have noticed that some if not all brands are now using metal wire instead of copper to make coils. Metal wire is stiffer and does not bent down out of the path of the driver. If you are using coils welded together with metal wire (some wire looks copper collored, however when tested with magnet is found to be metal), and after firing a few nails, open side door and check if the leading wire is not bending down. Leading wire will not allow the nail the fully move into the path of the driver. Stiff wire will also cause the next nail in line to pull down slightly. When nail is pulled down slightly, it will be out of the path of the driver. The driver will hit the edge of the nail and cause it to flip. The nails can also flip if the feeder is not pushing the nails fully forward due to low pressure or weak spring or springs (some nailers have a spring pushing feed piston others use air). Finally, the feed piston or the body of the nailer where the feed piston is housed could be worn. With feed piston in forward position (normal) and the feeder claw removed, apply outword pressure to feeder with thumb checking for loose fit. The feeder shaft should not be loose nor move from side to side with thumb pressure. If shaft is loose then most likey lower body of gun worn with no repair. Good luck with you nailer.
Sep 16, 2012 | Porter Cable Coil Roofing Nailer
Adjust nail depth 350 mag framing nailer
To adjust the depth of the nail on the coil 350, refer to the parts list listed below.
The safety foot, refrence # 430 or part # 904930 has a slot head bolt. Back off the bolt and move the safety foot down or up and retighten. If however the adjustment will not move enough to keep the driver from setting the nail too deep, then suspect that the bumper, refrence # 130 or part # 897337 has failed and is allowing the driver to travel down the cylinder further than normal. Easy fix. Remove the head and pull out the cylinder and driver to change the bumper. Good luck
http://www.ereplacementparts.com/porter-cable-coil350-type-coil-nailer-parts-c-129_1658_2177.html
Oct 10, 2011 | Porter Cable COIL350 3 12" Magnesium...
How do i load nails in my porter cable clipped head framing nailer...
Pull lever back on top of clip, slip sleeve of nails into slot, then release lever to push nails forward as you use nails.Make sure you are you the right gage of nail.
Jun 18, 2011 | Porter Cable FactoryReconditioned DA250BR...
Was trying to reload nails into my FC350A nailer. My hand slipped and the nail pusher slammed forward. Now I can't move the pusher to add more nails. What's wrong...nothing seems broken
Framing guns are a pain in the ****. It's the coil. Sounds like it broke free or jammed. Only solution is to take it apart. Take your time , not to difficult.
Feb 09, 2011 | Porter Cable Factory-Reconditioned...
I inherited a Bosch T31 bradder and stapler. Couldn't get any help at Home Depot chosinga nails. Bought Porter Cable 16 Ga. 1" finish nails (PFN16100-1). Released arm and slid the nail carrier...
BOSTITCH T31-1 stapler & T31-2 STAPLER and NAILER. Both use 18 gauge (very fine gauge wire). Try using 18 gauge Bostitch staples (used in BT model bostitch staplers). Good Luck
Feb 03, 2011 | Stanley Bostitch N80CB Coil Framing Nailer
Porter Cable FN250 will not advance the nails to the hammer. It appears to be an alignment problem. The nails stop on side of the hammer and not under it. It looks like the nails should be held "tighter"...
UNPLUG nailer. remove all the nails and look for a jammed nail in the magazine/ose area. Next check to make sure using the right guage nails for this tool and then look for a bent or broken driver blade. all the above could be causing you problems.
Sep 23, 2010 | Porter Cable 1" 18 Gauge Brad Nails...
Problem accessing nails
Hi, No you can't. They are two different feeds. The F33 uses tape feed and the N79 uses stick feed. The N79 is a basic wood frame nailer that uses 3 to 3 1/4 sticks, while the F33 uses up to 2 1/2 paper feed. The stick nails are the most common for the older nailers and on the box look for Bostitch as the brand to fit, as the N79 was sold under that brand not Stanley. This should Fixya!
Mar 02, 2009 | Stanley F33PT Paper Tape Framing Nail
Tools & Hardware - Others Logo
62 people viewed this question
Top Tools & Hardware - Others Experts
Are you a Tool and Hardware - Other Expert? Answer questions, earn points and help others
