Question about Dryers
I have a Roper model# rgd4440vq1 gas dryer. It will run if I hold the start button, but stops as soon as I release it. Any suggestions on where to start?
    Master:
  • 477 Answers
Put some duct tape over the start button!!
Posted on Nov 11, 2014
catriver
  • 878 Answers
SOURCE: My Dryer will only work if I hold start button, when I release start button the dryer stops.
Anra, this is a classic symptom of a failed even heat board. I've seen a lot of these failures out there. Easy to change out. Check out this link. Catriver..post back http://www.repairclinic.com/0080.asp
Posted on Mar 26, 2007
catriver
  • 878 Answers
SOURCE: My Dryer will only work if I hold start button, when start button is released the dryer stops working.
Anra, the problem is in the even heat board under the consol. This is a very easy job. Check out this link. Catriver, post back http://www.repairclinic.com/0080.asp
agitateme
  • 88 Answers
SOURCE: Dryer wont stay running
Either the motor relay, or if this is an evenheat dryer, the evenheat control board could be bad.
Posted on Jan 17, 2008
  • 686 Answers
SOURCE: Kenmore gas dryer doesn't stay running have to hold button down.
POST MODEL NUMBER, BUT IT MAY BE THE MOTOR START SWITCH.
Posted on Apr 18, 2009
maddogsteve1
  • 18 Answers
SOURCE: dryer won't stay on unless I hold the start button down. When I let go of the start button, it stops.
most likely the evenheat board is bad, but it could be the motor relay, get under the console and check the trouble shooting wiring diagram. there are several checks you can do to narrow it down.
Posted on May 25, 2009
Why want this dryer stay on ?
you have a bad belt switch,if the dryer stays running while you hold the start button on and stops when you release the button its the belt switch part WD21X10261 i've seen this a few times,go here and look at part 803 this is the bad part.
www.searspartsdirect.com/model-number/DPXR473EW0WW/0432/0151200.html
Oct 03, 2017 | GE Dryers
Old hotpoint gas dryer will not stay running starts when start button is pushed will stay running if button is held in but stops as soon as button is release
you have a bad push start button test it with a meter for continuity ohms should show ohms when pushed in and none when released
Oct 04, 2014 | Dryers
Roper dryer repair manual
90% it's the timer
Jan 30, 2014 | Dryers
Brand new roper dryer MOD RGD4440VQ1, Its gas and has a LP fitting how to change the LP fitting to PRopane. I have the conversion kit but can't find out how to install it
According to the roper site you may not change to LP gas yourself. You will need to get a licensed LP technician to make the conversion. The reason why is that they will need to adjust the flow of the Lp so that the dryer will work right. If you do not get a Lp technician to do the work then you will for fit the warranty on the Dryer.
May 28, 2011 | Roper Dryers
Apr 18, 2009 | Kenmore 73952 Gas Dryer
Dryer not drying cloths
http://www.pcappliancerepair.com/model-display.php This shows the screws (#2) that hold the front on. Use a putty knife to push on spring catches (#20) to release the top.
Jan 24, 2009 | Roper RGX4634KQ Gas Dryer
How do i access the gas coils on my roper dryer?
http://www.pcappliancerepair.com/model-display.php This is a good site for parts and help. You can see the screws #2 holding the front on. Release the spring clips #20 with a putty knife in the gap on the front.
Nov 24, 2008 | Roper RGX4634KQ Gas Dryer
Dryer starts when start button is pressed and held but will not stay running when button is released
there is a holding contact at the motor wiring, check the schematics and trace that holding contact. it should hold the motor running as soon as it starts.
tnx 4 using fixya,
drcool
Sep 14, 2008 | Kenmore Elite HE4 Electric Dryer
Dryers Logo
67 people viewed this question
Top Dryers Experts
