Question about Google Nexus 7
Okay so my tablet will not turn on after charge for a while and i have warranty on it until december 2014 how do i get it fixed?
    Master:
  • 478 Answers
Take it back to where you bought it & exchange it before the warranty runs out.
Posted on Nov 11, 2014
My tablet wont turn on or charge
Unplug the Battery, hold the Power button for 10 seconds to discharge any capacitors, Plug the battery back in, Charge the tablet until the battery reaches 100% (Factory Charger preferred), Turn it on. If this doesn't work it could be a bad battery, bad charger or bad USB connector.7 Jan 2014
SOLVED: Why won't my tablet charge or turn on? - Samsung Galaxy ...
https://www.ifixit.com/Answers/View/.../Why+won't+my+tablet+charge+or+turn+on https://www.google.co.uk/webhp?sourceid=chrome-instant&ion=1&espv=2&ie=UTF-8#q=My+tablet+wont+turn+on+or+charge
not saying any off this is going to work for you but read it anyway.
the reason i say this is because i had some one else with the same problem but it ended up it was the tablet itself was faulty.
Nov 29, 2016 | Tablets & eReaders
We bought a tablet on Dec. 5, 2014, and it just turned off and went black on Thursday, 6/11/2015 and we are unable to turn it back on. What can we do?
Contact the supplier for support, you should have a warranty for at least a year on the divice. You may need to proveide proof of purchase for service through a retailer.
Good Kick
Jun 13, 2015 | ZEEPAD 7DRK Dual Core 4.2 Blue Android...
Trio Quad Core Tablet will not charge
Either the charger or the battery is faulty, from the sound of your fault description. If the tablet will turn on and run normally when the charger is plugged in, then the problem most likely lies with the battery. If it will not run even when the charger is on, then the charger is most likely the cause of the fault. If your tablet is still under warranty, either problem should be repaired free
Jan 01, 2015 | I-INC UniK Trio AXS 3G with Wifi 7.85"...
My tablet will not turn on after chargeing i have warranty on it until december 2014 how do i get it fixed?
Nov 11, 2014 | ASUS Google Nexus 7 Tablet
Sm-T210R tablet will not turn on or charge
Plug in your tablet, hold the power button while also hold downing the home button (white, black or silver button on front of tablet beside the return key) until the battery icon shows on the tablet. If this doesn't work and you are still under warranty send it back to Samsung. If no longer under warranty you will need to remove the entire back of the Tab and disconnect the battery from the motherboard. I do not give advice on doing this and you will have to look elsewhere for that procedure. I hope the simple fix works.
Aug 28, 2014 | Samsung Tab Tablets & eReaders
Hkc tablet 7 inch multitouch screenwont turn on, overheats, doesn't charge
It sounds like the battery is incapable of holding enough of a charge to power the device. Trying to using a USB port or even the charger to power the device with a battery that is only holding a small charge may not be enough to allow it to start up.
Overheating is an indicator of something wrong. Using a charger OTHER than the one supplied could be grounds for the manufacturer to VOID your warranty - IF they find out. Opening the device is another sure-fire way to void the warranty - which will probably be evident to them when they get it back (which I think is your best solution, really).
You're in "over your head" on this, and the sooner you realize this; the better your chances of getting this fixed under warranty will be. Be smart and take advantage of the unlimited warranty. You may end up with a brand new device that solves a problem the would have been impossible for your to repair anyway.
May 21, 2014 | Tablets & eReaders
Htc wont charge and turn on
If it won't charge then you may have a defective charger, a failed battery or a loose solder joint at the charging port. If your charger plug is fitted with a fuse then consider checking the fuse is okay by trying a new one. Also, check your charger on a friends HTC, check their charger on your HTC. It really is a process of elimination to find the issue yourself.
The HTC won't turn on because it isn't charged, until you fix charging prob it won't turn on.
May 02, 2013 | HTC Flyer 7 inch 32GB Android Tablet PC...
Google Nexus 7 Logo
32 people viewed this question
Top Google Tablets & eReaders Experts
Jeff richtman
Jeff richtman
NOEL
NOEL
Are you a Google Tablet and eReader Expert? Answer questions, earn points and help others
