Question about HP HEWLETT PACKARD Designjet 130 printer C7791CA2L
HP Designjet 130 not initializing...
Hi I have a dj 130 printer that gets stuck in the initializing screen. All that is shown when starting up the printer is the hourglass icon and then nothing else happens. When you press the power button the display backlight goes on for a few seconds and then shuts down again. And the Orange warning led flashes. There's also no movement from any of the parts in the printer other than the PSU fan. I have replaced the power supply and also the electronics module as the printer had some problems beforehand and didn't power up. I have run the startup track mode and the printer gets stuck with the two squares on 64 and 128 which gives me the error 192: initializing VPPA. I have also reseated all the wires and nothing seems to work. If somebody would be able to assist me with this issue I would greatly appreciate the help. Regards Pieter
  • HP Master
  • 1,915 Answers
If there a jetdirect network card trying removing it and restarting.
Posted on Nov 12, 2014
Testimonial: "Thank you for the feedback Mark, but unfortunately this printer doesn't have a jetdirect network card installed."
2 Suggested Answers
yungwun639
SOURCE: pls., help. my hp designjet 130 does only shows the busy icon on the display after pressing the power-on button. it will not even initialize
had the same issue with a designjet 100 plus. I downloaded the service manual, opened it up, reseated every cable (be careful with this). **** thing started up like nothing was wrong.
Posted on Jul 24, 2012
What part do I need to replace
Hello. What you are describing is a failing component on the power supply. Some part is working momentarily and then heats up and fails. Replace the power supply and you will likely fix the plotter. Power supplies can be ordered from: 0950 2623R HP Designjet 700 750C 755CM Power Supply
Jul 20, 2015 | HP DesignJet 750c plus InkJet Printer
Hp designjet 130 carriage moves to the left and will not stop
If the printer has ink cartridges, check to make sure one of them did not come "undone" and is stickup up slightly. If so, just press it back in place.
May 04, 2014 | HP Hewlett Packard C7791C - Designjet 130...
Pls., help. my hp designjet 130 does only shows the busy icon on the display after pressing the power-on button. it will not even initialize
May 23, 2012 | HP DesignJet 130NR InkJet Printer
My HP DesignJet 500 plotter printer doesn't recognize any of the 4 ink cartridges
>Your have new cartridges,not refilled right?
>Remove cartridges,
>Remove right door,
>Check ISS unit cables,PCB & connectors as shown in snap shot,
Most of the cases ISS arrested with ink leakage from cartridges, result connectors,PCB tracks & cables got damaged.. check perfectly if found shoot the problem....
> Replace ISS unit,, But only professionals can do the replacement..
*** Reading, writing & initializing the backup EEROM located in ISS unit, if any thing goes wrong both ISS & Formatter assm will loose their memory..be careful..
Dec 05, 2011 | HP DesignJet 500 InkJet Printer
HP Designjet 130 shows no ink on display but cartridges are full
Remove the cartridges and give them a good shake - this should fix the problem!
Aug 10, 2009 | HP DesignJet 130 InkJet Printer
Test page
from the printer driver go to start menu then go to settings then chose printer and right click on the printer icons chose properties then chose print test page
Sep 06, 2008 | HP Designjet 130gp InkJet Printer
Colour problems when printing with dj 130
I had similar problems when I first installed the printer and after different tests we found out that the Magenta ink print head was faulty. Changed head to a new one and problem solved. You will need to recalibrate and do paper set up's again.
Aug 16, 2008 | Designjet Black Designjet 30/130 Series...
HP HEWLETT PACKARD Designjet 130 printer C7791CA2L Logo
183 people viewed this question
Seeker5211
Seeker5211
