<!-- from fixya rte -->Why do we get water in the exhaust blower? - Heating & Cooling
    Master:
  • 477 Answers
An air conditioner does just that, it conditions the air, air contains moisture so the air goes in "Wet" it gets conditioned then comes out "Dry" so the moisture that was in the air before conditioning comes out of the exhaust as a by product, hence why old air conditioners were placed in windows for the natural by product to drip away outside.
Posted on Nov 11, 2014
Exhaust blower
If it has no oil ports, replace the motor
Dec 02, 2013 | Fasco Bradford White Hot Water Heater...
Bradford-white water heater wont heat water.the blower motor hums but wont blow.also,pilot light wont light,is this just a safety feature?
Water heater is not identified and gas valve is not known.
Review options below:
1) Add a comment and describe what gas control valve is on the water heater, and model number from label on side of unit. Include what you have tried so far.
2) Try unplugging water heater and see if water heater resets.
Disconnect blower from gas valve, then plug blower in to see it it operates.
This will eliminate or include blower as suspect.
3) Open following link to download service and product manuals to help troubleshoot exact model.
http://www.bradfordwhite.com/documentation/residential/gas.asp
4) Open following link to identify gas valve.
http://waterheatertimer.org/How-to-adjust-temperature-on-water-heater.html#intelli
Oct 04, 2011 | Fasco Bradford White Hot Water Heater...
My fan on top of my bradford white water heater model mitw40L6en13 went out. What kind of of exhaust/blower should i get to replace it? Thank you
Contact Bradford White and ask which blower is correct:
http://www.bradfordwhite.com/supportserv.asp
Get model number and serial number from label located on side of tank.
This information will help BW find exact information for your product.
Jul 28, 2011 | Fasco Bradford White Hot Water Heater...
My hot water heater exhaust blower seems to run quite often, even though hot water consumption is not great. How often should the blower operate?
Your blower should run from before the heater lights until after it has shut off. Even if you're not using water, it will cool, and the heater will have to light to maintain temperature.
Oct 15, 2010 | Fasco Bradford White Hot Water Heater...
The blower is running constantly, trys to ignite gas burner,no hot water
the Thermos coupling has gone bad, call the manufacture and talk to customer support.
Apr 26, 2010 | Fasco Bradford White Water Hot Heater...
My hot water tank won't start, i can hear humming sound from the blower, but blower doesn't run, ant it does no heat.
If the blower will not run, then the unit will not fire up due to a safety hazard. If it is a capacitor start motor, then you may have to replace the capacitor, otherwise you will have to install a new blower motor. Hope this helps
Apr 03, 2010 | Fasco Bradford White Hot Water Heater...
Loud blower on my new Rheem Power Vent 2 water heater
find out if it does the same noise with the venting disconnected
Nov 01, 2009 | Fasco Bradford White Hot Water Heater...
Noisy water heater blower
It may just need a new pump coupling. Fairly inexpensive. I don't think you need to replace the whole burner.
Feb 14, 2009 | Fasco Bradford White Hot Water Heater...
yes the bearing could be gong bad, the screws could be comming loose which could make it where out the motor faster, it should be attended to
Feb 10, 2009 | Fasco Bradford White Hot Water Heater...
Heating & Cooling Logo
54 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
