Question about Panasonic Televison & Video
How do you reset the lamp hours on a Panasonic PT-61LCX66-K
Reset hours of lamp on a Panasonic PT-61LCX6-K
    Sergeant:
  • 295 Answers
There probably is a service manual you can find on line to help you with how to reset the lamp hours.
http://www.manualowl.com/m/Panasonic/PT52LCX66/Manual/289575
Posted on Nov 13, 2014
  • 19 Answers
SOURCE: reset lamp meter on Panasonic PT-43LC14 television
While TV is on, simultaneously press and hold both the TV's Volume Down button and the remote's PP/Play button for 7 seconds.
Posted on Jul 01, 2008
SOURCE: Need to reset the lamp timer / Panasonic PT-43LC14
hold the volume down on the TV and press and hold down the MUTE button on the remote control. Be sure to hold both buttons down at the same time and until the red light goes out.
This worked for me.
Posted on May 03, 2009
  • 2336 Answers
SOURCE: how to reset a panasonic dlp lamp hours?
Try the following:
If you need to get into the service menu, you can do so by following these directions:
With power on, hold down VOL minus button on projection display and hold down the PIP or SPLIT button (try both) on the remote simultaneously for more than 5 seconds.
You can also click here to get more instructions if the above do not work. See post # 4.
Posted on Jun 17, 2009
  • 3 Answers
SOURCE: Panasonic PT-50LC13 reset hour meter
on the tv itself push the volume down button and at the same time using the remote control press the pip button. I just did this on my tv - had the same problem. it worked perfectly. Jeanne
Posted on Jul 25, 2009
johnnydiode
  • 647 Answers
SOURCE: Lamp reset on a panasonic model pt-50lc14-k
This works for mos Panasonics
Turn on Power
Pres and hold the "vol-" button on the front of unit and the "split" key on the remote together for over 5sec.
Screen should say " Lamp time was reset to 0"
Posted on Nov 12, 2009
How to reset the hour meter on a panasonic pt-52lcx16
Panasonic Projection TV Lamp Timer Reset
Your lamp will probably last a lot longer than the TV thinks it should. This procedure will reset the lamp timer so you don't have to look at that annoying message every time you turn your tv on. Remember that the "lamp" indicator light on the lower left of the set will stay on until the lamp is actually replaced. I had to buy a replacement lamp to get this information, could not find it anywhere for these model numbers.
Press the volume down button on the projection display and hold down the zero button on the remote control at the same time for more than 5 seconds. When the reset procedure is complete, a message will display that the lamp timer was reset to zero.
This procedure will work for Panasonic models: PT-52LCX66 , PT-56LCX66 , PT-61LCX66 , PT-52LCX16 , PT-56LCX16 , PT-61LCX16
Jul 20, 2014 | Panasonic PT-52LCX16
Tip
Panasonic PT-61LCX66 Lamp Timer Reset Models No. PT-52LCX66 / PT-56LCX66 /...
Models No. PT-52LCX66 / PT-56LCX66 / PT-61LCX66
Models No. PT-52LCX16 / PT-56LCX16 / PT-61LCX16
Here are the steps to reset the Lamp Timer for your Panasonic Multimedia Projection HDTV:
  1. Plug your Television in.
  2. Press the POWER button on the TV or the remote control.
  3. Press and hold the VOL- button on the TV, while holding the 0 button on the remote control for at least 5 seconds.
  4. When the reset procedure is complete, a confirmation screen will appear.
  5. Release the buttons and the LAMP indicator will go out.
Download the TYLA1001 Replacement Lamp Installation instruction guide here.
I hope that helps.
on Apr 11, 2010 | Panasonic PT-61LCX66 Television
Tip
Panasonic PT-56LCX66 Lamp Timer Reset Models No. PT-52LCX66 / PT-56LCX66 /...
I hope that helps.
on Apr 11, 2010 | Panasonic PT-56LCX66 56" HDTV
How to reset the lamp meter on a panasonic pt-52lcx16
Jul 20, 2014 | Panasonic Pt-52lcx16-b Replacement Rear...
How to reset the meter on a panasonic pt-52lcx16
Panasonic Projection TV Lamp Timer Reset r
Tip
Panasonic PT-52LCX66 Lamp Timer Reset Models No. PT-52LCX66 / PT-56LCX66 /...
I hope that helps.
on Apr 11, 2010 | Panasonic PT-52LCX66 Projection Television
Tip
Panasonic PT-52LCX16 Lamp Timer Reset Models No. PT-52LCX66 / PT-56LCX66 /...
I hope that helps.
on Apr 11, 2010 | Panasonic 52LCX1516 52 in. Television
When I turn my tv on, there is a box that comes on and says replace lamp bulb and lamp timer, I changed the bulb but I do not know how to change the timer?
I can help you reset the lamp timer for your Panasonic PT-61LCX66 Projection HDTV.
Follow the steps in my Fixya Tip for the complete lamp timer reset procedure.
I hope that helps.
Mar 28, 2010 | Panasonic PT-61LCX66 Television
Tip
Panasonic TYLA1001 Lamp Reset Models No. PT-52LCX66 / PT-56LCX66 / PT-61LCX66...
Download the TYLA1001 Replacement Lamp Installation Instruction guide here.
I hope that helps.
on Apr 11, 2010 | Panasonic TYLA1001 TYLA1001 Projector Lamp
Tip
Panasonic TYLA1001 Manual Lamp Replacement Instructions Models No. PT-52LCX66 /...
Are you missing the Installation Instructions for your Panasonic TYLA1001 Replacement Projector Lamp?
A digital, pdf version of the TYLA1001 Lamp Replacement Instructions can be downloaded from here.
Once installed, reset the lamp timer of your Panasonic Multimedia Projection HDTV by following these steps.
I hope that helps.
Televison & Video Logo
136 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
